defaults.hpp
4 // Copyright 2020 Ettus Research, a National Instruments Brand
5 //
6 // SPDX-License-Identifier: GPL-3.0-or-later
7 //
8
9 #pragma once
10
11 #include <string>
12
13 namespace uhd { namespace rfnoc {
14
15 static const std::string CLOCK_KEY_GRAPH("__graph__");
16
17 static const std::string PROP_KEY_DECIM("decim");
18 static const std::string PROP_KEY_INTERP("interp");
19 static const std::string PROP_KEY_SAMP_RATE("samp_rate");
20 static const std::string PROP_KEY_SCALING("scaling");
21 static const std::string PROP_KEY_TYPE("type");
22 static const std::string PROP_KEY_FREQ("freq");
23 static const std::string PROP_KEY_TICK_RATE("tick_rate");
24 static const std::string PROP_KEY_SPP("spp");
25 static const std::string PROP_KEY_MTU("mtu");
26 static const std::string PROP_KEY_ATOMIC_ITEM_SIZE("atomic_item_size");
27
28 static const std::string NODE_ID_SEP("SEP");
29
30 using io_type_t = std::string;
31 static const io_type_t IO_TYPE_S16 = "s16";
32 static const io_type_t IO_TYPE_SC16 = "sc16";
33 static const io_type_t IO_TYPE_U8 = "u8";
34
35 static const std::string ACTION_KEY_STREAM_CMD("stream_cmd");
36 static const std::string ACTION_KEY_RX_EVENT("rx_event");
37 static const std::string ACTION_KEY_RX_RESTART_REQ("restart_request");
38 static const std::string ACTION_KEY_TX_EVENT("tx_event");
39
41 static const std::string DEFAULT_BLOCK_NAME = "Block";
43 static const uint32_t DEFAULT_NOC_ID = 0xFFFFFFFF;
44 static const double DEFAULT_TICK_RATE = 1.0;
45
49 using noc_id_t = uint32_t;
50
51 /*** Device Identifiers ******************************************************/
53 using device_type_t = uint16_t;
54 // first nibble for device family (E = E, N = 1, X = A), remaining three nibbles
55 // for device number
57 static const device_type_t ANY_DEVICE = 0xFFFF;
59 static const device_type_t E300 = 0xE300;
61 static const device_type_t E310 = 0xE310;
63 static const device_type_t E320 = 0xE320;
65 static const device_type_t N300 = 0x1300;
67 static const device_type_t N320 = 0x1320;
69 static const device_type_t X300 = 0xA300;
71 static const device_type_t X400 = 0xA400;
72
73 // block identifiers
74 static const noc_id_t ADDSUB_BLOCK = 0xADD00000;
75 static const noc_id_t DUC_BLOCK = 0xD0C00000;
76 static const noc_id_t DDC_BLOCK = 0xDDC00000;
77 static const noc_id_t FFT_BLOCK = 0xFF700000;
78 static const noc_id_t FIR_FILTER_BLOCK = 0xF1120000;
79 static const noc_id_t FOSPHOR_BLOCK = 0x666F0000;
80 static const noc_id_t LOGPWR_BLOCK = 0x4C500000;
81 static const noc_id_t KEEP_ONE_IN_N_BLOCK = 0x02460000;
82 static const noc_id_t MOVING_AVERAGE_BLOCK = 0xAAD20000;
83 static const noc_id_t RADIO_BLOCK = 0x12AD1000;
84 static const noc_id_t REPLAY_BLOCK = 0x4E91A000;
85 static const noc_id_t SIGGEN_BLOCK = 0x51663110;
86 static const noc_id_t SPLIT_STREAM_BLOCK = 0x57570000;
87 static const noc_id_t SWITCHBOARD_BLOCK = 0xBE110000;
88 static const noc_id_t VECTOR_IIR_BLOCK = 0x11120000;
89 static const noc_id_t WINDOW_BLOCK = 0xD0530000;
90
91 }} // namespace uhd::rfnoc
uhd
Definition: build_info.hpp:12
uhd::rfnoc::io_type_t
std::string io_type_t
Definition: defaults.hpp:30
uhd::rfnoc::device_type_t
uint16_t device_type_t
Device Type.
Definition: defaults.hpp:53
uhd::rfnoc::noc_id_t
uint32_t noc_id_t
Definition: defaults.hpp:49
