Python API
UHD supports a Python API, in case the C++ or C APIs are not the right solution for your application.
Installing the Python API
In order to install the Python API when building UHD from source, make sure you have the CMake variable ENABLE_PYTHON_API set to ON (e.g., by running cmake -DENABLE_PYTHON_API=ON). UHD requires Python header files in order to compile the Python API. On most Linux systems, there are packages called "python3-dev" or "python3-devel" that provide that functionality. On Windows, these headers always get installed when using the binary installers provided on https://www.python.org/downloads/windows/.
If CMake can't find the Python headers or library, specify the PYTHON_INCLUDE_DIR and/or PYTHON_LIBRARY CMake variables manually.
Note that since UHD version 4.0.0.0, Python 2 is no longer supported.
Installing on Windows
Static linking is unsupported on Windows. Otherwise, compiling the Python API on Windows is no different from other operating systems.
Note that you may have to set the PYTHONPATH environment variable to ensure that Python is able to find the UHD package. For example, if the UHD install base path is C:\Program Files (x86)\UHD:
set PYTHONPATH=%PYTHONPATH%;C:\Program Files (x86)\UHD\lib\site-packages
Python 3.8 Note: If you receive an error similar to this when running import uhd in Python 3.8 and above on Windows:
ImportError: DLL load failed while importing libpyuhd: The specified module could not be found.
this indicates a problem finding one or more of the DLLs that the UHD Python module depends on to load correctly.
Python 3.8 includes a change to the paths Windows searches when attempting to find a module's dependent DLLs. To ensure that Python is able to find and load the DLLs required to import the UHD module, it is advised that the uhd.dll and libusb-1.0.dll (if UHD was build with USB support) DLLs be copied to one of the following directories:
  • The %windows%\system32 directory
  • The directory where the Python UHD package is installed (by default, this is C:\Program Files (x86)\UHD\lib\site-packages\uhd
  • The directory from which the Python executable is run
  • Paths added to the import extension module DLL search path via Python's os.add_dll_directory function
Advanced Usage Notes
UHD uses the PyBind11 library to generate its Python bindings. UHD ships its own copy of PyBind11, in order to facilitate the access to that library, as it is not packaged for many operating systems, but also to lock down its version. For the purpose of experimentation, it is, however possible to replace the version of PyBind11 shipped with UHD by overriding the PYBIND11_INCLUDE_DIR CMake variable.
Using the Python API
The Python API mirrors the C++ API, so the C++ reference manual can be used to understand the behaviour of the Python API as well.
Names in the Python API have been modified to follow a PEP8-compatible naming convention, for example, uhd::usrp::multi_usrp in C++ corresponds to uhd.usrp.MultiUSRP in Python (this makes UHD/Python code implicitly compatible with most linters, but it also has the side-effect of hiding symbols that get imported from the C++ domain). The following two snippets are equivalent. First the C++ version:
auto usrp = uhd::usrp::multi_usrp::make("type=b200");
usrp->set_rx_freq(100e6);
Now the Python version:
import uhd
usrp = uhd.usrp.MultiUSRP("type=b200")
usrp.set_rx_freq(100e6)
Not all API calls from the C++ API are also supported in the Python API, and the Python API has some additional functions that are not available in C++, but for the most part, the uhd::usrp::multi_usrp API is identical.
One-off transmit/receive applications
A common type of Python-based SDR applications are those which produce or consume a limited number of samples. For example, an application could receive a second's worth of samples, then do offline processing, print the result, and exit. For this case, convenience API calls were added to the Python API. The following snippet is an example of how to store 1 second of samples acquired at 1 Msps:
import uhd
def recv_to_file():
"""RX samples and write to file"""
num_samps = 1e6
if not isinstance(args.channels, list):
args.channels = [args.channels]
samps = usrp.recv_num_samps(
1e6, # Number of samples
2.4e9, # Frequency in Hz
1e6, # Sampling rate
[0], # Receive on channel 0
80, # 80 dB of RX gain
samps.tofile('samples.dat')
This kind of API is particularly useful in combination with Jupyter Notebooks or similar interactive environments.
Thread Safety and the Python Global Interpreter Lock
From the Python wiki page on the GIL:
In CPython, the global interpreter lock, or GIL, is a mutex that protects access to Python objects, preventing multiple threads from executing Python bytecodes at once.
During some performance-critical function calls, the UHD Python API releases the GIL, during which Python objects have their contents modified. The functions calls which do so are uhd::rx_streamer::recv, uhd::tx_streamer::send, and uhd::tx_streamer::recv_async_msg. To be clear, the functions listed here violate the expected contract set out by the GIL by accessing Python objects (from C++) without holding the GIL. This is necessary to achieve rates similar to what the C++ API can provide.
To this end, users must ensure that the Python objects accessed by the listed functions are handled with care. In simple, single threaded applications, this won't require any extra work. However, in more complicated and/or multi- threaded applications, steps must be taken to avoid thread-unsafe behavior. For example, if an application needs to call recv() in one thread, and access the sample buffer from another thread, a synchronization method (ie. a mutex) must be used to safeguard access to that buffer.
multi_usrp.hpp
