12 namespace uhd {
namespace rfnoc {
   19 static const std::string PROP_KEY_MAGNITUDE    =
"magnitude";
   20 static const std::string PROP_KEY_DIRECTION    =
"direction";
   21 static const std::string PROP_KEY_LENGTH       =
"length";
   22 static const std::string PROP_KEY_FFT_SCALING  =
"fft_scaling";
   23 static const std::string PROP_KEY_SHIFT_CONFIG =
"shift_config";
   46     static const uint32_t REG_RESET_ADDR;
   47     static const uint32_t REG_LENGTH_LOG2_ADDR;
   48     static const uint32_t REG_MAGNITUDE_OUT_ADDR;
   49     static const uint32_t REG_DIRECTION_ADDR;
   50     static const uint32_t REG_SCALING_ADDR;
   51     static const uint32_t REG_SHIFT_CONFIG_ADDR;
   60     virtual
void set_direction(const
fft_direction direction) = 0;
   81     virtual
void set_magnitude(const
fft_magnitude magnitude) = 0;
  112     virtual
fft_shift get_shift_config() const = 0;
  124     virtual
void set_scaling(const uint16_t scaling) = 0;
  132     virtual uint16_t get_scaling() const = 0;
  142     virtual
void set_length(const
size_t length) = 0;
  150     virtual
size_t get_length() const = 0;
