Loading [MathJax]/jax/output/HTML-CSS/config.js
Vivado Environment Utilities
Environment Setup
  • Navigate to <repo>/fpga/usrp3/top/{project} where {project} is:
    • x300: For USRP X300/X310
    • e31x: For USRP E310
    • e320: For USRP E320
    • n3xx: For USRP N300/N310/N320
    • x400: For USRP X410
  • To setup up the Ettus Research Xilinx build environment run
    • source setupenv.sh (If Vivado is installed in the default path /opt/Xilinx/Vivado) OR
    • source setupenv.sh --vivado-path=<VIVADO_PATH> (where VIVADO_PATH is a non-default installation path)
  • This should not only enable building USRP FPGAs but also make available the utilities described in the following sections.
ModelSim Specific
The setupenv.sh script will search the system for ModelSim installations and setup everything to run it natively and within Vivado. The currently supported versions of ModelSim are PE, DE, SE, DE-64, SE-64.
The following functions are also available in the environment:
build_simlibs: Build ModelSim simulation libraries for Vivado
IP Management
Create Vivado IP
viv_create_ip: Create a new Vivado IP instance and a Makefile for it
Usage: viv_create_ip <IP Name> <IP Location> <IP VLNV> <Product>
- <IP Name>: Name of the IP instance
- <IP Location>: Base location for IP
- <IP VLNV>: The vendor, library, name, and version (VLNV) string for the IP as defined by Xilinx
- <Product>: Product to generate IP for
Modify existing Vivado IP
viv_modify_ip: Modify an existing Vivado IP instance
Usage: viv_modify_ip <IP XCI Path>
- <IP XCI Path>: Path to the IP XCI file
Modify existing Vivado Block Design (BD)
viv_modify_bd: Modify an existing Vivado BD instance
Usage: viv_modify_bd <BD File Path> <Product>
- <BD File Path>: Path to the BD file.
Modify existing Vivado Tcl-based Block Design
viv_modify_tcl_bd: Modify an existing Vivado BD instance
Usage: viv_modify_tcl_bd <Tcl File Path> <Product>
- <Tcl File Path>: Path to the Tcl file for the block design.
List supported Vivado IP
viv_ls_ip: List the items in the Vivado IP catalog
Usage: viv_ls_ip <Product>
- <Product>: Product to generate IP for.
Upgrade IP to the environment version of Vivado
viv_upgrade_ip: Upgrade one or more Xilinx IP targets
Usage: viv_upgrade_ip <IP Directory> [--recursive]
- <IP Directory>: Path to the IP XCI file.
Hardware Management
Launch Vivado Hardware Console
viv_hw_console: Launch the Tcl hardware console
Usage: viv_hw_console
List connected JTAG devices
viv_jtag_list: List all devices (and their addresses) that are connected to the system using the Xilinx platform cable
Usage: viv_jtag_list
Program device over JTAG
viv_jtag_program: Downloads a bitfile to an FPGA device using Vivado
Usage: viv_jtag_program <Bitfile Path> [<Device Address> = 0:0]
- <Bitfile Path>: Path to a .bit FPGA configuration file
- <Device Address>: Address to the device in the form <Target>:<Device>
                    Run viv_jtag_list to get a list of connected devices
Probe Xilinx bitfile
probe_bitfile: Probe a Xilinx bitfile and report header information
Usage: probe_bitfile <Bitfile Path>
