dboard_eeprom.h
4 //
6 //
7
8 #pragma once
9
10 #include <uhd/config.h>
11 #include <uhd/error.h>
12
13 #ifdef __cplusplus
15 # include <string>
16
17 struct uhd_dboard_eeprom_t
18 {
19  uhd::usrp::dboard_eeprom_t dboard_eeprom_cpp;
20  std::string last_error;
21 };
22
23 extern "C" {
24 #else
25 struct uhd_dboard_eeprom_t;
26 #endif
27
29
35 typedef struct uhd_dboard_eeprom_t* uhd_dboard_eeprom_handle;
36
38 UHD_API uhd_error uhd_dboard_eeprom_make(uhd_dboard_eeprom_handle* h);
39
41
45 UHD_API uhd_error uhd_dboard_eeprom_free(uhd_dboard_eeprom_handle* h);
46
49  uhd_dboard_eeprom_handle h, char* id_out, size_t strbuffer_len);
50
52 UHD_API uhd_error uhd_dboard_eeprom_set_id(uhd_dboard_eeprom_handle h, const char* id);
53
56  uhd_dboard_eeprom_handle h, char* serial_out, size_t strbuffer_len);
57
60  uhd_dboard_eeprom_handle h, const char* serial);
61
68  uhd_dboard_eeprom_handle h, int* revision_out);
69
72  uhd_dboard_eeprom_handle h, int revision);
73
76  uhd_dboard_eeprom_handle h, char* error_out, size_t strbuffer_len);
77
78 #ifdef __cplusplus
79 }
80 #endif
UHD_API uhd_error uhd_dboard_eeprom_free(uhd_dboard_eeprom_handle *h)
Safely destroy the given handle.
UHD_API uhd_error uhd_dboard_eeprom_get_serial(uhd_dboard_eeprom_handle h, char *serial_out, size_t strbuffer_len)
Get the daughterboard&#39;s serial.
UHD_API uhd_error uhd_dboard_eeprom_set_revision(uhd_dboard_eeprom_handle h, int revision)
Set the daughterboard&#39;s revision.
uhd_error
UHD error codes.
Definition: error.h:20
UHD_API uhd_error uhd_dboard_eeprom_get_id(uhd_dboard_eeprom_handle h, char *id_out, size_t strbuffer_len)
Get the ID associated with the given daughterboard as a string hex representation.
struct uhd_dboard_eeprom_t * uhd_dboard_eeprom_handle
A C-level interface for interacting with a daughterboard EEPROM.
Definition: dboard_eeprom.h:35
Definition: dboard_eeprom.hpp:17
UHD_API uhd_error uhd_dboard_eeprom_get_revision(uhd_dboard_eeprom_handle h, int *revision_out)
UHD_API uhd_error uhd_dboard_eeprom_set_serial(uhd_dboard_eeprom_handle h, const char *serial)
Set the daughterboard&#39;s serial.
UHD_API uhd_error uhd_dboard_eeprom_make(uhd_dboard_eeprom_handle *h)
Create handle for a USRP daughterboard EEPROM.
Definition: config.h:87
UHD_API uhd_error uhd_dboard_eeprom_set_id(uhd_dboard_eeprom_handle h, const char *id)
Set the daughterboard ID using a string hex representation.
UHD_API uhd_error uhd_dboard_eeprom_last_error(uhd_dboard_eeprom_handle h, char *error_out, size_t strbuffer_len)
Get the last error reported by the handle.
