Device Identification
Identifying USRP Devices
Devices are addressed through key/value string pairs. These string pairs can be used to narrow down the search for a specific device or group of devices. Most UHD utility applications and examples have an --args parameter that takes a device address, which is expressed as a delimited string.
See uhd::device_addr_t for reference.
Note that the device "address" can also take configuration options. See Configuring Devices and Streamers for a list of those options.
Common device identifiers
Every device has several ways of identifying it on the host system:
Identifier Key Notes Devices Example Value
Serial # serial globally unique identifier All devices 12345678
IP Address addr unique identifier on a network All network devices 192.168.10.2
Resource resource unique identifier for USRP RIO devices (over PCI Express) X3x0 RIO0
Name name optional user-set identifier or hostname All devices my_usrp1 (User-defined value)
Type type hardware series identifier All devices usrp1, usrp2, b200, x300, n3xx, x4xx ...
Vendor/Product ID vid,pid Both must be provided, as well as type. All USB Devices vid=0x04b4,pid=0x8613
Device discovery via command line
Devices attached to your system can be discovered using the uhd_find_devices program. This program scans your system for supported devices and prints out an enumerated list of discovered devices and their addresses. The list of discovered devices can be narrowed down by specifying device address args.
uhd_find_devices
Device address arguments can be supplied to narrow the scope of the search.
uhd_find_devices --args="type=usrp1"
-- OR --
uhd_find_devices --args="serial=12345678"
Device discovery through the API
The device::find() API call searches for devices and returns a list of discovered devices.
uhd::device_addr_t hint; //an empty hint discovers all devices
The hint argument can be populated to narrow the scope of the search.
hint["type"] = "usrp1";
-- OR --
hint["serial"] = "12345678";
Device properties
Properties of devices attached to your system can be probed with the uhd_usrp_probe program. This program constructs an instance of the device and prints out its properties, such as detected daughterboards, frequency range, gain ranges, etc...
Usage:
uhd_usrp_probe --args <device-specific-address-args>
Naming a USRP Device
For convenience purposes, users may assign a custom name to their USRP device. The USRP device can then be identified via name, rather than a difficult to remember serial or address.
A name has the following properties:
  • is composed of ASCII characters
  • is 0-20 characters
  • is not required to be unique
Set a custom name
Run the following commands:
./usrp_burn_mb_eeprom --args=<optional device args> --values="name=lab1_xcvr"
Discovery via name
The keyword name can be used to narrow the scope of the search. Example with the find devices utility:
uhd_find_devices --args="name=lab1_xcvr"
-- OR --
uhd_find_devices --args="type=usrp1, name=lab1_xcvr"
uhd::device_addrs_t
std::vector< device_addr_t > device_addrs_t
A typedef for a vector of device addresses.
Definition: device_addr.hpp:93
uhd::device_addr_t
Definition: device_addr.hpp:37
uhd::device::find
static device_addrs_t find(const device_addr_t &hint, device_filter_t filter=ANY)
Find devices attached to the host.
