uhd::rfnoc::ddc_block_control Member List
This is the complete list of members for uhd::rfnoc::ddc_block_control, including all inherited members.
get_freq(const size_t chan) const =0uhd::rfnoc::ddc_block_controlpure virtual
get_frequency_range(const size_t chan) const =0uhd::rfnoc::ddc_block_controlpure virtual
get_input_rate(const size_t chan) const =0uhd::rfnoc::ddc_block_controlpure virtual
get_output_rate(const size_t chan) const =0uhd::rfnoc::ddc_block_controlpure virtual
get_output_rates(const size_t chan) const =0uhd::rfnoc::ddc_block_controlpure virtual
issue_stream_cmd(const uhd::stream_cmd_t &stream_cmd, const size_t port)=0uhd::rfnoc::ddc_block_controlpure virtual
MAJOR_COMPATuhd::rfnoc::ddc_block_controlstatic
MINOR_COMPATuhd::rfnoc::ddc_block_controlstatic
node_t()uhd::rfnoc::node_t
RB_CIC_MAX_DECIMuhd::rfnoc::ddc_block_controlstatic
RB_COMPAT_NUMuhd::rfnoc::ddc_block_controlstatic
RB_NUM_HBuhd::rfnoc::ddc_block_controlstatic
set_freq(const double freq, const size_t chan, const boost::optional< uhd::time_spec_t > time=boost::none)=0uhd::rfnoc::ddc_block_controlpure virtual
set_input_rate(const double rate, const size_t chan)=0uhd::rfnoc::ddc_block_controlpure virtual
set_output_rate(const double rate, const size_t chan)=0uhd::rfnoc::ddc_block_controlpure virtual
SR_COEFFS_ADDRuhd::rfnoc::ddc_block_controlstatic
SR_CONFIG_ADDRuhd::rfnoc::ddc_block_controlstatic
SR_DECIM_ADDRuhd::rfnoc::ddc_block_controlstatic
SR_FREQ_ADDRuhd::rfnoc::ddc_block_controlstatic
SR_M_ADDRuhd::rfnoc::ddc_block_controlstatic
SR_MUX_ADDRuhd::rfnoc::ddc_block_controlstatic
SR_N_ADDRuhd::rfnoc::ddc_block_controlstatic
SR_SCALE_IQ_ADDRuhd::rfnoc::ddc_block_controlstatic
SR_TIME_INCR_ADDRuhd::rfnoc::ddc_block_controlstatic
