   14 namespace uhd {
namespace rfnoc {
   50     virtual void set_enable(
const bool enable,
const size_t port) = 0;
   60     virtual bool get_enable(
const size_t port)
const = 0;
   70     virtual void set_waveform(
const siggen_waveform type,
   99     virtual void set_amplitude(
const double amplitude,
  111     virtual double get_amplitude(
const size_t port)
const = 0;
  126     virtual void set_constant(
const std::complex<double> constant,
  137     virtual std::complex<double> get_constant(
const size_t port)
const = 0;
  148     virtual void set_sine_phase_increment(
const double phase_inc,
  159     virtual double get_sine_phase_increment(
const size_t port)
const = 0;
  170     virtual void set_samples_per_packet(
const size_t spp,
  180     virtual size_t get_samples_per_packet(
const size_t port)
const = 0;
  193         const double frequency,
const double sample_rate,
const size_t port)
  195         if (sample_rate <= 0.0) {
  198         const double phase_inc = (frequency / sample_rate) * 2.0 * uhd::math::PI;
  199         if (phase_inc < -uhd::math::PI || phase_inc > uhd::math::PI) {
  202         set_sine_phase_increment(phase_inc, port);
Definition: noc_block_base.hpp:42
Definition: exception.hpp:107
Definition: siggen_block_control.hpp:28
Definition: config.h:87
static const uint32_t REG_BLOCK_SIZE
Definition: siggen_block_control.hpp:33
static const uint32_t REG_CARTESIAN_OFFSET
Definition: siggen_block_control.hpp:40
static const uint32_t REG_GAIN_OFFSET
Definition: siggen_block_control.hpp:37
static const uint32_t REG_SPP_OFFSET
Definition: siggen_block_control.hpp:35
Definition: build_info.hpp:12
static const uint32_t REG_ENABLE_OFFSET
Definition: siggen_block_control.hpp:34
siggen_waveform
Definition: siggen_block_control.hpp:16
static const uint32_t REG_PHASE_INC_OFFSET
Definition: siggen_block_control.hpp:39
static const uint32_t REG_CONSTANT_OFFSET
Definition: siggen_block_control.hpp:38
void set_sine_frequency(const double frequency, const double sample_rate, const size_t port)
Definition: siggen_block_control.hpp:192
#define RFNOC_DECLARE_BLOCK(CLASS_NAME)
Definition: noc_block_base.hpp:22
static const uint32_t REG_WAVEFORM_OFFSET
Definition: siggen_block_control.hpp:36
