   13 #include <boost/scoped_array.hpp>
   26     typedef std::shared_ptr<filter_info_base>
sptr;
   27     enum filter_type { ANALOG_LOW_PASS, ANALOG_BAND_PASS, DIGITAL_I16, DIGITAL_FIR_I16 };
   30         : _type(type), _bypass(bypass), _position_index(position_index)
   50     virtual std::string to_pp_string();
   62     std::string _analog_type;
   65     typedef std::shared_ptr<analog_filter_base>
sptr;
   68         size_t position_index,
   69         const std::string& analog_type)
   80     std::string to_pp_string()
override;
   89     typedef std::shared_ptr<analog_filter_lp>
sptr;
   92         size_t position_index,
   93         const std::string& analog_type,
  118     std::string to_pp_string()
override;
  121 template <
typename tap_t>
  133     typedef std::shared_ptr<digital_filter_base>
sptr;
  136         size_t position_index,
  138         uint32_t interpolation,
  140         tap_t tap_full_scale,
  141         uint32_t max_num_taps,
  142         const std::vector<tap_t>& taps)
  145         , _interpolation(interpolation)
  146         , _decimation(decimation)
  147         , _tap_full_scale(tap_full_scale)
  148         , _max_num_taps(max_num_taps)
  156         return (_bypass ? _rate : (_rate / _decimation * _interpolation));
  166         return _interpolation;
  176         return _tap_full_scale;
  186         std::ostringstream os;
  188            <<
"\tinput rate: " << _rate << std::endl
  189            <<
"\tinterpolation: " << _interpolation << std::endl
  190            <<
"\tdecimation: " << _decimation << std::endl
  191            <<
"\tfull-scale: " << _tap_full_scale << std::endl
  192            <<
"\tmax num taps: " << _max_num_taps << std::endl
  193            <<
"\ttaps: " << std::endl;
  196         for (
size_t i = 0; i < _taps.size(); i++) {
  197             os <<
"(tap " << i <<
": " << _taps[i] <<
  198             if (((i % 10) == 0) && (i != 0)) {
  199                 os << std::endl <<
"\t\t";
  203         return std::string(os.str());
  207 template <
typename tap_t>
  211     typedef std::shared_ptr<digital_filter_fir<tap_t>>
sptr;
  215         size_t position_index,
  217         uint32_t interpolation,
  220         uint32_t max_num_taps,
  221         const std::vector<tap_t>& taps)
  237         std::size_t num_taps = taps.size();
  238         if (num_taps < this->_max_num_taps) {
  240                                              "coefficients. Appending zeros";
  241             std::vector<tap_t> coeffs;
  242             for (
size_t i = 0; i < this->_max_num_taps; i++) {
  244                     coeffs.push_back(taps[i]);
  249             this->_taps = coeffs;
filter_type
Definition: filters.hpp:27
digital_filter_base(filter_type type, bool bypass, size_t position_index, double rate, uint32_t interpolation, uint32_t decimation, tap_t tap_full_scale, uint32_t max_num_taps, const std::vector< tap_t > &taps)
Definition: filters.hpp:134
UHD_INLINE filter_type get_type()
Definition: filters.hpp:40
UHD_INLINE double get_input_rate()
Definition: filters.hpp:159
bool _bypass
Definition: filters.hpp:54
UHD_INLINE void set_cutoff(const double cutoff)
Definition: filters.hpp:113
Definition: filters.hpp:208
Definition: filters.hpp:122
std::shared_ptr< analog_filter_base > sptr
Definition: filters.hpp:65
filter_info_base(filter_type type, bool bypass, size_t position_index)
Definition: filters.hpp:29
uint32_t _decimation
Definition: filters.hpp:127
analog_filter_base(filter_type type, bool bypass, size_t position_index, const std::string &analog_type)
Definition: filters.hpp:66
virtual ~filter_info_base()
Definition: filters.hpp:45
#define UHD_INLINE
Definition: config.h:65
std::string to_pp_string() override
Definition: filters.hpp:184
Definition: filters.hpp:60
Definition: config.h:87
virtual UHD_INLINE bool is_bypassed()
Definition: filters.hpp:35
std::shared_ptr< filter_info_base > sptr
Definition: filters.hpp:26
UHD_INLINE uint32_t get_interpolation()
Definition: filters.hpp:164
Definition: build_info.hpp:12
UHD_INLINE uint32_t get_decimation()
Definition: filters.hpp:169
tap_t _tap_full_scale
Definition: filters.hpp:128
UHD_INLINE double get_rolloff()
Definition: filters.hpp:108
double _rate
Definition: filters.hpp:125
digital_filter_fir(filter_info_base::filter_type type, bool bypass, size_t position_index, double rate, uint32_t interpolation, uint32_t decimation, tap_t tap_bit_width, uint32_t max_num_taps, const std::vector< tap_t > &taps)
Definition: filters.hpp:213
Definition: filters.hpp:83
uint32_t _interpolation
Definition: filters.hpp:126
UHD_INLINE double get_cutoff()
Definition: filters.hpp:103
std::vector< tap_t > _taps
Definition: filters.hpp:130
#define UHD_LOGGER_WARNING(component)
Definition: log.hpp:272
UHD_INLINE uint32_t get_tap_full_scale()
Definition: filters.hpp:174
std::shared_ptr< digital_filter_base > sptr
Definition: filters.hpp:133
size_t _position_index
Definition: filters.hpp:55
void set_taps(const std::vector< tap_t > &taps)
Definition: filters.hpp:235
const UHD_INLINE std::string & get_analog_type()
Definition: filters.hpp:75
UHD_INLINE double get_output_rate()
Definition: filters.hpp:154
uint32_t _max_num_taps
Definition: filters.hpp:129
std::shared_ptr< digital_filter_fir< tap_t > > sptr
Definition: filters.hpp:211
UHD_API_HEADER std::ostream & operator<<(std::ostream &os, filter_info_base &f)
std::shared_ptr< analog_filter_lp > sptr
Definition: filters.hpp:89
filter_type _type
Definition: filters.hpp:53
#define UHD_API_HEADER
Definition: config.h:88
analog_filter_lp(filter_type type, bool bypass, size_t position_index, const std::string &analog_type, double cutoff, double rolloff)
Definition: filters.hpp:90
UHD_INLINE std::vector< tap_t > & get_taps()
Definition: filters.hpp:179
