sensors.h
4 //
6 //
7
8 #pragma once
9
10 #include <uhd/config.h>
11 #include <uhd/error.h>
12
13 #ifdef __cplusplus
14 #include <uhd/types/sensors.hpp>
15 #include <string>
16
17 struct uhd_sensor_value_t {
18  // No default constructor, so we need a pointer
19  uhd::sensor_value_t* sensor_value_cpp;
20  std::string last_error;
21 };
22 extern "C" {
23 #else
24 struct uhd_sensor_value_t;
25 #endif
26
28
33 typedef struct uhd_sensor_value_t* uhd_sensor_value_handle;
34
36 typedef enum {
42
44
55 );
56
58
68  const char* name,
69  bool value,
70  const char* utrue,
71  const char* ufalse
72 );
73
75
85  const char* name,
86  int value,
87  const char* unit,
88  const char* formatter
89 );
90
92
102  const char* name,
103  double value,
104  const char* unit,
105  const char* formatter
106 );
107
109
118  const char* name,
119  const char* value,
120  const char* unit
121 );
122
124
130 );
131
135  bool *value_out
136 );
137
141  int *value_out
142 );
143
147  double *value_out
148 );
149
151
161  char* name_out,
162  size_t strbuffer_len
163 );
164
166
176  char* value_out,
177  size_t strbuffer_len
178 );
179
181
191  char* unit_out,
192  size_t strbuffer_len
193 );
194
197  uhd_sensor_value_data_type_t *data_type_out
198 );
199
201
211  char* pp_string_out,
212  size_t strbuffer_len
213 );
214
216
226  char* error_out,
227  size_t strbuffer_len
228 );
229
230 #ifdef __cplusplus
231 }
232 #endif
uhd_sensor_value_to_int
UHD_API uhd_error uhd_sensor_value_to_int(uhd_sensor_value_handle h, int *value_out)
Get the sensor's value as an integer.
uhd_sensor_value_make_from_int
UHD_API uhd_error uhd_sensor_value_make_from_int(uhd_sensor_value_handle *h, const char *name, int value, const char *unit, const char *formatter)
Make a UHD sensor from an integer.
uhd_sensor_value_to_realnum
UHD_API uhd_error uhd_sensor_value_to_realnum(uhd_sensor_value_handle h, double *value_out)
Get the sensor's value as a real number.
UHD_SENSOR_VALUE_STRING
@ UHD_SENSOR_VALUE_STRING
Definition: sensors.h:40
sensors.hpp
uhd_sensor_value_free
UHD_API uhd_error uhd_sensor_value_free(uhd_sensor_value_handle *h)
Free the given sensor handle.
uhd_error
uhd_error
UHD error codes.
Definition: error.h:20
UHD_SENSOR_VALUE_INTEGER
@ UHD_SENSOR_VALUE_INTEGER
Definition: sensors.h:38
uhd_sensor_value_value
UHD_API uhd_error uhd_sensor_value_value(uhd_sensor_value_handle h, char *value_out, size_t strbuffer_len)
Get the sensor's value.
uhd_sensor_value_unit
UHD_API uhd_error uhd_sensor_value_unit(uhd_sensor_value_handle h, char *unit_out, size_t strbuffer_len)
Get the sensor's unit.
UHD_API
Definition: config.h:87
uhd_sensor_value_make_from_string
UHD_API uhd_error uhd_sensor_value_make_from_string(uhd_sensor_value_handle *h, const char *name, const char *value, const char *unit)
Make a UHD sensor from a string.
Sensor value types.
Definition: sensors.h:36
UHD_API uhd_error uhd_sensor_value_data_type(uhd_sensor_value_handle h, uhd_sensor_value_data_type_t *data_type_out)
uhd_sensor_value_make_from_bool
UHD_API uhd_error uhd_sensor_value_make_from_bool(uhd_sensor_value_handle *h, const char *name, bool value, const char *utrue, const char *ufalse)
Make a UHD sensor from a boolean.
error.h
UHD_API uhd_error uhd_sensor_value_make(uhd_sensor_value_handle *h)
Make an empty UHD sensor value.
UHD_SENSOR_VALUE_REALNUM
@ UHD_SENSOR_VALUE_REALNUM
Definition: sensors.h:39
uhd_sensor_value_to_pp_string
UHD_API uhd_error uhd_sensor_value_to_pp_string(uhd_sensor_value_handle h, char *pp_string_out, size_t strbuffer_len)
Get a pretty-print representation of the given sensor.
uhd_sensor_value_to_bool
UHD_API uhd_error uhd_sensor_value_to_bool(uhd_sensor_value_handle h, bool *value_out)
Get the sensor's value as a boolean.
uhd_sensor_value_make_from_realnum
UHD_API uhd_error uhd_sensor_value_make_from_realnum(uhd_sensor_value_handle *h, const char *name, double value, const char *unit, const char *formatter)
Make a UHD sensor from a real number.
Definition: sensors.h:33
config.h
uhd_sensor_value_name
UHD_API uhd_error uhd_sensor_value_name(uhd_sensor_value_handle h, char *name_out, size_t strbuffer_len)
Get the sensor's name.
uhd::sensor_value_t
Definition: sensors.hpp:28
uhd_sensor_value_last_error
UHD_API uhd_error uhd_sensor_value_last_error(uhd_sensor_value_handle h, char *error_out, size_t strbuffer_len)
Get the last error logged by the sensor handle.
UHD_SENSOR_VALUE_BOOLEAN
@ UHD_SENSOR_VALUE_BOOLEAN
Definition: sensors.h:37
