dboard_iface.hpp
2 // Copyright 2010-2013,2015-2016 Ettus Research LLC
4 //
6 //
7
8 #pragma once
9
10 #include <uhd/config.hpp>
11 #include <uhd/types/serial.hpp>
12 #include <uhd/types/time_spec.hpp>
14 #include <uhd/usrp/gpio_defs.hpp>
15 #include <uhd/utils/pimpl.hpp>
16 #include <stdint.h>
17 #include <chrono>
18 #include <memory>
19 #include <string>
20 #include <vector>
21
22 namespace uhd { namespace usrp {
23
26 {
34
44 };
45
53 {
54 public:
55  typedef std::shared_ptr<dboard_iface> sptr;
57
59  enum unit_t {
60  UNIT_RX = int('r'),
61  UNIT_TX = int('t'),
62  UNIT_BOTH = int('b'),
63  };
64
66  enum aux_dac_t {
67  AUX_DAC_A = int('a'),
68  AUX_DAC_B = int('b'),
69  AUX_DAC_C = int('c'),
70  AUX_DAC_D = int('d')
71  };
72
74  enum aux_adc_t { AUX_ADC_A = int('a'), AUX_ADC_B = int('b') };
75
77
78  ~dboard_iface(void) override{};
79
86  virtual special_props_t get_special_props(void) = 0;
87
95  virtual void write_aux_dac(unit_t unit, aux_dac_t which_dac, double value) = 0;
96
104  virtual double read_aux_adc(unit_t unit, aux_adc_t which_adc) = 0;
105
113  virtual void set_pin_ctrl(unit_t unit, uint32_t value, uint32_t mask = 0xffff) = 0;
114
121  virtual uint32_t get_pin_ctrl(unit_t unit) = 0;
122
131  virtual void set_atr_reg(
132  unit_t unit, atr_reg_t reg, uint32_t value, uint32_t mask = 0xffff) = 0;
133
141  virtual uint32_t get_atr_reg(unit_t unit, atr_reg_t reg) = 0;
142
150  virtual void set_gpio_ddr(unit_t unit, uint32_t value, uint32_t mask = 0xffff) = 0;
151
158  virtual uint32_t get_gpio_ddr(unit_t unit) = 0;
159
167  virtual void set_gpio_out(unit_t unit, uint32_t value, uint32_t mask = 0xffff) = 0;
168
175  virtual uint32_t get_gpio_out(unit_t unit) = 0;
176
183  virtual uint32_t read_gpio(unit_t unit) = 0;
184
193  virtual void write_spi(
194  unit_t unit, const spi_config_t& config, uint32_t data, size_t num_bits) = 0;
195
205  virtual uint32_t read_write_spi(
206  unit_t unit, const spi_config_t& config, uint32_t data, size_t num_bits) = 0;
207
214  virtual void set_clock_rate(unit_t unit, double rate) = 0;
215
222  virtual double get_clock_rate(unit_t unit) = 0;
223
230  virtual std::vector<double> get_clock_rates(unit_t unit) = 0;
231
238  virtual void set_clock_enabled(unit_t unit, bool enb) = 0;
239
247  virtual double get_codec_rate(unit_t unit) = 0;
248
256  virtual void set_fe_connection(unit_t unit,
257  const std::string& fe_name,
258  const uhd::usrp::fe_connection_t& fe_conn) = 0;
259
262  virtual bool has_set_fe_connection(const unit_t)
263  {
264  return false;
265  }
266
271  virtual uhd::time_spec_t get_command_time(void) = 0;
272
277  virtual void set_command_time(const uhd::time_spec_t& t) = 0;
278
283  virtual void sleep(const std::chrono::nanoseconds& time);
284 };
285
286 }} // namespace uhd::usrp
uhd::soft_reg_field::mask
Definition: soft_register.hpp:86
gpio_defs.hpp
uhd::usrp::dboard_iface
Definition: dboard_iface.hpp:52
uhd::usrp::dboard_iface::special_props_t
Definition: dboard_iface.hpp:56
time_spec.hpp
config.hpp
uhd::usrp::dboard_iface::has_set_fe_connection
Definition: dboard_iface.hpp:262
uhd::usrp::dboard_iface_special_props_t::mangle_i2c_addrs
bool mangle_i2c_addrs
Definition: dboard_iface.hpp:43
pimpl.hpp
UHD_API
Definition: config.h:87
uhd::usrp::dboard_iface::sptr
std::shared_ptr< dboard_iface > sptr
Definition: dboard_iface.hpp:55
fe_connection.hpp
Definition: dboard_iface.hpp:25
uhd::usrp::dboard_iface_special_props_t::soft_clock_divider
bool soft_clock_divider
Definition: dboard_iface.hpp:33
uhd::usrp::dboard_iface::atr_reg_t
uhd::usrp::gpio_atr::gpio_atr_reg_t atr_reg_t
Definition: dboard_iface.hpp:76
uhd
Definition: build_info.hpp:12
uhd::time_spec_t
Definition: time_spec.hpp:28
uhd::usrp::dboard_iface::unit_t
unit_t
Definition: dboard_iface.hpp:59
gpio_atr_reg_t
Definition: gpio_defs.hpp:12
uhd::usrp::dboard_iface::aux_adc_t
aux_adc_t
Definition: dboard_iface.hpp:74
serial.hpp
uhd::usrp::dboard_iface::aux_dac_t
aux_dac_t
Definition: dboard_iface.hpp:66
uhd::i2c_iface
Definition: serial.hpp:35
uhd::spi_config_t
Definition: serial.hpp:82
Definition: fe_connection.hpp:16
uhd::usrp::dboard_iface::~dboard_iface
Definition: dboard_iface.hpp:78
