expert_factory.hpp
2 // Copyright 2016 Ettus Research
4 //
6 //
7
8 #pragma once
9
10 #include <uhd/config.hpp>
12 #include <uhd/property_tree.hpp>
14 #include <functional>
15 #include <memory>
16
18 namespace uhd { namespace experts {
19
32 {
33 public:
40  static expert_container::sptr create_container(const std::string& name);
41
56  template <typename data_t>
57  inline static void add_data_node(expert_container::sptr container,
58  const std::string& name,
59  const data_t& init_val,
61  {
62  container->add_data_node(new data_node_t<data_t>(name, init_val), mode);
63  }
64
91  template <typename data_t>
93  property_tree::sptr subtree,
94  const fs_path& path,
95  const std::string& name,
96  const data_t& init_val,
98  {
99  property<data_t>& prop =
100  subtree->create<data_t>(path, property_tree::AUTO_COERCE);
101  data_node_t<data_t>* node_ptr =
102  new data_node_t<data_t>(name, init_val, &container->resolve_mutex());
103  prop.set(init_val);
105  std::bind(&data_node_t<data_t>::commit, node_ptr, std::placeholders::_1));
106  prop.set_publisher(std::bind(&data_node_t<data_t>::retrieve, node_ptr));
107  container->add_data_node(node_ptr, mode);
108  return prop;
109  }
110
123  template <typename data_t>
125  property_tree::sptr subtree,
126  const fs_path& path,
127  const data_t& init_val,
129  {
130  return add_prop_node(container, subtree, path, path, init_val, mode);
131  }
132
151  template <typename data_t>
153  property_tree::sptr subtree,
154  const fs_path& path,
155  const std::string& desired_name,
156  const std::string& coerced_name,
157  const data_t& init_val,
159  {
160  bool auto_resolve_desired =
162  bool auto_resolve_coerced =
164
165  property<data_t>& prop =
166  subtree->create<data_t>(path, property_tree::MANUAL_COERCE);
167  data_node_t<data_t>* desired_node_ptr =
168  new data_node_t<data_t>(desired_name, init_val, &container->resolve_mutex());
169  data_node_t<data_t>* coerced_node_ptr =
170  new data_node_t<data_t>(coerced_name, init_val, &container->resolve_mutex());
171  prop.set(init_val);
172  prop.set_coerced(init_val);
173  prop.add_desired_subscriber(std::bind(
174  &data_node_t<data_t>::commit, desired_node_ptr, std::placeholders::_1));
175  prop.set_publisher(std::bind(&data_node_t<data_t>::retrieve, coerced_node_ptr));
176
177  container->add_data_node(desired_node_ptr,
178  auto_resolve_desired ? AUTO_RESOLVE_ON_WRITE : AUTO_RESOLVE_OFF);
179  container->add_data_node(coerced_node_ptr,
180  auto_resolve_coerced ? AUTO_RESOLVE_ON_READ : AUTO_RESOLVE_OFF);
181  return prop;
182  }
183
197  template <typename data_t>
199  property_tree::sptr subtree,
200  const fs_path& path,
201  const data_t& init_val,
203  {
204  return add_dual_prop_node(container,
205  subtree,
206  path,
207  path + "/desired",
208  path + "/coerced",
209  init_val,
210  mode);
211  }
212
222  template <typename worker_t>
223  inline static void add_worker_node(expert_container::sptr container)
224  {
225  container->add_worker(new worker_t());
226  }
227
242  template <typename worker_t, typename arg1_t>
243  inline static void add_worker_node(
244  expert_container::sptr container, arg1_t const& arg1)
245  {
246  container->add_worker(new worker_t(arg1));
247  }
248
249  template <typename worker_t, typename arg1_t, typename arg2_t>
250  inline static void add_worker_node(
251  expert_container::sptr container, arg1_t const& arg1, arg2_t const& arg2)
252  {
253  container->add_worker(new worker_t(arg1, arg2));
254  }
255
256  template <typename worker_t, typename arg1_t, typename arg2_t, typename arg3_t>
257  inline static void add_worker_node(expert_container::sptr container,
258  arg1_t const& arg1,
259  arg2_t const& arg2,
260  arg3_t const& arg3)
261  {
262  container->add_worker(new worker_t(arg1, arg2, arg3));
263  }
264
265  template <typename worker_t,
266  typename arg1_t,
267  typename arg2_t,
268  typename arg3_t,
269  typename arg4_t>
270  inline static void add_worker_node(expert_container::sptr container,
271  arg1_t const& arg1,
272  arg2_t const& arg2,
273  arg3_t const& arg3,
274  arg4_t const& arg4)
275  {
276  container->add_worker(new worker_t(arg1, arg2, arg3, arg4));
277  }
278
279  template <typename worker_t,
280  typename arg1_t,
281  typename arg2_t,
282  typename arg3_t,
283  typename arg4_t,
284  typename arg5_t>
285  inline static void add_worker_node(expert_container::sptr container,
286  arg1_t const& arg1,
287  arg2_t const& arg2,
288  arg3_t const& arg3,
289  arg4_t const& arg4,
290  arg5_t const& arg5)
291  {
292  container->add_worker(new worker_t(arg1, arg2, arg3, arg4, arg5));
293  }
294
295  template <typename worker_t,
296  typename arg1_t,
297  typename arg2_t,
298  typename arg3_t,
299  typename arg4_t,
300  typename arg5_t,
301  typename arg6_t>
