window_block_control.hpp
2 // Copyright 2020 Ettus Research, a National Instruments Brand
5 //
6
7 #pragma once
8
9 #include <uhd/config.hpp>
11 #include <uhd/types/ranges.hpp>
12
13 namespace uhd { namespace rfnoc {
14
31 {
32 public:
34
35  // Block registers
36  static const uint32_t REG_WINDOW_BLOCK_SIZE;
37
38  static const uint32_t REG_WINDOW_LEN_OFFSET;
39  static const uint32_t REG_WINDOW_MAX_LEN_OFFSET;
40  static const uint32_t REG_WINDOW_LOAD_COEFF_OFFSET;
41  static const uint32_t REG_WINDOW_LOAD_COEFF_LAST_OFFSET;
42
51  virtual size_t get_max_num_coefficients(const size_t chan) const = 0;
52
62  virtual void set_coefficients(
63  const std::vector<int16_t>& coeffs, const size_t chan) = 0;
64
72  virtual std::vector<int16_t> get_coefficients(const size_t chan) const = 0;
73 };
74
75 }} // namespace uhd::rfnoc
config.hpp
uhd::rfnoc::noc_block_base
Definition: noc_block_base.hpp:42
uhd::rfnoc::window_block_control
Definition: window_block_control.hpp:30
UHD_API
Definition: config.h:87
uhd
Definition: build_info.hpp:12
ranges.hpp
noc_block_base.hpp
RFNOC_DECLARE_BLOCK
#define RFNOC_DECLARE_BLOCK(CLASS_NAME)
Definition: noc_block_base.hpp:22
