uhd::rfnoc::moving_average_block_control Member List
This is the complete list of members for uhd::rfnoc::moving_average_block_control, including all inherited members.
get_divisor() const =0uhd::rfnoc::moving_average_block_controlpure virtual
get_sum_len() const =0uhd::rfnoc::moving_average_block_controlpure virtual
node_t()uhd::rfnoc::node_t
REG_DIVISOR_ADDRuhd::rfnoc::moving_average_block_controlstatic
REG_SUM_LEN_ADDRuhd::rfnoc::moving_average_block_controlstatic
set_divisor(const uint32_t divisor)=0uhd::rfnoc::moving_average_block_controlpure virtual
set_sum_len(const uint8_t sum_len)=0uhd::rfnoc::moving_average_block_controlpure virtual
