12 namespace uhd {
namespace rfnoc {
   105     static const uint32_t REG_ENABLE_ADDR;
   106     static const uint32_t REG_CLEAR_ADDR;
   107     static const uint32_t REG_RANDOM_ADDR;
   108     static const uint32_t REG_DECIM_ADDR;
   109     static const uint32_t REG_OFFSET_ADDR;
   110     static const uint32_t REG_SCALE_ADDR;
   111     static const uint32_t REG_TRISE_ADDR;
   112     static const uint32_t REG_TDECAY_ADDR;
   113     static const uint32_t REG_ALPHA_ADDR;
   114     static const uint32_t REG_EPSILON_ADDR;
   115     static const uint32_t REG_WF_CTRL_ADDR;
   116     static const uint32_t REG_WF_DECIM_ADDR;
   124     virtual
void set_enable_histogram(const
bool enable_histogram) = 0;
   132     virtual
bool get_enable_histogram() const = 0;
   140     virtual
void set_enable_waterfall(const
bool enable_waterfall) = 0;
   148     virtual
bool get_enable_waterfall() const = 0;
   155     virtual
void clear_history() = 0;
   164     virtual
void set_enable_dither(const
bool enable_dither) = 0;
   172     virtual
bool get_enable_dither() const = 0;
   181     virtual
void set_enable_noise(const
bool enable_noise) = 0;
   189     virtual
bool get_enable_noise() const = 0;
   201     virtual
void set_histogram_decimation(const uint16_t decimation) = 0;
   209     virtual uint16_t get_histogram_decimation() const = 0;
   218     virtual
void set_histogram_offset(const uint16_t offset) = 0;
   226     virtual uint16_t get_histogram_offset() const = 0;
   235     virtual
void set_histogram_scale(const uint16_t scale) = 0;
   243     virtual uint16_t get_histogram_scale() const = 0;
   256     virtual
void set_histogram_rise_rate(const uint16_t rise_rate) = 0;
   264     virtual uint16_t get_histogram_rise_rate() const = 0;
   277     virtual
void set_histogram_decay_rate(const uint16_t decay_rate) = 0;
   285     virtual uint16_t get_histogram_decay_rate() const = 0;
   296     virtual
void set_spectrum_alpha(const uint16_t alpha) = 0;
   305     virtual uint16_t get_spectrum_alpha() const = 0;
   315     virtual
void set_spectrum_max_hold_decay(const uint16_t epsilon) = 0;
   324     virtual uint16_t get_spectrum_max_hold_decay() const = 0;
   332     virtual
void set_waterfall_predivision(
   373     virtual
void set_waterfall_decimation(const uint16_t waterfall_decimation) = 0;
   381     virtual uint16_t get_waterfall_decimation() const = 0;
fosphor_waterfall_predivision_ratio
Definition: fosphor_block_control.hpp:15
#define RFNOC_DECLARE_BLOCK(CLASS_NAME)
Definition: noc_block_base.hpp:22
Definition: build_info.hpp:12
Definition: noc_block_base.hpp:42
Definition: config.h:87
Definition: fosphor_block_control.hpp:99
fosphor_waterfall_mode
Definition: fosphor_block_control.hpp:14
