usrp_info.h
1 /*
2  * Copyright 2015 Ettus Research LLC
3  * Copyright 2018 Ettus Research, a National Instruments Company
4  *
5  * SPDX-License-Identifier: GPL-3.0-or-later
6  */
7
8 #pragma once
9
10 #include <uhd/config.h>
11 #include <uhd/error.h>
12
14
17 typedef struct {
19  char* mboard_id;
21  char* mboard_name;
25  char* rx_id;
31  char* rx_serial;
33  char* rx_antenna;
35
37
40 typedef struct {
42  char* mboard_id;
44  char* mboard_name;
48  char* tx_id;
54  char* tx_serial;
56  char* tx_antenna;
58
59 #ifdef __cplusplus
60 extern "C" {
61 #endif
62
64
70
72
78
79 #ifdef __cplusplus
80 }
81 #endif
uhd_usrp_rx_info_t::rx_subdev_name
char * rx_subdev_name
RX subdev name.
Definition: usrp_info.h:27
uhd_usrp_rx_info_t::rx_id
char * rx_id
RX daughterboard ID.
Definition: usrp_info.h:25
uhd_usrp_rx_info_t::rx_antenna
char * rx_antenna
RX daughterboard antenna.
Definition: usrp_info.h:33
uhd_error
uhd_error
UHD error codes.
Definition: error.h:20
uhd_usrp_rx_info_free
UHD_API uhd_error uhd_usrp_rx_info_free(uhd_usrp_rx_info_t *rx_info)
Clean up a uhd_usrp_rx_info_t populated by uhd_usrp_get_rx_info().
uhd_usrp_tx_info_t::tx_serial
char * tx_serial
TX daughterboard serial.
Definition: usrp_info.h:54
UHD_API
Definition: config.h:87
uhd_usrp_rx_info_t::rx_subdev_spec
char * rx_subdev_spec
RX subdev spec.
Definition: usrp_info.h:29
uhd_usrp_tx_info_t::tx_antenna
char * tx_antenna
TX daughterboard antenna.
Definition: usrp_info.h:56
uhd_usrp_tx_info_t
USRP TX info.
Definition: usrp_info.h:40
uhd_usrp_rx_info_t::mboard_id
char * mboard_id
Motherboard ID.
Definition: usrp_info.h:19
uhd_usrp_tx_info_t::mboard_name
char * mboard_name
Motherboard name.
Definition: usrp_info.h:44
uhd_usrp_tx_info_t::tx_id
char * tx_id
TX daughterboard ID.
Definition: usrp_info.h:48
error.h
uhd_usrp_rx_info_t
USRP RX info.
Definition: usrp_info.h:17
uhd_usrp_rx_info_t::mboard_serial
char * mboard_serial
Motherboard serial.
Definition: usrp_info.h:23
uhd_usrp_tx_info_t::tx_subdev_spec
char * tx_subdev_spec
TX subdev spec.
Definition: usrp_info.h:52
uhd_usrp_rx_info_t::rx_serial
char * rx_serial
RX daughterboard serial.
Definition: usrp_info.h:31
uhd_usrp_tx_info_t::mboard_id
char * mboard_id
Motherboard ID.
Definition: usrp_info.h:42
config.h
uhd_usrp_tx_info_free
UHD_API uhd_error uhd_usrp_tx_info_free(uhd_usrp_tx_info_t *tx_info)
Clean up a uhd_usrp_tx_info_t populated by uhd_usrp_get_tx_info().
uhd_usrp_tx_info_t::mboard_serial
Motherboard serial.
Definition: usrp_info.h:46
uhd_usrp_rx_info_t::mboard_name
char * mboard_name
Motherboard name.
Definition: usrp_info.h:21
uhd_usrp_tx_info_t::tx_subdev_name
char * tx_subdev_name
TX subdev name.
Definition: usrp_info.h:50
