Loading [MathJax]/jax/input/TeX/config.js
Internal GPSDO Application Notes (USRP-X3x0 Models)
This application note describes the use of the board-mounted GPS Disciplined OCXO, as used with the USRP X300/X310. For information regarding the GPSDO that is compatible with the USRP N2xx or E1xx, please see Internal GPSDO (USRP-N2x0/E1X0 Models).
Specifications
  • 10 MHz ADEV: 5e-11 over >24h
  • 1PPS RMS jitter: <50ns 1-sigma
  • Holdover: <20us over 3h
Phase noise:
Offset OCXO Phase noise power
1Hz -75dBc/Hz
10Hz -110dBc/Hz
100Hz -132dBc/Hz
1kHz -142dBc/Hz
10kHz -145dBc/Hz
100kHz -150dBc/Hz
Antenna Types:
Installation Instructions
To install the GPSDO, you must insert it into the slot on the board near the 10 MHz Reference SMA. Keep in mind that the two sides of the GPSDO have a different number of pins. When inserting the GPSDO, make sure to press down firmly and evenly. When turning on the USRP X3x0 device, a green LED should illuminate on the GPSDO. This signifies that the unit has successfully been placed.
If a GPSDO is detected at startup, the USRP will have gpsdo clock and time source options.
Select these by using UHD's
usrp->set_clock_source("gpsdo");
usrp->set_time_source("gpsdo");
That will lock the reference clock to the disciplined 10MHz oscillator, and will make the USRP listen for time signal pulses coming from the GPSDO.
However, you will still need to explicitly set the device time on such a PPS edge, using the set_time_next_pps or set_time_unknown_pps calls.
The returned value will be the current epoch time, in seconds since January 1, 1970. This value is readily converted into human-readable format using the time.h library in C, std::chrono in C++, etc.
Device Time to GPS time
If you want to set the device time to GPS time, the following procedure makes sure you don't encounter timing problems while doing so:
  1. Wait for GPS lock, and then set the time source to GPSDO,
    while(! (usrp->get_mboard_sensor("gps_locked",0).to_bool()) ) {
    std::this_thread::sleep(std::chrono::seconds(2));
  2. poll on usrp->get_time_last_pps() until a change is seen, and then sleep 200ms to allow new time data coming from the GPSDO to propagate through the system,
    uhd::time_spec_t last = usrp->get_time_last_pps();
    uhd::time_spec_t next = usrp->get_time_last_pps();
    while(next == last) {
    std::this_thread::sleep(std::chrono::milliseconds(50));
    last = next;
    std::this_thread::sleep(std::chrono::milliseconds(200));
  3. use
    usrp->set_time_next_pps(uhd::time_spec_t(usrp->get_mboard_sensor("gps_time").to_int()+1));
    to set the time,
  4. poll on usrp->get_time_last_pps() until a change is seen and sleep 200ms (allow NMEA string to propagate),
  5. Verify that usrp->get_time_last_pps() and usrp->get_mboard_sensor("gps_time") return the same time.
GPS sensors
