97     virtual property<T>& set_coercer(
const coercer_type& coercer) = 0;
   109     virtual property<T>& set_publisher(
const publisher_type& publisher) = 0;
   120     virtual property<T>& add_desired_subscriber(
const subscriber_type& subscriber) = 0;
   131     virtual property<T>& add_coerced_subscriber(
   166     virtual property<T>& set_coerced(
const T& value) = 0;
   176     virtual const T
get(void)
const = 0;
   184     virtual const T get_desired(
void)
const = 0;
   192     virtual bool empty(
void)
const = 0;
   195 template <
typename T>
   209     UHD_API fs_path(
const std::string&);
   210     UHD_API std::string leaf(
void)
const;
   211     UHD_API fs_path branch_path(
void)
const;
   223     typedef std::shared_ptr<property_tree>
sptr;
   230     static sptr make(
void);
   233     virtual sptr subtree(
const fs_path& path)
const = 0;
   236     virtual void remove(
const fs_path& path) = 0;
   239     virtual bool exists(
const = 0;
   242     virtual std::vector<std::string> list(
const = 0;
   245     template <
typename T>
   249     template <
typename T>
   253     template <
typename T>
   254     std::shared_ptr<property<T>> pop(
const fs_path& path);
   258     virtual std::shared_ptr<property_iface> _pop(
   261     virtual void _create(
   262         const fs_path& path,
const std::shared_ptr<property_iface>& prop) = 0;
   265     virtual std::shared_ptr<property_iface>& _access(
const = 0;
 virtual ~property(void)=0
Definition: property_tree.hpp:196
std::function< T(const T &)> coercer_type
Definition: property_tree.hpp:83
Definition: property_tree.hpp:205
#define UHD_API_HEADER
Definition: config.h:88
std::function< void(const T &)> subscriber_type
Definition: property_tree.hpp:81
Definition: build_info.hpp:12
Definition: config.h:87
coerce_mode_t
Definition: property_tree.hpp:225
Definition: property_tree.hpp:220
UHD_API fs_path operator/(const fs_path &, const fs_path &)
Definition: property_tree.hpp:78
Definition: property_tree.hpp:24
Definition: property_tree.hpp:223
std::function< T(void)> publisher_type
Definition: property_tree.hpp:82
