   14 #include <unordered_map>
   15 #include <boost/tokenizer.hpp>
   38 #define UHD_DEFINE_SOFT_REG_FIELD(name, width, shift) \
   39     static const uhd::soft_reg_field_t name = (((shift & 0xFF) << 8) | (width & 0xFF))
   49     return __builtin_expect(expr,
true);
   59     return __builtin_expect(expr,
false);
   74 namespace soft_reg_field {
   77     return (field & 0xFF);
   82     return ((field >> 8) & 0xFF);
   85 template <
typename data_t>
   88     constexpr data_t ONE      =
static_cast<data_t
>(1);
   89     constexpr data_t ALL_ONES = ~static_cast<data_t>(0);
   94         return ((ONE <<
width(field)) - ONE) <<
shift(field);
   96         return ALL_ONES <<
shift(field);
  107     virtual void flush()                                        = 0;
  116     template <
typename soft_reg_t>
  119         soft_reg_t* ptr =
dynamic_cast<soft_reg_t*
  135 template <
typename reg_data_t,
bool readable,
bool writable>
  139     typedef std::shared_ptr<soft_register_t<reg_data_t, readable, writable>>
sptr;
  164         : _iface(NULL), _wr_addr(addr), _rd_addr(addr), _soft_copy(0), _flush_mode(mode)
  178         if (sync && writable)
  180         if (sync && readable)
  191         _soft_copy = (_soft_copy & ~soft_reg_field::mask<reg_data_t>(field))
  193                            & soft_reg_field::mask<reg_data_t>(field));
  202         return (_soft_copy & soft_reg_field::mask<reg_data_t>(field))
  211         if (writable && _iface) {
  215             if (_flush_mode ==
ALWAYS_FLUSH || _soft_copy.is_dirty()) {
  216                 if (get_bitwidth() <= 32) {
  217                     _iface->poke32(_wr_addr,
static_cast<uint32_t
>(_soft_copy));
  218                 }
else if (get_bitwidth() <= 64) {
  219                     _iface->poke64(_wr_addr,
static_cast<uint64_t
>(_soft_copy));
  222                         "soft_register only supports up to 64 bits.");
  224                 _soft_copy.mark_clean();
  228                 "soft_register is not writable or uninitialized.");
  237         if (readable && _iface) {
  238             if (get_bitwidth() <= 32) {
  239                 _soft_copy =
static_cast<reg_data_t
>(_iface->peek32(_rd_addr));
  240             }
  241                 _soft_copy =
>(_iface->peek64(_rd_addr));
  244                     "soft_register only supports up to 64 bits.");
  246             _soft_copy.mark_clean();
  249                 "soft_register is not readable or uninitialized.");
  276         static const size_t BITS_IN_BYTE = 8;
  277         return sizeof(reg_data_t) * BITS_IN_BYTE;
  308 template <
bool readable,
bool writable>
  313     typedef std::shared_ptr<soft_register_sync_t<reg_data_t, readable, writable>>
sptr;
  318         :
soft_register_t<reg_data_t, readable, writable>(wr_addr, rd_addr, mode)
  325         :
soft_register_t<reg_data_t, readable, writable>(addr, mode), _mutex()
  331         std::lock_guard<std::mutex> lock(_mutex);
  337         std::lock_guard<std::mutex> lock(_mutex);
  343         std::lock_guard<std::mutex> lock(_mutex);
  349         std::lock_guard<std::mutex> lock(_mutex);
  355         std::lock_guard<std::mutex> lock(_mutex);
  361         std::lock_guard<std::mutex> lock(_mutex);
  367         std::lock_guard<std::mutex> lock(_mutex);
  445     typedef std::shared_ptr<soft_regmap_accessor_t>
sptr;
  449     virtual std::vector<std::string> enumerate()
const                = 0;
  450     virtual const std::string& get_name()
const                       = 0;
  485         std::lock_guard<std::mutex> lock(_mutex);
  487             reg->initialize(iface, sync);
  498         std::lock_guard<std::mutex> lock(_mutex);
  511         std::lock_guard<std::mutex> lock(_mutex);
  523         regmap_t::const_iterator iter = _regmap.find(name);
  524         if (iter != _regmap.end()) {
  525             return *(iter->second);
  537         std::vector<std::string> temp;
  538         for (
const regmap_t::value_type& reg : _regmap) {
