Version: 4.3.0.HEAD-0-g1f8fd345
30 struct uhd_meta_range_t {
32 std::string last_error;
37 struct uhd_meta_range_t;
137 UHD_API void uhd_range_cpp_to_c(
UHD_API uhd_error uhd_meta_range_push_back(uhd_meta_range_handle h, const uhd_range_t *range)
Add a range to the given meta range.
UHD_API uhd_error uhd_meta_range_free(uhd_meta_range_handle *h)
Destroy a meta range handle.
Range of floating-point values.
Definition: ranges.h:17
UHD_API uhd_error uhd_meta_range_make(uhd_meta_range_handle *h)
Create a meta range handle.
uhd_error
UHD error codes.
Definition: error.h:20
UHD_API uhd_error uhd_meta_range_step(uhd_meta_range_handle h, double *step_out)
Get the overall step value for the given meta range.
UHD_API uhd_error uhd_meta_range_stop(uhd_meta_range_handle h, double *stop_out)
Get the overall stop value for the given meta range.
double step
Granularity.
Definition: ranges.h:23
UHD_API uhd_error uhd_range_to_pp_string(const uhd_range_t *range, char *pp_string_out, size_t strbuffer_len)
Get a string representation of the given range.
Definition: config.h:87
Definition: ranges.h:44
UHD_API uhd_error uhd_meta_range_last_error(uhd_meta_range_handle h, char *error_out, size_t strbuffer_len)
Get the last error recorded by the underlying meta range.
double stop
Last value.
Definition: ranges.h:21
UHD_API uhd_error uhd_meta_range_to_pp_string(uhd_meta_range_handle h, char *pp_string_out, size_t strbuffer_len)
Get a string representation of the given meta range.
UHD_API uhd_error uhd_meta_range_size(uhd_meta_range_handle h, size_t *size_out)
Get the number of ranges in the given meta range.
double start
First value.
Definition: ranges.h:19
UHD_API uhd_error uhd_meta_range_at(uhd_meta_range_handle h, size_t num, uhd_range_t *range_out)
Get the range at the given index.
UHD_API uhd_error uhd_meta_range_clip(uhd_meta_range_handle h, double value, bool clip_step, double *result_out)
Clip the given value to a possible value in the given range.
Definition: ranges.hpp:21
UHD_API uhd_error uhd_meta_range_start(uhd_meta_range_handle h, double *start_out)
Get the overall start value for the given meta range.
