The extension framework enables custom libraries to attach to UHD. This can be used for instance when an external frontend module shall be used together with a USRP while maintaining the control via the UHD API.
For getting started with the extensions framework please refer to the extension example in the examples directory. It can be built by
cmake .. && make && make install
Depending on your UHD installation prefix root privileges may be required for make install
Known issue: When using the Python API with an extension installed, import uhd
may throw an error:
Error: EnvironmentError: OSError: dlopen failed to load "/path/to/libextension.so"
If this occurs, please provide the LD_PRELOAD variable with the path to the uhdlib:
export LD_PRELOAD=[UHD_PREFIX]/lib/libuhd.so
Afterwards start Python again in the same commandline.
The Extension Framework attaches to multi_usrp and will work for all RFNoC-capable devices. The following methods in multi_usrp offer hooks which allow for manipulating the behavior of the USRP and controlling the extension:
RX:
set_rx_freq()
get_rx_freq()
get_rx_freq_range()
get_fe_rx_freq_range()
set_rx_gain()
set_rx_agc()
get_rx_gain()
get_rx_gain_range()
get_rx_gain_names()
set_rx_antenna()
get_rx_antenna()
get_rx_antennas()
set_rx_bandwidth()
get_rx_bandwidth()
get_rx_bandwidth_range()
TX:
set_tx_freq()
get_tx_freq()
get_tx_freq_range()
get_fe_tx_freq_range()
set_tx_gain()
get_tx_gain()
get_tx_gain_range()
get_tx_gain_names()
set_tx_antenna()
get_tx_antenna()
get_tx_antennas()
set_tx_bandwidth()
get_tx_bandwidth()
get_tx_bandwidth_range()
Further hooks may be implemented in the future. These hooks call into the following methods in an extension:
RX:
set_rx_tune_args()
set_rx_frequency()
get_rx_frequency()
get_rx_frequency_range()
set_rx_bandwidth()
get_rx_bandwidth()
set_rx_gain()
get_rx_gain()
set_rx_agc()
get_rx_gain_range()
get_rx_gain_names()
set_rx_antenna()
get_rx_antenna()
get_rx_antennas()
TX:
set_tx_tune_args()
set_tx_frequency()
get_tx_frequency()
get_tx_frequency_range()
set_tx_bandwidth()
get_tx_bandwidth()
set_tx_gain()
get_tx_gain()
get_tx_gain_range()
get_tx_gain_names()
set_tx_antenna()
get_tx_antenna()
get_tx_antennas()
The implementation of these methods in the extension may just pass this through to the equivalent method on the radio or it can change values, call other methods e.g. of other devices etc.
To use the Extension Framework, uhd::extension::extension from uhd/extension/extension.hpp needs to be implemented.
The implementation of the extension will have to register itself by calling UHD_REGISTER_EXTENSION([extension_name], [class_name])
. After building the extension library it must be either:
UHD_MODULE_PATH
environment variable,\<install-path\>/share/uhd/modules
directory,/usr/share/uhd/modules
directory (UNIX only).To use the extension its name will have to be passed to the arguments string like "extension=[extension_name]".
