Loading [MathJax]/jax/output/HTML-CSS/config.js
device_addr.hpp
4 //
6 //
7
8 #pragma once
9
10 #include <uhd/config.hpp>
11 #include <uhd/types/dict.hpp>
12 #include <boost/lexical_cast.hpp>
13 #include <map>
14 #include <stdexcept>
15 #include <string>
16 #include <vector>
18 namespace uhd {
19
37 class UHD_API device_addr_t : public dict<std::string, std::string>
38 {
39 public:
44  device_addr_t(const std::string& args = "");
45
50  device_addr_t(const char* args);
51
56  device_addr_t(const std::map<std::string, std::string>& info);
57
62  std::string to_pp_string(void) const;
63
69  std::string to_string(void) const;
70
79  template <typename T>
80  T cast(const std::string& key, const T& def) const
81  {
82  if (not this->has_key(key))
83  return def;
84  try {
85  return boost::lexical_cast<T>((*this)[key]);
86  } catch (const boost::bad_lexical_cast&) {
87  throw std::runtime_error("cannot cast " + key + " = " + (*this)[key]);
88  }
89  }
90 };
91
93 typedef std::vector<device_addr_t> device_addrs_t;
94
96 UHD_API device_addrs_t separate_device_addr(const device_addr_t& dev_addr);
97
99 UHD_API device_addr_t combine_device_addrs(const device_addrs_t& dev_addrs);
100
101 } // namespace uhd
UHD_API device_addr_t combine_device_addrs(const device_addrs_t &dev_addrs)
Combine a vector of device addresses into an indexed device address.
Definition: log.hpp:119
Definition: dict.hpp:21
Definition: build_info.hpp:12
UHD_API device_addrs_t separate_device_addr(const device_addr_t &dev_addr)
Separate an indexed device address into a vector of device addresses.
T cast(const std::string &key, const T &def) const
Definition: device_addr.hpp:80
std::vector< device_addr_t > device_addrs_t
A typedef for a vector of device addresses.
Definition: device_addr.hpp:93
Definition: config.h:87
Definition: device_addr.hpp:37
