uhd::usrp::multi_usrp Member List
This is the complete list of members for uhd::usrp::multi_usrp, including all inherited members.
ALL_CHANSuhd::usrp::multi_usrpstatic
ALL_GAINSuhd::usrp::multi_usrpstatic
ALL_LOSuhd::usrp::multi_usrpstatic
ALL_MBOARDSuhd::usrp::multi_usrpstatic
clear_command_time(size_t mboard=ALL_MBOARDS)=0uhd::usrp::multi_usrppure virtual
get_clock_source(const size_t mboard)=0uhd::usrp::multi_usrppure virtual
get_clock_sources(const size_t mboard)=0uhd::usrp::multi_usrppure virtual
get_device(void)=0uhd::usrp::multi_usrppure virtual
get_extension(const direction_t trx, const size_t chan)=0uhd::usrp::multi_usrppure virtual
get_extension(const direction_t trx, const size_t chan)uhd::usrp::multi_usrpinline
get_fe_rx_freq_range(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_fe_tx_freq_range(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_gpio_attr(const std::string &bank, const std::string &attr, const size_t mboard=0)=0uhd::usrp::multi_usrppure virtual
get_gpio_banks(const size_t mboard)=0uhd::usrp::multi_usrppure virtual
get_gpio_src(const std::string &bank, const size_t mboard=0)=0uhd::usrp::multi_usrppure virtual
get_gpio_src_banks(const size_t mboard=0)=0uhd::usrp::multi_usrppure virtual
get_gpio_srcs(const std::string &bank, const size_t mboard=0)=0uhd::usrp::multi_usrppure virtual
get_master_clock_rate(size_t mboard=0)=0uhd::usrp::multi_usrppure virtual
get_master_clock_rate_range(const size_t mboard=0)=0uhd::usrp::multi_usrppure virtual
get_mb_controller(const size_t mboard=0)=0uhd::usrp::multi_usrppure virtual
get_mboard_name(size_t mboard=0)=0uhd::usrp::multi_usrppure virtual
get_mboard_sensor(const std::string &name, size_t mboard=0)=0uhd::usrp::multi_usrppure virtual
get_mboard_sensor_names(size_t mboard=0)=0uhd::usrp::multi_usrppure virtual
get_normalized_rx_gain(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_normalized_tx_gain(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_num_mboards(void)=0uhd::usrp::multi_usrppure virtual
get_pp_string(void)=0uhd::usrp::multi_usrppure virtual
get_radio_control(const size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_antenna(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_antennas(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_bandwidth(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_bandwidth_range(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_dboard_iface(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_dc_offset_range(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_filter(const std::string &name, const size_t chan)=0uhd::usrp::multi_usrppure virtual
get_rx_filter_names(const size_t chan)=0uhd::usrp::multi_usrppure virtual
get_rx_freq(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_freq_range(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_gain(const std::string &name, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_gain(size_t chan=0)uhd::usrp::multi_usrpinline
get_rx_gain_names(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_gain_profile(const size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_gain_profile_names(const size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_gain_range(const std::string &name, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_gain_range(size_t chan=0)uhd::usrp::multi_usrpinline
get_rx_lo_export_enabled(const std::string &name=ALL_LOS, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_lo_freq(const std::string &name, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_lo_freq_range(const std::string &name, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_lo_names(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_lo_source(const std::string &name=ALL_LOS, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_lo_sources(const std::string &name=ALL_LOS, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_num_channels(void)=0uhd::usrp::multi_usrppure virtual
get_rx_power_range(const size_t chan)=0uhd::usrp::multi_usrppure virtual
get_rx_power_reference(const size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_rate(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_rates(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_sensor(const std::string &name, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_sensor_names(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_stream(const stream_args_t &args)=0uhd::usrp::multi_usrppure virtual
get_rx_subdev_name(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_rx_subdev_spec(size_t mboard=0)=0uhd::usrp::multi_usrppure virtual
