14 namespace uhd {
namespace rfnoc {
    16 static const std::string CLOCK_KEY_GRAPH(
"__graph__");
    17 static const std::string CLOCK_KEY_AUTO(
"__auto__");
    19 static const std::string PROP_KEY_DECIM(
"decim");
    20 static const std::string PROP_KEY_INTERP(
"interp");
    21 static const std::string PROP_KEY_SAMP_RATE(
"samp_rate");
    22 static const std::string PROP_KEY_SCALING(
"scaling");
    23 static const std::string PROP_KEY_TYPE(
"type");
    24 static const std::string PROP_KEY_FREQ(
"freq");
    25 static const std::string PROP_KEY_TICK_RATE(
"tick_rate");
    26 static const std::string PROP_KEY_SPP(
"spp");
    27 static const std::string PROP_KEY_MTU(
"mtu");
    28 static const std::string PROP_KEY_ATOMIC_ITEM_SIZE(
"atomic_item_size");
    30 static const std::string NODE_ID_SEP(
"SEP");
    33 static const io_type_t IO_TYPE_S16  =
"s16";
    34 static const io_type_t IO_TYPE_SC16 =
"sc16";
    37 static const std::string ACTION_KEY_STREAM_CMD(
"stream_cmd");
    38 static const std::string ACTION_KEY_RX_EVENT(
"rx_event");
    39 static const std::string ACTION_KEY_RX_RESTART_REQ(
"restart_request");
    40 static const std::string ACTION_KEY_TX_EVENT(
"tx_event");
    43 static const std::string DEFAULT_BLOCK_NAME =
"Block";
    45 static const uint32_t DEFAULT_NOC_ID  = 0xFFFFFFFF;
    46 static const double DEFAULT_TICK_RATE = 1.0;
    76 static const noc_id_t ADDSUB_BLOCK         = 0xADD00000;
    77 static const noc_id_t DUC_BLOCK            = 0xD0C00000;
    78 static const noc_id_t DDC_BLOCK            = 0xDDC00000;
    79 static const noc_id_t FFT_BLOCK            = 0xFF700000;
    80 static const noc_id_t FIR_FILTER_BLOCK     = 0xF1120000;
    81 static const noc_id_t FOSPHOR_BLOCK        = 0x666F0000;
    82 static const noc_id_t LOGPWR_BLOCK         = 0x4C500000;
    83 static const noc_id_t KEEP_ONE_IN_N_BLOCK  = 0x02460000;
    84 static const noc_id_t MOVING_AVERAGE_BLOCK = 0xAAD20000;
    85 static const noc_id_t RADIO_BLOCK          = 0x12AD1000;
    86 static const noc_id_t REPLAY_BLOCK         = 0x4E91A000;
    87 static const noc_id_t SIGGEN_BLOCK         = 0x51663110;
    88 static const noc_id_t SPLIT_STREAM_BLOCK   = 0x57570000;
    89 static const noc_id_t SWITCHBOARD_BLOCK    = 0xBE110000;
    90 static const noc_id_t VECTOR_IIR_BLOCK     = 0x11120000;
    91 static const noc_id_t WINDOW_BLOCK         = 0xD0530000;
 Definition: build_info.hpp:12
uint16_t device_type_t
Device Type.
Definition: defaults.hpp:55
std::string io_type_t
Definition: defaults.hpp:32
uint32_t noc_id_t
Definition: defaults.hpp:51
