Loading [MathJax]/jax/output/HTML-CSS/config.js
All
Classes
Namespaces
Files
Functions
Variables
Typedefs
Enumerations
Enumerator
Friends
Macros
Modules
Pages
cast.hpp
1
2
// Copyright 2014-2015 Ettus Research LLC
3
// Copyright 2018 Ettus Research, a National Instruments Company
4
// Copyright 2019 Ettus Research, a National Instruments Brand
5
6
// SPDX-License-Identifier: GPL-3.0-or-later
7
8
9
#pragma once
10
11
#include <
uhd/config.hpp
12
#include <
uhd/exception.hpp
13
#include <sstream>
14
#include <string>
15
16
namespace
uhd
namespace
cast {
18
19
// Example:
// uint16_t x = hexstr_cast<uint16_t>("0xDEADBEEF");
21
// Uses stringstream.
22
template
typename
T>
23
T
hexstr_cast
const
std::string& in)
25
T x;
26
std::stringstream ss;
27
ss << std::hex << in;
28
ss >> x;
29
return
x;
30
31
33
template
typename
data_t>
34
data_t
from_str
const
std::string&)
35
36
throw
uhd::runtime_error
"Cannot convert from string!"
37
38
39
// Specializations of `uhd::cast::from_str()` for supported data types
40
42
43
// Examples evaluating to `true`: 'True', 'Yes', 'y', '1', empty string
44
// Examples evaluating to `false`: 'false', 'NO', 'n', '0'
45
// Throws `uhd::runtime_error` if the string can't be converted to `bool`
46
template
47
UHD_API
bool
from_str
const
std::string& val);
48
50
template
51
UHD_API
double
from_str
const
std::string& val);
52
54
template
55
UHD_API
int
from_str
const
std::string& val);
56
58
59
// This function simply returns the incoming string
60
template
61
UHD_API
std::string
from_str
const
std::string& val);
62
63
// namespace uhd::cast
config.hpp
uhd::cast::from_str
data_t from_str(const std::string &)
Generic cast-from-string function.
Definition:
cast.hpp:34
UHD_API
Definition:
config.h:87
uhd::cast::hexstr_cast
T hexstr_cast(const std::string &in)
Convert a hexadecimal string into a value.
Definition:
cast.hpp:23
uhd
Definition:
build_info.hpp:12
uhd::runtime_error
Definition:
exception.hpp:131
exception.hpp
include
uhd
utils
cast.hpp
Generated by
1.8.17
