   18 namespace uhd {
namespace experts {
   56     template <
typename data_t>
   58         const std::string& name,
   59         const data_t& init_val,
   91     template <
typename data_t>
   95         const std::string& name,
   96         const data_t& init_val,
  107         container->add_data_node(node_ptr, mode);
  123     template <
typename data_t>
  127         const data_t& init_val,
  130         return add_prop_node(container, subtree, path, path, init_val, mode);
  151     template <
typename data_t>
  155         const std::string& desired_name,
  156         const std::string& coerced_name,
  157         const data_t& init_val,
  160         bool auto_resolve_desired =
  162         bool auto_resolve_coerced =
  177         container->add_data_node(desired_node_ptr,
  179         container->add_data_node(coerced_node_ptr,
  197     template <
typename data_t>
  201         const data_t& init_val,
  204         return add_dual_prop_node(container,
  222     template <
typename worker_t>
  225         container->add_worker(
new worker_t());
  242     template <
typename worker_t,
typename arg1_t>
  246         container->add_worker(
new worker_t(arg1));
  249     template <
typename worker_t,
typename arg1_t,
typename arg2_t>
  253         container->add_worker(
new worker_t(arg1, arg2));
  256     template <
typename worker_t,
typename arg1_t,
typename arg2_t,
typename arg3_t>
  262         container->add_worker(
new worker_t(arg1, arg2, arg3));
  265     template <
typename worker_t,
  276         container->add_worker(
new worker_t(arg1, arg2, arg3, arg4));
  279     template <
typename worker_t,
  292         container->add_worker(
new worker_t(arg1, arg2, arg3, arg4, arg5));
  295     template <
typename worker_t,
  310         container->add_worker(
new worker_t(arg1, arg2, arg3, arg4, arg5, arg6));
  313     template <
typename worker_t,
  330         container->add_worker(
new worker_t(arg1, arg2, arg3, arg4, arg5, arg6, arg7));
  333     template <
typename worker_t,
  352         container->add_worker(
  353             new worker_t(arg1, arg2, arg3, arg4, arg5, arg6, arg7, arg8));
Definition: expert_factory.hpp:31
virtual property< T > & add_desired_subscriber(const subscriber_type &subscriber)=0
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1, arg2_t const &arg2, arg3_t const &arg3)
Definition: expert_factory.hpp:257
static property< data_t > & add_dual_prop_node(expert_container::sptr container, property_tree::sptr subtree, const fs_path &path, const std::string &desired_name, const std::string &coerced_name, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
Definition: expert_factory.hpp:152
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1, arg2_t const &arg2, arg3_t const &arg3, arg4_t const &arg4)
Definition: expert_factory.hpp:270
std::shared_ptr< expert_container > sptr
Definition: expert_container.hpp:28
virtual property< T > & add_coerced_subscriber(const subscriber_type &subscriber)=0
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1, arg2_t const &arg2, arg3_t const &arg3, arg4_t const &arg4, arg5_t const &arg5, arg6_t const &arg6)
Definition: expert_factory.hpp:302
static property< data_t > & add_prop_node(expert_container::sptr container, property_tree::sptr subtree, const fs_path &path, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
Definition: expert_factory.hpp:124
virtual property< T > & set_publisher(const publisher_type &publisher)=0
static void add_data_node(expert_container::sptr container, const std::string &name, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
Definition: expert_factory.hpp:57
@ AUTO_RESOLVE_OFF
Definition: expert_container.hpp:19
Definition: config.h:87
Definition: property_tree.hpp:222
@ AUTO_RESOLVE_ON_READ
Definition: expert_container.hpp:20
static property< data_t > & add_prop_node(expert_container::sptr container, property_tree::sptr subtree, const fs_path &path, const std::string &name, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
Definition: expert_factory.hpp:92
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1)
Definition: expert_factory.hpp:243
virtual property< T > & set(const T &value)=0
Definition: build_info.hpp:12
Definition: expert_nodes.hpp:127
Definition: property_tree.hpp:204
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1, arg2_t const &arg2)
Definition: expert_factory.hpp:250
Definition: property_tree.hpp:77
static void add_worker_node(expert_container::sptr container)
Definition: expert_factory.hpp:223
auto_resolve_mode_t
Definition: expert_container.hpp:18
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1, arg2_t const &arg2, arg3_t const &arg3, arg4_t const &arg4, arg5_t const &arg5, arg6_t const &arg6, arg7_t const &arg7)
Definition: expert_factory.hpp:321
@ AUTO_RESOLVE_ON_WRITE
Definition: expert_container.hpp:21
virtual property< T > & set_coerced(const T &value)=0
@ AUTO_COERCE
Definition: property_tree.hpp:224
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1, arg2_t const &arg2, arg3_t const &arg3, arg4_t const &arg4, arg5_t const &arg5)
Definition: expert_factory.hpp:285
static property< data_t > & add_dual_prop_node(expert_container::sptr container, property_tree::sptr subtree, const fs_path &path, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
Definition: expert_factory.hpp:198
@ AUTO_RESOLVE_ON_READ_WRITE
Definition: expert_container.hpp:22
@ MANUAL_COERCE
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1, arg2_t const &arg2, arg3_t const &arg3, arg4_t const &arg4, arg5_t const &arg5, arg6_t const &arg6, arg7_t const &arg7, arg7_t const &arg8)
Definition: expert_factory.hpp:342