302  inline static void add_worker_node(expert_container::sptr container,
303  arg1_t const& arg1,
304  arg2_t const& arg2,
305  arg3_t const& arg3,
306  arg4_t const& arg4,
307  arg5_t const& arg5,
308  arg6_t const& arg6)
309  {
310  container->add_worker(new worker_t(arg1, arg2, arg3, arg4, arg5, arg6));
311  }
312
313  template <typename worker_t,
314  typename arg1_t,
315  typename arg2_t,
316  typename arg3_t,
317  typename arg4_t,
318  typename arg5_t,
319  typename arg6_t,
320  typename arg7_t>
321  inline static void add_worker_node(expert_container::sptr container,
322  arg1_t const& arg1,
323  arg2_t const& arg2,
324  arg3_t const& arg3,
325  arg4_t const& arg4,
326  arg5_t const& arg5,
327  arg6_t const& arg6,
328  arg7_t const& arg7)
329  {
330  container->add_worker(new worker_t(arg1, arg2, arg3, arg4, arg5, arg6, arg7));
331  }
332
333  template <typename worker_t,
334  typename arg1_t,
335  typename arg2_t,
336  typename arg3_t,
337  typename arg4_t,
338  typename arg5_t,
339  typename arg6_t,
340  typename arg7_t,
341  typename arg8_t>
342  inline static void add_worker_node(expert_container::sptr container,
343  arg1_t const& arg1,
344  arg2_t const& arg2,
345  arg3_t const& arg3,
346  arg4_t const& arg4,
347  arg5_t const& arg5,
348  arg6_t const& arg6,
349  arg7_t const& arg7,
350  arg7_t const& arg8)
351  {
352  container->add_worker(
353  new worker_t(arg1, arg2, arg3, arg4, arg5, arg6, arg7, arg8));
354  }
355 };
356 }} // namespace uhd::experts
static property< data_t > & add_prop_node(expert_container::sptr container, property_tree::sptr subtree, const fs_path &path, const std::string &name, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
Definition: expert_factory.hpp:92
std::shared_ptr< expert_container > sptr
Definition: expert_container.hpp:28
Definition: property_tree.hpp:205
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1, arg2_t const &arg2, arg3_t const &arg3)
Definition: expert_factory.hpp:257
auto_resolve_mode_t
Definition: expert_container.hpp:18
Definition: property_tree.hpp:225
static property< data_t > & add_dual_prop_node(expert_container::sptr container, property_tree::sptr subtree, const fs_path &path, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
Definition: expert_factory.hpp:198
Definition: expert_factory.hpp:223
Definition: expert_container.hpp:21
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1, arg2_t const &arg2, arg3_t const &arg3, arg4_t const &arg4)
Definition: expert_factory.hpp:270
Definition: expert_factory.hpp:31
Definition: expert_container.hpp:19
virtual property< T > & add_coerced_subscriber(const subscriber_type &subscriber)=0
Definition: build_info.hpp:12
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1, arg2_t const &arg2, arg3_t const &arg3, arg4_t const &arg4, arg5_t const &arg5)
Definition: expert_factory.hpp:285
virtual property< T > & set_publisher(const publisher_type &publisher)=0
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1, arg2_t const &arg2)
Definition: expert_factory.hpp:250
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1, arg2_t const &arg2, arg3_t const &arg3, arg4_t const &arg4, arg5_t const &arg5, arg6_t const &arg6, arg7_t const &arg7)
Definition: expert_factory.hpp:321
virtual property< T > & set(const T &value)=0
static void add_data_node(expert_container::sptr container, const std::string &name, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
Definition: expert_factory.hpp:57
Definition: expert_nodes.hpp:128
virtual property< T > & set_coerced(const T &value)=0
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1)
Definition: expert_factory.hpp:243
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1, arg2_t const &arg2, arg3_t const &arg3, arg4_t const &arg4, arg5_t const &arg5, arg6_t const &arg6, arg7_t const &arg7, arg7_t const &arg8)
Definition: expert_factory.hpp:342
Definition: expert_container.hpp:20
Definition: config.h:87
static void add_worker_node(expert_container::sptr container, arg1_t const &arg1, arg2_t const &arg2, arg3_t const &arg3, arg4_t const &arg4, arg5_t const &arg5, arg6_t const &arg6)
Definition: expert_factory.hpp:302
Definition: expert_container.hpp:22
virtual property< T > & add_desired_subscriber(const subscriber_type &subscriber)=0
Definition: property_tree.hpp:78
Definition: property_tree.hpp:223
static property< data_t > & add_prop_node(expert_container::sptr container, property_tree::sptr subtree, const fs_path &path, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
Definition: expert_factory.hpp:124
static property< data_t > & add_dual_prop_node(expert_container::sptr container, property_tree::sptr subtree, const fs_path &path, const std::string &desired_name, const std::string &coerced_name, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
Definition: expert_factory.hpp:152