  539             temp.push_back(_name +
"/" + reg.first);
  554         const std::string& name,
  557         std::lock_guard<std::mutex> lock(_mutex);
  558         if (visible == PUBLIC) {
  560             if (not _regmap.insert(regmap_t::value_type(name, ®)).second) {
  562                     "cannot add two registers with the same name to regmap: " + name);
  565         _reglist.push_back(®);
  569     typedef std::unordered_map<std::string, soft_register_base*> regmap_t;
  570     typedef std::list<soft_register_base*> reglist_t;
  572     const std::string _name;
  588     typedef std::shared_ptr<soft_regmap_db_t>
sptr;
  613         std::lock_guard<std::mutex> lock(_mutex);
  614         _regmaps.push_back(®map);
  622         std::lock_guard<std::mutex> lock(_mutex);
  626             _regmap_dbs.push_back(&db);
  643         std::list<std::string> tokens;
  644         for (
const std::string& node : boost::tokenizer<boost::char_separator<char>>(
  645                  path, boost::char_separator<char>(
  646             tokens.push_back(node);
  648         if ((tokens.size() > 2 && tokens.front() == _name) ||
  649             (tokens.size() > 1 && _name.empty())) {
  652             if (tokens.size() == 2) {
  654                     if (regmap->get_name() == tokens.front()) {
  655                         return regmap->lookup(tokens.back());
  659             }
else if (not _regmap_dbs
  663                 for (
const std::string& node : tokens) {
  664                     newpath += (
"/" + node);
  669                         return db->lookup(newpath.substr(1));
  670                     }
catch (std::exception&) {
  684         std::vector<std::string> paths;
  686             const std::vector<std::string>& regs = regmap->enumerate();
  687             paths.insert(paths.end(), regs.begin(), regs.end());
  690             const std::vector<std::string>& regs = db->enumerate();
  691             paths.insert(paths.end(), regs.begin(), regs.end());
  697     typedef std::list<soft_regmap_accessor_t*> db_t;
  699     const std::string _name;
Definition: soft_register.hpp:86
const UHD_INLINE std::string & get_name() const override
Definition: soft_register.hpp:472
UHD_INLINE size_t get_bitwidth() override
Definition: soft_register.hpp:274
UHD_INLINE size_t shift(const soft_reg_field_t field)
Definition: soft_register.hpp:80
soft_register_sync_t< uint64_t, true, false > soft_reg64_ro_sync_t
Definition: soft_register.hpp:399
virtual ~soft_regmap_accessor_t()
Definition: soft_register.hpp:447
soft_register_t< uint64_t, true, true > soft_reg64_rw_t
Definition: soft_register.hpp:397
Definition: exception.hpp:156
soft_regmap_t(const std::string &name)
Definition: soft_register.hpp:466
~soft_regmap_t() override
Definition: soft_register.hpp:467
UHD_INLINE reg_data_t read(const soft_reg_field_t field)
Definition: soft_register.hpp:365
soft_register_t< uint64_t, true, false > soft_reg64_ro_t
Definition: soft_register.hpp:396
UHD_INLINE bool is_readable() override
Definition: soft_register.hpp:283
virtual void initialize(wb_iface &iface, bool sync=false)=0
Definition: soft_register.hpp:463
UHD_INLINE void flush()
Definition: soft_register.hpp:347
void flush()
Definition: soft_register.hpp:496
std::shared_ptr< soft_regmap_accessor_t > sptr
Definition: soft_register.hpp:445
UHD_INLINE void write(const soft_reg_field_t field, const reg_data_t value)
Definition: soft_register.hpp:256
virtual bool is_readable()=0
Definition: soft_register.hpp:136
UHD_INLINE reg_data_t get(const soft_reg_field_t field)
Definition: soft_register.hpp:200
void refresh()
Definition: soft_register.hpp:509
soft_register_t(wb_iface::wb_addr_type addr, soft_reg_flush_mode_t mode=ALWAYS_FLUSH)
Definition: soft_register.hpp:162
soft_register_t< uint32_t, true, true > soft_reg32_rw_t
Definition: soft_register.hpp:390
@ PUBLIC
Definition: soft_register.hpp:546
Definition: soft_register.hpp:359
soft_regmap_db_t(const std::string &name)
