12 namespace uhd {
namespace rfnoc {
  116     static const uint16_t MINOR_COMPAT;
  117     static const uint16_t MAJOR_COMPAT;
  119     static const uint32_t REPLAY_ADDR_W;
  120     static const uint32_t REPLAY_BLOCK_OFFSET;
  122     static const uint32_t REG_COMPAT_ADDR;
  123     static const uint32_t REG_MEM_SIZE_ADDR;
  124     static const uint32_t REG_REC_RESTART_ADDR;
  125     static const uint32_t REG_REC_BASE_ADDR_LO_ADDR;
  126     static const uint32_t REG_REC_BASE_ADDR_HI_ADDR;
  127     static const uint32_t REG_REC_BUFFER_SIZE_LO_ADDR;
  128     static const uint32_t REG_REC_BUFFER_SIZE_HI_ADDR;
  129     static const uint32_t REG_REC_FULLNESS_LO_ADDR;
  130     static const uint32_t REG_REC_FULLNESS_HI_ADDR;
  131     static const uint32_t REG_PLAY_BASE_ADDR_LO_ADDR;
  132     static const uint32_t REG_PLAY_BASE_ADDR_HI_ADDR;
  133     static const uint32_t REG_PLAY_BUFFER_SIZE_LO_ADDR;
  134     static const uint32_t REG_PLAY_BUFFER_SIZE_HI_ADDR;
  135     static const uint32_t REG_PLAY_CMD_NUM_WORDS_LO_ADDR;
  136     static const uint32_t REG_PLAY_CMD_NUM_WORDS_HI_ADDR;
  137     static const uint32_t REG_PLAY_CMD_TIME_LO_ADDR;
  138     static const uint32_t REG_PLAY_CMD_TIME_HI_ADDR;
  139     static const uint32_t REG_PLAY_CMD_ADDR;
  140     static const uint32_t REG_PLAY_WORDS_PER_PKT_ADDR;
  141     static const uint32_t REG_PLAY_ITEM_SIZE_ADDR;
  142     static const uint32_t REG_REC_POS_LO_ADDR;
  143     static const uint32_t REG_REC_POS_HI_ADDR;
  144     static const uint32_t REG_PLAY_POS_LO_ADDR;
  145     static const uint32_t REG_PLAY_POS_HI_ADDR;
  146     static const uint32_t REG_PLAY_CMD_FIFO_SPACE_ADDR;
  148     static const uint32_t PLAY_CMD_STOP;
  149     static const uint32_t PLAY_CMD_FINITE;
  150     static const uint32_t PLAY_CMD_CONTINUOUS;
  172         const uint64_t offset, const uint64_t size, const
size_t port = 0) = 0;
  180     virtual
void record_restart(const
  222     virtual
void play(const uint64_t offset,
  224         const
size_t port                = 0,
  226         const
bool repeat                = false) = 0;
  235     virtual
void stop(const
  244     virtual uint64_t get_mem_size() const = 0;
  250     virtual uint64_t get_word_size() const = 0;
  260     virtual uint64_t get_record_offset(const
size_t port = 0) const = 0;
  267     virtual uint64_t get_record_size(const
  277     virtual uint64_t get_record_fullness(const
  284     virtual uint64_t get_record_position(const
  291     virtual
io_type_t get_record_type(const
  298     virtual
size_t get_record_item_size(const
  313     virtual
bool get_record_async_metadata(
  324     virtual uint64_t get_play_offset(const
  331     virtual uint64_t get_play_size(const
  338     virtual uint64_t get_play_position(const
  345     virtual uint32_t get_max_items_per_packet(const
  354     virtual uint32_t get_max_packet_size(const
  361     virtual
io_type_t get_play_type(const
  368     virtual
size_t get_play_item_size(const
  383     virtual
bool get_play_async_metadata(
  396     virtual
void set_record_type(const
io_type_t type, const
  415     virtual
void config_play(
  416         const uint64_t offset, const uint64_t size, const
  425     virtual
void set_play_type(const
  436     virtual
void set_max_items_per_packet(const uint32_t ipp, const
  446     virtual
void set_max_packet_size(const uint32_t size, const
  464     virtual
void issue_stream_cmd(
