rfnoc_graph.hpp
2 // Copyright 2019 Ettus Research, a National Instruments Brand
5 //
6
7 #pragma once
8
9 #include <uhd/config.hpp>
10 #include <uhd/rfnoc/block_id.hpp>
11 #include <uhd/rfnoc/graph_edge.hpp>
13 #include <uhd/stream.hpp>
16 #include <uhd/types/time_spec.hpp>
18 #include <boost/units/detail/utility.hpp> // for demangle
19 #include <memory>
20 #include <vector>
21
22 namespace uhd { namespace rfnoc {
23
24 class mb_controller;
25
32 class UHD_API rfnoc_graph : public uhd::noncopyable, public std::enable_shared_from_this<rfnoc_graph>
33 {
34 public:
38  using sptr = std::shared_ptr<rfnoc_graph>;
39
40  virtual ~rfnoc_graph() {}
41
42  /******************************************
43  * Factory
44  ******************************************/
53  static sptr make(const device_addr_t& dev_addr);
54
55  /******************************************
56  * Block Discovery/Retrieval
57  ******************************************/
77  virtual std::vector<block_id_t> find_blocks(
78  const std::string& block_id_hint) const = 0;
79
82  template <typename T>
83  std::vector<block_id_t> find_blocks(const std::string& block_id_hint) const
84  {
85  std::vector<block_id_t> all_block_ids = find_blocks(block_id_hint);
86  std::vector<block_id_t> filt_block_ids;
87  for (size_t i = 0; i < all_block_ids.size(); i++) {
88  if (has_block<T>(all_block_ids[i])) {
89  filt_block_ids.push_back(all_block_ids[i]);
90  }
91  }
92  return filt_block_ids;
93  }
94
101  virtual bool has_block(const block_id_t& block_id) const = 0;
102
108  template <typename T>
109  bool has_block(const block_id_t& block_id) const
110  {
111  return has_block(block_id)
112  && bool(std::dynamic_pointer_cast<T>(get_block(block_id)));
113  }
114
123  virtual noc_block_base::sptr get_block(const block_id_t& block_id) const = 0;
124
139  template <typename T>
140  std::shared_ptr<T> get_block(const block_id_t& block_id) const
141  {
142  std::shared_ptr<T> blk = std::dynamic_pointer_cast<T>(get_block(block_id));
143  if (blk) {
144  return blk;
145  } else {
146  throw uhd::lookup_error(
147  std::string("This device does not have a block of type ")
148  + boost::units::detail::demangle(typeid(T).name())
149  + " with ID: " + block_id.to_string());
150  }
151  }
152
153  /**************************************************************************
154  * Connection APIs
155  *************************************************************************/
164  virtual bool is_connectable(const block_id_t& src_blk,
165  size_t src_port,
166  const block_id_t& dst_blk,
167  size_t dst_port) = 0;
168
188  virtual void connect(const block_id_t& src_blk,
189  size_t src_port,
190  const block_id_t& dst_blk,
191  size_t dst_port,
192  bool is_back_edge = false) = 0;
193
205  virtual void connect(uhd::tx_streamer::sptr streamer,
206  size_t strm_port,
207  const block_id_t& dst_blk,
208  size_t dst_port,
209  uhd::transport::adapter_id_t adapter_id = uhd::transport::NULL_ADAPTER_ID) = 0;
210
222  virtual void connect(const block_id_t& src_blk,
223  size_t src_port,
224  uhd::rx_streamer::sptr streamer,
225  size_t strm_port,
226  uhd::transport::adapter_id_t adapter_id = uhd::transport::NULL_ADAPTER_ID) = 0;
227
241  virtual void disconnect(const block_id_t& src_blk,
242  size_t src_port,
243  const block_id_t& dst_blk,
244  size_t dst_port) = 0;
245
255  virtual void disconnect(const std::string& streamer_id) = 0;
256
267  virtual void disconnect(const std::string& streamer_id, size_t port) = 0;
268
278  virtual std::vector<uhd::transport::adapter_id_t> enumerate_adapters_from_src(
279  const block_id_t& src_blk, size_t src_port) = 0;
280
290  virtual std::vector<uhd::transport::adapter_id_t> enumerate_adapters_to_dst(
291  const block_id_t& dst_blk, size_t dst_port) = 0;
292
302  virtual std::vector<graph_edge_t> enumerate_static_connections() const = 0;
303
311  virtual std::vector<graph_edge_t> enumerate_active_connections() = 0;
312
320  virtual void commit() = 0;
321
327  virtual void release() = 0;
328
329  /******************************************
330  * Streaming
331  ******************************************/
332
343  virtual rx_streamer::sptr create_rx_streamer(
344  const size_t num_ports, const stream_args_t& args) = 0;
345
356  virtual tx_streamer::sptr create_tx_streamer(
357  const size_t num_ports, const stream_args_t& args) = 0;
358
359  /**************************************************************************
360  * Hardware Control
361  *************************************************************************/
362  virtual size_t get_num_mboards() const = 0;
364  //
365  // See also uhd::rfnoc::mb_controller
366  virtual std::shared_ptr<mb_controller> get_mb_controller(
367  const size_t mb_index = 0) = 0;
368
389  virtual bool synchronize_devices(
390  const uhd::time_spec_t& time_spec, const bool quiet) = 0;
391
393  virtual uhd::property_tree::sptr get_tree(void) const = 0;
394 }; // class rfnoc_graph
395
396 }}; // namespace uhd::rfnoc
device_addr.hpp
uhd::rfnoc::block_id_t
Definition: block_id.hpp:39
time_spec.hpp
config.hpp
uhd::rfnoc::rfnoc_graph::find_blocks
std::vector< block_id_t > find_blocks(const std::string &block_id_hint) const
Definition: rfnoc_graph.hpp:83
uhd::lookup_error
Definition: exception.hpp:58
block_id.hpp
conf.release
string release
Definition: conf.py:29
Definition: stream.hpp:169
std::shared_ptr< tx_streamer > sptr
Definition: stream.hpp:267
uhd::rfnoc::block_id_t::to_string
std::string to_string() const
Return a string like this: "0/FFT#1" (includes all components, if set)
UHD_API
Definition: config.h:87
Definition: property_tree.hpp:222
noncopyable.hpp
uhd::rfnoc::rfnoc_graph::has_block
bool has_block(const block_id_t &block_id) const
Definition: rfnoc_graph.hpp:109
uhd::device_addr_t
Definition: device_addr.hpp:37
uhd::rfnoc::rfnoc_graph::~rfnoc_graph
Definition: rfnoc_graph.hpp:40
uhd
Definition: build_info.hpp:12
uhd::time_spec_t
Definition: time_spec.hpp:28
size_t adapter_id_t
Host transport adapter ID.
Definition: adapter_id.hpp:17
noc_block_base.hpp
Definition: rfnoc_graph.hpp:32
graph_edge.hpp
adapter_id.hpp
uhd::stream_args_t
Definition: stream.hpp:47
uhd::rfnoc::rfnoc_graph::sptr
std::shared_ptr< rfnoc_graph > sptr
Definition: rfnoc_graph.hpp:38
uhd::rfnoc::noc_block_base::sptr
Definition: noc_block_base.hpp:48
stream.hpp
uhd::noncopyable
uhd::rfnoc::rfnoc_graph::get_block
std::shared_ptr< T > get_block(const block_id_t &block_id) const
Definition: rfnoc_graph.hpp:140
