byte_vector.hpp
4 //
6 //
7
8 #pragma once
9
10 #include <uhd/config.hpp>
11 #include <boost/range.hpp>
12 #include <algorithm>
13 #include <string>
14 #include <vector>
15
16 namespace uhd {
19 typedef std::vector<uint8_t> byte_vector_t;
21 template <typename RangeSrc, typename RangeDst>
22 UHD_INLINE void byte_copy(const RangeSrc& src, RangeDst& dst)
23 {
24  std::copy(boost::begin(src), boost::end(src), boost::begin(dst));
25 }
26
28 UHD_API std::string bytes_to_string(const byte_vector_t& bytes);
29
31 UHD_API byte_vector_t string_to_bytes(const std::string& str, size_t max_length);
32
33 } // namespace uhd
UHD_API std::string bytes_to_string(const byte_vector_t &bytes)
UHD_API byte_vector_t string_to_bytes(const std::string &str, size_t max_length)
Definition: byte_vector.hpp:22
Definition: build_info.hpp:12
#define UHD_INLINE
Definition: config.h:65
Definition: config.h:87
Definition: byte_vector.hpp:19
