Writing a Top-level Simulation Module
The top-level simulation module will instantiate the DUT and implement self-checking behavior. Testbenches can be written in any language (SystemVerilog, Verilog, VHDL) but to take advantage of our repository of simulation libraries, it is recommended that SystemVerilog be used.
An example testbench is shown below. This example is for an RFNoC block. If creating a testbench for RFNoC, it is recommended to use the RFNoC ModTool to generate a testbench template for your RFNoC block.
See Simulation Libraries for documentation on the simulation libraries used in this example.
// Copyright 2020 Ettus Research, A National Instruments Company
// SPDX-License-Identifier: LGPL-3.0-or-later
// Module: rfnoc_block_example_tb
// Description: An example top-level testbench
`default_nettype none
module rfnoc_block_example_tb;
  `include "test_exec.svh"
  import PkgTestExec::*;
  import PkgChdrUtils::*;
  import PkgRfnocBlockCtrlBfm::*;
  // Testbench Configuration
  localparam [ 9:0] THIS_PORTID     = 10'h123;
  localparam int    CHDR_W          = 64;
  localparam int    ITEM_W          = 32;
  localparam int    NUM_PORTS_I     = 1;
  localparam int    NUM_PORTS_O     = 1;
  localparam int    MTU             = 13;
  localparam int    SPP             = 64;
  localparam int    PKT_SIZE_BYTES  = SPP * (ITEM_W/8);
  localparam int    STALL_PROB      = 25;      // Default BFM stall probability
  localparam real   CHDR_CLK_PER    = 5.0;     // 200 MHz
  localparam real   CTRL_CLK_PER    = 25.0;    // 40 MHz
  // Clocks and Resets
  bit rfnoc_chdr_clk;
  bit rfnoc_ctrl_clk;
  sim_clock_gen #(CHDR_CLK_PER) rfnoc_chdr_clk_gen (.clk(rfnoc_chdr_clk), .rst());
  sim_clock_gen #(CTRL_CLK_PER) rfnoc_ctrl_clk_gen (.clk(rfnoc_ctrl_clk), .rst());
  // Bus Functional Models
  // Backend Interface
  RfnocBackendIf backend (rfnoc_chdr_clk, rfnoc_ctrl_clk);
  // AXIS-Ctrl Interface
  AxiStreamIf #(32) m_ctrl (rfnoc_ctrl_clk, 1'b0);
  AxiStreamIf #(32) s_ctrl (rfnoc_ctrl_clk, 1'b0);
  // AXIS-CHDR Interfaces
  AxiStreamIf #(CHDR_W) m_chdr [NUM_PORTS_I] (rfnoc_chdr_clk, 1'b0);
  AxiStreamIf #(CHDR_W) s_chdr [NUM_PORTS_O] (rfnoc_chdr_clk, 1'b0);
  // Block Controller BFM
  RfnocBlockCtrlBfm #(CHDR_W, ITEM_W) blk_ctrl = new(backend, m_ctrl, s_ctrl);
  // CHDR word and item/sample data types
  typedef ChdrData #(CHDR_W, ITEM_W)::chdr_word_t chdr_word_t;
  typedef ChdrData #(CHDR_W, ITEM_W)::item_t      item_t;
  // Connect block controller to BFMs
  for (genvar i = 0; i < NUM_PORTS_I; i++) begin : gen_bfm_input_connections
    initial begin
      blk_ctrl.connect_master_data_port(i, m_chdr[i], PKT_SIZE_BYTES);
      blk_ctrl.set_master_stall_prob(i, STALL_PROB);
    end
  end
  for (genvar i = 0; i < NUM_PORTS_O; i++) begin : gen_bfm_output_connections
    initial begin
      blk_ctrl.connect_slave_data_port(i, s_chdr[i]);
      blk_ctrl.set_slave_stall_prob(i, STALL_PROB);
    end
  end
  // Device Under Test (DUT)
