ranges.hpp
4 //
6 //
7
8 #pragma once
9
10 #include <uhd/config.hpp>
11 #include <type_traits>
12 #include <string>
13 #include <vector>
14
15 namespace uhd {
16
22 {
23 public:
29  range_t(double value = 0);
30
38  range_t(double start, double stop, double step = 0);
39
41  double start(void) const;
42
44  double stop(void) const;
45
47  double step(void) const;
48
50  const std::string to_pp_string(void) const;
51
53  bool operator==(const range_t& other) const;
54
56  bool operator!=(const range_t& other) const;
57
58 private:
59  double _start, _stop, _step;
60 };
61
65 struct UHD_API meta_range_t : public std::vector<range_t>
66 {
68  meta_range_t(void);
69
76  template <typename InputIterator>
77  meta_range_t(InputIterator first, InputIterator last)
78  : std::vector<range_t>(first, last)
79  { /* NOP */
80  // This is to avoid people accidentally doing silly things like:
81  // meta_range_t(0, 0)
82  // which probably was supposed to call meta_range_t(double, double, double)
83  // but actually calls this constructor.
84  static_assert(!std::is_integral<typename std::decay<InputIterator>::type>::value,
85  "You can't pass integers to meta_range_t's constructor!");
86  }
87
95  meta_range_t(double start, double stop, double step = 0);
96
98  double start(void) const;
99
101  double stop(void) const;
102
104  double step(void) const;
105
112  double clip(double value, bool clip_step = false) const;
113
124  meta_range_t as_monotonic() const;
125
127  const std::string to_pp_string(void) const;
128 };
129
132
133 } // namespace uhd
meta_range_t freq_range_t
Definition: ranges.hpp:131
Definition: ranges.hpp:77
UHD_INLINE T clip(const T &val, const T &bound1, const T &bound2)
Definition: algorithm.hpp:81
meta_range_t gain_range_t
Definition: ranges.hpp:130
Definition: fp_compare_delta.ipp:71
STL namespace.
Definition: build_info.hpp:12
Definition: ranges.hpp:21
Definition: config.h:87
Definition: ranges.hpp:65
UHD_API bool operator==(const time_spec_t &, const time_spec_t &)