get_sync_source(const size_t mboard)=0uhd::usrp::multi_usrppure virtual
get_sync_sources(const size_t mboard)=0uhd::usrp::multi_usrppure virtual
get_time_last_pps(size_t mboard=0)=0uhd::usrp::multi_usrppure virtual
get_time_now(size_t mboard=0)=0uhd::usrp::multi_usrppure virtual
get_time_source(const size_t mboard)=0uhd::usrp::multi_usrppure virtual
get_time_sources(const size_t mboard)=0uhd::usrp::multi_usrppure virtual
get_time_synchronized(void)=0uhd::usrp::multi_usrppure virtual
get_tree(void) const =0uhd::usrp::multi_usrppure virtual
get_tx_antenna(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_antennas(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_bandwidth(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_bandwidth_range(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_dboard_iface(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_dc_offset_range(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_filter(const std::string &name, const size_t chan)=0uhd::usrp::multi_usrppure virtual
get_tx_filter_names(const size_t chan)=0uhd::usrp::multi_usrppure virtual
get_tx_freq(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_freq_range(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_gain(const std::string &name, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_gain(size_t chan=0)uhd::usrp::multi_usrpinline
get_tx_gain_names(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_gain_profile(const size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_gain_profile_names(const size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_gain_range(const std::string &name, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_gain_range(size_t chan=0)uhd::usrp::multi_usrpinline
get_tx_lo_export_enabled(const std::string &name=ALL_LOS, const size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_lo_freq(const std::string &name, const size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_lo_freq_range(const std::string &name, const size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_lo_names(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_lo_source(const std::string &name=ALL_LOS, const size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_lo_sources(const std::string &name=ALL_LOS, const size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_num_channels(void)=0uhd::usrp::multi_usrppure virtual
get_tx_power_range(const size_t chan)=0uhd::usrp::multi_usrppure virtual
get_tx_power_reference(const size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_rate(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_rates(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_sensor(const std::string &name, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_sensor_names(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_stream(const stream_args_t &args)=0uhd::usrp::multi_usrppure virtual
get_tx_subdev_name(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_tx_subdev_spec(size_t mboard=0)=0uhd::usrp::multi_usrppure virtual
get_user_settings_iface(const size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_usrp_rx_info(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
get_usrp_tx_info(size_t chan=0)=0uhd::usrp::multi_usrppure virtual
has_rx_power_reference(const size_t chan=0)=0uhd::usrp::multi_usrppure virtual
has_tx_power_reference(const size_t chan=0)=0uhd::usrp::multi_usrppure virtual
issue_stream_cmd(const stream_cmd_t &stream_cmd, size_t chan=ALL_CHANS)=0uhd::usrp::multi_usrppure virtual
make(const device_addr_t &dev_addr)uhd::usrp::multi_usrpstatic
set_clock_source(const std::string &source, const size_t mboard=ALL_MBOARDS)=0uhd::usrp::multi_usrppure virtual
set_clock_source_out(const bool enb, const size_t mboard=ALL_MBOARDS)=0uhd::usrp::multi_usrppure virtual
set_command_time(const uhd::time_spec_t &time_spec, size_t mboard=ALL_MBOARDS)=0uhd::usrp::multi_usrppure virtual
set_gpio_attr(const std::string &bank, const std::string &attr, const uint32_t value, const uint32_t mask=0xffffffff, const size_t mboard=0)=0uhd::usrp::multi_usrppure virtual
set_gpio_src(const std::string &bank, const std::vector< std::string > &src, const size_t mboard=0)=0uhd::usrp::multi_usrppure virtual
set_master_clock_rate(double rate, size_t mboard=ALL_MBOARDS)=0uhd::usrp::multi_usrppure virtual
set_normalized_rx_gain(double gain, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
set_normalized_tx_gain(double gain, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