Definition: soft_register.hpp:598
#define UHD_INLINE
Definition: config.h:65
uint32_t soft_reg_field_t
Definition: soft_register.hpp:72
soft_register_sync_t(wb_iface::wb_addr_type addr, soft_reg_flush_mode_t mode=ALWAYS_FLUSH)
Definition: soft_register.hpp:323
Definition: config.h:87
soft_register_sync_t< uint32_t, true, false > soft_reg32_ro_sync_t
Definition: soft_register.hpp:392
virtual ~soft_register_base()
Definition: soft_register.hpp:104
Definition: soft_register.hpp:341
virtual bool is_writable()=0
Definition: soft_register.hpp:585
std::shared_ptr< soft_regmap_db_t > sptr
Definition: soft_register.hpp:588
static UHD_INLINE soft_reg_t & cast(soft_register_base ®)
Definition: soft_register.hpp:117
UHD_INLINE void refresh()
Definition: soft_register.hpp:353
soft_register_sync_t< uint64_t, false, true > soft_reg64_wo_sync_t
Definition: soft_register.hpp:398
Definition: wb_iface.hpp:17
soft_register_t(wb_iface::wb_addr_type wr_addr, wb_iface::wb_addr_type rd_addr, soft_reg_flush_mode_t mode=ALWAYS_FLUSH)
Definition: soft_register.hpp:147
uint32_t wb_addr_type
Definition: wb_iface.hpp:21
soft_register_sync_t< uint32_t, true, true > soft_reg32_rw_sync_t
Definition: soft_register.hpp:393
void add(soft_regmap_db_t &db)
Definition: soft_register.hpp:620
soft_register_sync_t(wb_iface::wb_addr_type wr_addr, wb_iface::wb_addr_type rd_addr, soft_reg_flush_mode_t mode=ALWAYS_FLUSH)
Definition: soft_register.hpp:315
soft_register_base & lookup(const std::string &path) const override
Definition: soft_register.hpp:640
Definition: soft_register.hpp:265
std::vector< std::string > enumerate() const override
Definition: soft_register.hpp:682
UHD_INLINE void initialize(wb_iface &iface, bool sync=false) override
Definition: soft_register.hpp:173
@ OPTIMIZED_FLUSH
Definition: soft_register.hpp:128
UHD_INLINE void flush() override
Definition: soft_register.hpp:209
Definition: soft_register.hpp:329
@ ALWAYS_FLUSH
Definition: soft_register.hpp:309
Definition: soft_register.hpp:442
Definition: build_info.hpp:12
UHD_INLINE bool is_writable() override
Definition: soft_register.hpp:291
soft_register_t< uint64_t, false, true > soft_reg64_wo_t
Definition: soft_register.hpp:395
UHD_INLINE void add_to_map(soft_register_base ®, const std::string &name, const visibility_t visible=PRIVATE)
Definition: soft_register.hpp:553
UHD_INLINE void refresh() override
Definition: soft_register.hpp:235
Definition: soft_register.hpp:101
UHD_INLINE bool likely(bool expr)
hint for the branch prediction
Definition: soft_register.hpp:38
soft_register_sync_t< uint32_t, false, true > soft_reg32_wo_sync_t
Definition: soft_register.hpp:391
Definition: soft_register.hpp:483
soft_register_t< uint32_t, true, false > soft_reg32_ro_t
Definition: soft_register.hpp:389
Definition: exception.hpp:131
UHD_INLINE void set(const soft_reg_field_t field, const reg_data_t value)
Definition: soft_register.hpp:335
Definition: exception.hpp:95
soft_register_sync_t< uint64_t, true, true > soft_reg64_rw_sync_t
Definition: soft_register.hpp:400
std::shared_ptr< soft_register_sync_t< reg_data_t, readable, writable > > sptr
Definition: soft_register.hpp:313
Definition: soft_register.hpp:535
const std::string & get_name() const override
Definition: soft_register.hpp:603
UHD_INLINE bool unlikely(bool expr)
Definition: soft_register.hpp:56
void add(soft_regmap_t ®map)
Definition: soft_register.hpp:611
Definition: exception.hpp:47
virtual size_t get_bitwidth()=0
visibility_t
Definition: soft_register.hpp:545
soft_register_base & lookup(const std::string &name) const override
Definition: soft_register.hpp:521
soft_register_t< uint32_t, false, true > soft_reg32_wo_t
Definition: soft_register.hpp:388
UHD_INLINE size_t width(const soft_reg_field_t field)
Definition: soft_register.hpp:75
std::shared_ptr< soft_register_t< reg_data_t, readable, writable > > sptr
Definition: soft_register.hpp:139
Definition: soft_register.hpp:189
soft_regmap_db_t()
Definition: soft_register.hpp:593
