serial.hpp
4 //
6 //
7
8 #pragma once
9
10 #include <uhd/config.hpp>
11 #include <stdint.h>
12 #include <memory>
13 #include <string>
14 #include <vector>
15
16 namespace uhd {
21 typedef std::vector<uint8_t> byte_vector_t;
22
36 {
37 public:
38  typedef std::shared_ptr<i2c_iface> sptr;
39
40  virtual ~i2c_iface(void);
41
43  i2c_iface::sptr eeprom16(void);
44
50  virtual void write_i2c(uint16_t addr, const byte_vector_t& buf) = 0;
51
58  virtual byte_vector_t read_i2c(uint16_t addr, size_t num_bytes) = 0;
59
66  virtual void write_eeprom(uint16_t addr, uint16_t offset, const byte_vector_t& buf);
67
75  virtual byte_vector_t read_eeprom(uint16_t addr, uint16_t offset, size_t num_bytes);
76 };
77
83 {
88  enum edge_t { EDGE_RISE = 'r', EDGE_FALL = 'f' };
89
92
95
98
100  size_t divider;
101
106  spi_config_t(edge_t edge = EDGE_RISE);
107
113  spi_config_t(edge_t edge, size_t divider);
114 };
115
122 {
123 public:
124  typedef std::shared_ptr<spi_iface> sptr;
125
126  virtual ~spi_iface(void);
127
137  virtual uint32_t transact_spi(int which_slave,
138  const spi_config_t& config,
139  uint32_t data,
140  size_t num_bits,
141  bool readback) = 0;
142
151  virtual uint32_t read_spi(
152  int which_slave, const spi_config_t& config, uint32_t data, size_t num_bits);
153
161  virtual void write_spi(
162  int which_slave, const spi_config_t& config, uint32_t data, size_t num_bits);
163 };
164
169 {
170 public:
171  typedef std::shared_ptr<uart_iface> sptr;
172
173  virtual ~uart_iface(void);
174
179  virtual void write_uart(const std::string& buf) = 0;
180
186  virtual std::string read_uart(double timeout) = 0;
187 };
188
189 } // namespace uhd
size_t divider
Optionally set the SPI clock divider for this transaction.
Definition: serial.hpp:100
Definition: serial.hpp:121
Definition: serial.hpp:35
bool use_custom_divider
Set the clock speed for this transaction.
Definition: serial.hpp:97
std::shared_ptr< uart_iface > sptr
Definition: serial.hpp:171
edge_t mosi_edge
on what edge is the mosi data valid?
Definition: serial.hpp:91
std::shared_ptr< i2c_iface > sptr
Definition: serial.hpp:38
Definition: build_info.hpp:12
Definition: serial.hpp:82
Definition: config.h:87
std::shared_ptr< spi_iface > sptr
Definition: serial.hpp:124
edge_t miso_edge
on what edge is the miso data valid?
Definition: serial.hpp:94
Definition: serial.hpp:168
edge_t
Definition: serial.hpp:88
Definition: byte_vector.hpp:19