set_rx_agc(bool enable, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
set_rx_antenna(const std::string &ant, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
set_rx_bandwidth(double bandwidth, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
set_rx_dc_offset(const bool enb, size_t chan=ALL_CHANS)=0uhd::usrp::multi_usrppure virtual
set_rx_dc_offset(const std::complex< double > &offset, size_t chan=ALL_CHANS)=0uhd::usrp::multi_usrppure virtual
set_rx_filter(const std::string &name, uhd::filter_info_base::sptr filter, const size_t chan)=0uhd::usrp::multi_usrppure virtual
set_rx_freq(const tune_request_t &tune_request, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
set_rx_gain(double gain, const std::string &name, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
set_rx_gain(double gain, size_t chan=0)uhd::usrp::multi_usrpinline
set_rx_gain_profile(const std::string &profile, const size_t chan=0)=0uhd::usrp::multi_usrppure virtual
set_rx_iq_balance(const bool enb, size_t chan)=0uhd::usrp::multi_usrppure virtual
set_rx_iq_balance(const std::complex< double > &correction, size_t chan=ALL_CHANS)=0uhd::usrp::multi_usrppure virtual
set_rx_lo_export_enabled(bool enabled, const std::string &name=ALL_LOS, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
set_rx_lo_freq(double freq, const std::string &name, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
set_rx_lo_source(const std::string &src, const std::string &name=ALL_LOS, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
set_rx_power_reference(const double power_dbm, const size_t chan=0)=0uhd::usrp::multi_usrppure virtual
set_rx_rate(double rate, size_t chan=ALL_CHANS)=0uhd::usrp::multi_usrppure virtual
set_rx_spp(const size_t spp, const size_t chan=ALL_CHANS)=0uhd::usrp::multi_usrppure virtual
set_rx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard=ALL_MBOARDS)=0uhd::usrp::multi_usrppure virtual
set_sync_source(const std::string &clock_source, const std::string &time_source, const size_t mboard=ALL_MBOARDS)=0uhd::usrp::multi_usrppure virtual
set_sync_source(const device_addr_t &sync_source, const size_t mboard=ALL_MBOARDS)=0uhd::usrp::multi_usrppure virtual
set_time_next_pps(const time_spec_t &time_spec, size_t mboard=ALL_MBOARDS)=0uhd::usrp::multi_usrppure virtual
set_time_now(const time_spec_t &time_spec, size_t mboard=ALL_MBOARDS)=0uhd::usrp::multi_usrppure virtual
set_time_source(const std::string &source, const size_t mboard=ALL_MBOARDS)=0uhd::usrp::multi_usrppure virtual
set_time_source_out(const bool enb, const size_t mboard=ALL_MBOARDS)=0uhd::usrp::multi_usrppure virtual
set_time_unknown_pps(const time_spec_t &time_spec)=0uhd::usrp::multi_usrppure virtual
set_tx_antenna(const std::string &ant, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
set_tx_bandwidth(double bandwidth, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
set_tx_dc_offset(const std::complex< double > &offset, size_t chan=ALL_CHANS)=0uhd::usrp::multi_usrppure virtual
set_tx_filter(const std::string &name, uhd::filter_info_base::sptr filter, const size_t chan)=0uhd::usrp::multi_usrppure virtual
set_tx_freq(const tune_request_t &tune_request, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
set_tx_gain(double gain, const std::string &name, size_t chan=0)=0uhd::usrp::multi_usrppure virtual
set_tx_gain(double gain, size_t chan=0)uhd::usrp::multi_usrpinline
set_tx_gain_profile(const std::string &profile, const size_t chan=0)=0uhd::usrp::multi_usrppure virtual
set_tx_iq_balance(const std::complex< double > &correction, size_t chan=ALL_CHANS)=0uhd::usrp::multi_usrppure virtual
set_tx_lo_export_enabled(const bool enabled, const std::string &name=ALL_LOS, const size_t chan=0)=0uhd::usrp::multi_usrppure virtual
set_tx_lo_freq(const double freq, const std::string &name, const size_t chan=0)=0uhd::usrp::multi_usrppure virtual
set_tx_lo_source(const std::string &src, const std::string &name=ALL_LOS, const size_t chan=0)=0uhd::usrp::multi_usrppure virtual
set_tx_power_reference(const double power_dbm, const size_t chan=0)=0uhd::usrp::multi_usrppure virtual
set_tx_rate(double rate, size_t chan=ALL_CHANS)=0uhd::usrp::multi_usrppure virtual
set_tx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard=ALL_MBOARDS)=0uhd::usrp::multi_usrppure virtual
set_user_register(const uint8_t addr, const uint32_t data, size_t mboard=ALL_MBOARDS)=0uhd::usrp::multi_usrppure virtual
sptr typedefuhd::usrp::multi_usrp
~multi_usrp(void)=0uhd::usrp::multi_usrppure virtual
