uhd::usrp::dboard_iface Member List
This is the complete list of members for uhd::usrp::dboard_iface, including all inherited members.
atr_reg_t typedefuhd::usrp::dboard_iface
AUX_ADC_A enum valueuhd::usrp::dboard_iface
AUX_ADC_B enum valueuhd::usrp::dboard_iface
aux_adc_t enum nameuhd::usrp::dboard_iface
AUX_DAC_A enum valueuhd::usrp::dboard_iface
AUX_DAC_B enum valueuhd::usrp::dboard_iface
AUX_DAC_C enum valueuhd::usrp::dboard_iface
AUX_DAC_D enum valueuhd::usrp::dboard_iface
aux_dac_t enum nameuhd::usrp::dboard_iface
eeprom16(void)uhd::i2c_iface
get_atr_reg(unit_t unit, atr_reg_t reg)=0uhd::usrp::dboard_ifacepure virtual
get_clock_rate(unit_t unit)=0uhd::usrp::dboard_ifacepure virtual
get_clock_rates(unit_t unit)=0uhd::usrp::dboard_ifacepure virtual
get_codec_rate(unit_t unit)=0uhd::usrp::dboard_ifacepure virtual
get_command_time(void)=0uhd::usrp::dboard_ifacepure virtual
get_gpio_ddr(unit_t unit)=0uhd::usrp::dboard_ifacepure virtual
get_gpio_out(unit_t unit)=0uhd::usrp::dboard_ifacepure virtual
get_pin_ctrl(unit_t unit)=0uhd::usrp::dboard_ifacepure virtual
get_special_props(void)=0uhd::usrp::dboard_ifacepure virtual
has_set_fe_connection(const unit_t)uhd::usrp::dboard_ifaceinlinevirtual
read_aux_adc(unit_t unit, aux_adc_t which_adc)=0uhd::usrp::dboard_ifacepure virtual
read_eeprom(uint16_t addr, uint16_t offset, size_t num_bytes)uhd::i2c_ifacevirtual
read_gpio(unit_t unit)=0uhd::usrp::dboard_ifacepure virtual
read_i2c(uint16_t addr, size_t num_bytes)=0uhd::i2c_ifacepure virtual
read_write_spi(unit_t unit, const spi_config_t &config, uint32_t data, size_t num_bits)=0uhd::usrp::dboard_ifacepure virtual
set_atr_reg(unit_t unit, atr_reg_t reg, uint32_t value, uint32_t mask=0xffff)=0uhd::usrp::dboard_ifacepure virtual
set_clock_enabled(unit_t unit, bool enb)=0uhd::usrp::dboard_ifacepure virtual
set_clock_rate(unit_t unit, double rate)=0uhd::usrp::dboard_ifacepure virtual
set_command_time(const uhd::time_spec_t &t)=0uhd::usrp::dboard_ifacepure virtual
set_fe_connection(unit_t unit, const std::string &fe_name, const uhd::usrp::fe_connection_t &fe_conn)=0uhd::usrp::dboard_ifacepure virtual
set_gpio_ddr(unit_t unit, uint32_t value, uint32_t mask=0xffff)=0uhd::usrp::dboard_ifacepure virtual
set_gpio_out(unit_t unit, uint32_t value, uint32_t mask=0xffff)=0uhd::usrp::dboard_ifacepure virtual
set_pin_ctrl(unit_t unit, uint32_t value, uint32_t mask=0xffff)=0uhd::usrp::dboard_ifacepure virtual
sleep(const std::chrono::nanoseconds &time)uhd::usrp::dboard_ifacevirtual
special_props_t typedefuhd::usrp::dboard_iface
sptr typedefuhd::usrp::dboard_iface
UNIT_BOTH enum valueuhd::usrp::dboard_iface
UNIT_RX enum valueuhd::usrp::dboard_iface
unit_t enum nameuhd::usrp::dboard_iface
UNIT_TX enum valueuhd::usrp::dboard_iface
write_aux_dac(unit_t unit, aux_dac_t which_dac, double value)=0uhd::usrp::dboard_ifacepure virtual
write_eeprom(uint16_t addr, uint16_t offset, const byte_vector_t &buf)uhd::i2c_ifacevirtual
write_i2c(uint16_t addr, const byte_vector_t &buf)=0uhd::i2c_ifacepure virtual
~dboard_iface(void) overrideuhd::usrp::dboard_ifaceinline
~i2c_iface(void)uhd::i2c_ifacevirtual