  // DUT Slave (Input) Port Signals
  logic [CHDR_W*NUM_PORTS_I-1:0] s_rfnoc_chdr_tdata;
  logic [       NUM_PORTS_I-1:0] s_rfnoc_chdr_tlast;
  logic [       NUM_PORTS_I-1:0] s_rfnoc_chdr_tvalid;
  logic [       NUM_PORTS_I-1:0] s_rfnoc_chdr_tready;
  // DUT Master (Output) Port Signals
  logic [CHDR_W*NUM_PORTS_O-1:0] m_rfnoc_chdr_tdata;
  logic [       NUM_PORTS_O-1:0] m_rfnoc_chdr_tlast;
  logic [       NUM_PORTS_O-1:0] m_rfnoc_chdr_tvalid;
  logic [       NUM_PORTS_O-1:0] m_rfnoc_chdr_tready;
  // Map the array of BFMs to a flat vector for the DUT connections
  for (genvar i = 0; i < NUM_PORTS_I; i++) begin : gen_dut_input_connections
    // Connect BFM master to DUT slave port
    assign s_rfnoc_chdr_tdata[CHDR_W*i+:CHDR_W] = m_chdr[i].tdata;
    assign s_rfnoc_chdr_tlast[i]                = m_chdr[i].tlast;
    assign s_rfnoc_chdr_tvalid[i]               = m_chdr[i].tvalid;
    assign m_chdr[i].tready                     = s_rfnoc_chdr_tready[i];
  end
  for (genvar i = 0; i < NUM_PORTS_O; i++) begin : gen_dut_output_connections
    // Connect BFM slave to DUT master port
    assign s_chdr[i].tdata        = m_rfnoc_chdr_tdata[CHDR_W*i+:CHDR_W];
    assign s_chdr[i].tlast        = m_rfnoc_chdr_tlast[i];
    assign s_chdr[i].tvalid       = m_rfnoc_chdr_tvalid[i];
    assign m_rfnoc_chdr_tready[i] = s_chdr[i].tready;
  end
  rfnoc_block_example #(
    .THIS_PORTID         (THIS_PORTID),
    .CHDR_W              (CHDR_W),
    .MTU                 (MTU)
  ) dut (
    .rfnoc_chdr_clk      (rfnoc_chdr_clk),
    .rfnoc_ctrl_clk      (rfnoc_ctrl_clk),
    .rfnoc_core_config   (backend.cfg),
    .rfnoc_core_status   (backend.sts),
    .s_rfnoc_chdr_tdata  (s_rfnoc_chdr_tdata),
    .s_rfnoc_chdr_tlast  (s_rfnoc_chdr_tlast),
    .s_rfnoc_chdr_tvalid (s_rfnoc_chdr_tvalid),
    .s_rfnoc_chdr_tready (s_rfnoc_chdr_tready),
    .m_rfnoc_chdr_tdata  (m_rfnoc_chdr_tdata),
    .m_rfnoc_chdr_tlast  (m_rfnoc_chdr_tlast),
    .m_rfnoc_chdr_tvalid (m_rfnoc_chdr_tvalid),
    .m_rfnoc_chdr_tready (m_rfnoc_chdr_tready),
    .s_rfnoc_ctrl_tdata  (m_ctrl.tdata),
    .s_rfnoc_ctrl_tlast  (m_ctrl.tlast),
    .s_rfnoc_ctrl_tvalid (m_ctrl.tvalid),
    .s_rfnoc_ctrl_tready (m_ctrl.tready),
    .m_rfnoc_ctrl_tdata  (s_ctrl.tdata),
    .m_rfnoc_ctrl_tlast  (s_ctrl.tlast),
    .m_rfnoc_ctrl_tvalid (s_ctrl.tvalid),
    .m_rfnoc_ctrl_tready (s_ctrl.tready)
  // Main Test Process
  initial begin : tb_main
    // Initialize the test exec object for this testbench
    test.start_tb("example");
    // Start the BFMs running
    //blk_ctrl.run();
    // Reset
    test.start_test("Flush block then reset it", 10us);
    //blk_ctrl.flush_and_reset();
    test.end_test();
    // Test Sequences
    test.start_test("This is an example test", 10us);
    // < Add test code here >
    test.end_test();
    // Finish Up
    // Display final statistics and results
    test.end_tb();
  end : tb_main
endmodule : rfnoc_block_example_tb
`default_nettype wire
