   18 #include <boost/units/detail/utility.hpp>
   22 namespace uhd {
namespace rfnoc {
   38     using sptr = std::shared_ptr<rfnoc_graph>;
   77     virtual std::vector<block_id_t> find_blocks(
   78         const std::string& block_id_hint)
const = 0;
   83     std::vector<block_id_t>
find_blocks(
 const
   85         std::vector<block_id_t> all_block_ids = find_blocks(block_id_hint);
   86         std::vector<block_id_t> filt_block_ids;
   87         for (
size_t i = 0; i < all_block_ids.size(); i++) {
   88             if (has_block<T>(all_block_ids[i])) {
   89                 filt_block_ids.push_back(all_block_ids[i]);
   92         return filt_block_ids;
  101     virtual bool has_block(
const block_id_t& block_id)
const = 0;
  108     template <
typename T>
  111         return has_block(block_id)
  112                && bool(std::dynamic_pointer_cast<T>(get_block(block_id)));
  139     template <
typename T>
  142         std::shared_ptr<T> blk = std::dynamic_pointer_cast<T>(get_block(block_id));
  147                 std::string(
"This device does not have a block of type ")
  148                 + boost::units::detail::demangle(
typeid(T).name())
  164     virtual bool is_connectable(
const block_id_t& src_blk,
  167         size_t dst_port) = 0;
  188     virtual void connect(
  192         bool is_back_edge =
false) = 0;
  222     virtual void connect(
  241     virtual void disconnect(
  244         size_t dst_port) = 0;
  255     virtual void disconnect(
const std::string& streamer_id) = 0;
  267     virtual void disconnect(
const std::string& streamer_id,
size_t port) = 0;
  278     virtual std::vector<uhd::transport::adapter_id_t> enumerate_adapters_from_src(
  279         const block_id_t& src_blk,
size_t src_port) = 0;
  290     virtual std::vector<uhd::transport::adapter_id_t> enumerate_adapters_to_dst(
  291         const block_id_t& dst_blk,
  302     virtual std::vector<graph_edge_t> enumerate_static_connections()
const = 0;
  311     virtual std::vector<graph_edge_t> enumerate_active_connections() = 0;
  320     virtual void commit() = 0;
  362     virtual size_t get_num_mboards()
const = 0;
  366     virtual std::shared_ptr<mb_controller> get_mb_controller(
  367         const size_t mb_index = 0) = 0;
  389     virtual bool synchronize_devices(
Definition: block_id.hpp:39
std::vector< block_id_t > find_blocks(const std::string &block_id_hint) const
Definition: rfnoc_graph.hpp:83
Definition: exception.hpp:58
string release
Definition: conf.py:29
Definition: stream.hpp:169
std::shared_ptr< tx_streamer > sptr
Definition: stream.hpp:267
std::string to_string() const
Return a string like this: "0/FFT#1" (includes all components, if set)
Definition: config.h:87
Definition: property_tree.hpp:222
bool has_block(const block_id_t &block_id) const
Definition: rfnoc_graph.hpp:109
Definition: device_addr.hpp:37
virtual ~rfnoc_graph()
Definition: rfnoc_graph.hpp:40
Definition: build_info.hpp:12
Definition: time_spec.hpp:28
size_t adapter_id_t
Host transport adapter ID.
Definition: adapter_id.hpp:17
Definition: rfnoc_graph.hpp:32
Definition: stream.hpp:47
std::shared_ptr< rfnoc_graph > sptr
Definition: rfnoc_graph.hpp:38
Definition: noc_block_base.hpp:48
std::shared_ptr< T > get_block(const block_id_t &block_id) const
Definition: rfnoc_graph.hpp:140
