Legacy AXI Interface Libraries
This document describes legacy AXI interface libraries used by some testbenches. They are included here due to their continued use.
AXI4 Stream (sim_axis_lib.vh)
Defines axis_t, an AXI Stream bus interface that implements several tasks to send and receive data on the bus.
Definition
interface axis_t #(parameter DWIDTH = 64)
                  (input clk);
  logic [DWIDTH-1:0]  tdata;
  logic               tvalid;
  logic               tlast;
  logic               tready;
modport master (output tdata, output tvalid, output tlast, input tready);
modport slave (input tdata, input tvalid, input tlast, output tready);
Operations
push_word
// Push a word onto the AXI-Stream bus and wait for it to transfer
// Args:
// - word: The data to push onto the bus
// - eop (optional): End of packet (asserts tlast)
push_bubble
// Push a bubble cycle onto the AXI-Stream bus
pull_word
// Wait for a sample to be transferred on the AXI Stream
// bus and return the data and last
// Args:
// - word: The data pulled from the bus
// - eop: End of packet (tlast)
wait_for_bubble
// Wait for a bubble cycle on the AXI Stream bus
wait_for_pkt
// Wait for a packet to finish on the bus
push_rand_pkt
// Push a packet with random data onto to the AXI Stream bus
// Args:
// - num_samps: Packet size.
push_ramp_pkt
// Push a packet with a ramp on to the AXI Stream bus
// Args:
// - ramp_start: Start value for the ramp
// - ramp_inc: Increment per clock cycle
Compressed VITA (sim_chdr_lib.vh)
Note: This section describes legacy CHDR in 3.x and earlier. As of UHD 4.0, the CHDR protocol and format has changed.
Defines cvita_stream_t, an AXI Stream bus interface that implements the CHDR protocol and several tasks to send and receive data on the bus.
CHDR
typedef enum logic [1:0] {
  DATA=2'b00, FC=2'b01, CMD=2'b10, RESP=2'b11
} cvita_pkt_t;
typedef struct packed {
  logic [31:0]  sid;
  logic [15:0]  length;
  logic [11:0]  seqno;
  logic         eob;
  logic         has_time;
  cvita_pkt_t   pkt_type;
  logic [63:0]  timestamp;
} cvita_hdr_t;
Operations
  • flatten_chdr_no_ts: Flatten header struct to a 64-bit bus. No timestamp.
  • unflatten_chdr_no_ts: Decode a 64-bit header and populate the cvita_hdr_t struct. No timestamp.
  • unflatten_chdr: Decode a 64-bit header and populate the cvita_hdr_t struct. Timestamp supported.
CVITA Stream Type
Definition
interface cvita_stream_t (input clk);
  axis_t #(.DWIDTH(64)) axis (.clk(clk));
push_hdr
// Push a CVITA header into the stream
// Args:
// - hdr: The header to push
push_data
// Args:
// - eop: End of packet (asserts tlast)
push_bubble
// Push a bubble cycle on the AXI-Stream bus
pull_word
// Args:
wait_for_bubble
wait_for_pkt
wait_for_pkt_get_info
// Wait for a packet to finish on the bus and extract the header and payload statistics.
  logic [31:0]  count;
  logic [63:0]  sum;
  logic [63:0]  min;
  logic [63:0]  max;
  logic [63:0]  crc;
} cvita_stats_t;
push_rand_pkt
// Args:
// - hdr: Header to attach to packet (length will be ignored)
// - timestamp: Optional timestamp
push_ramp_pkt
// Args:
Memory Mapped AXI4 (sim_axi4_lib.vh)
Defines the following interfaces to group signals in the AXI4 bus. WIP: No functions or tasks implemented yet.
Address
interface axi4_addr_t #(parameter AWIDTH=32, parameter IDWIDTH=4)
                       (input clk);
  logic [IDWIDTH-1:0] id;
  logic [AWIDTH-1:0]  addr;
  logic [7:0]         len;
  logic [2:0]         size;
  logic [1:0]         burst;
  logic               lock;
  logic [3:0]         cache;
  logic [2:0]         prot;
  logic [3:0]         qos;
  logic [3:0]         region;
  logic               user;
  logic               valid;
  logic               ready;
  modport master (output id,addr,len,size,burst,lock,cache,prot,qos,valid, input ready);
  modport slave (input id,addr,len,size,burst,lock,cache,prot,qos,valid, output ready);
endinterface
Write Data
interface axi4_wdata_t #(parameter DWIDTH=64)
                       (input clk);
  logic [DWIDTH-1:0]      data;
  logic [(DWIDTH/8)-1:0]  strb;
  logic                   last;
  logic                   user;
  logic                   valid;
  logic                   ready;
  modport master(output data,strb,last,valid, input ready);
  modport slave(input data,strb,last,valid, output ready);
endinterface
Write Response
interface axi4_resp_t #(parameter IDWIDTH=4)
                       (input clk);
  logic               ready;
  logic [1:0]         resp;
  logic               user;
  logic               valid;
  modport master(output ready, input id,resp,valid);
  modport slave(input ready, output id,resp,valid);
endinterface
Read Data
interface axi4_rdata_t #(parameter DWIDTH=64, parameter IDWIDTH=4)
                       (input clk);
  logic               ready;
  logic [1:0]         resp;
  logic               user;
  logic               last;
  logic               valid;
  modport master(output ready, input id,data,resp,last,valid);
  modport slave(input ready, output id,data,resp,last,valid);
endinterface
Meta: AXI4 Writer
interface axi4_wr_t #(parameter DWIDTH=64, parameter AWIDTH=32, parameter IDWIDTH=4)
                     (input clk);
  axi4_addr_t  #(.AWIDTH(AWIDTH), .IDWIDTH(IDWIDTH)) addr (.clk(clk));
  axi4_wdata_t #(.DWIDTH(DWIDTH))                    data (.clk(clk));
  axi4_resp_t  #(.IDWIDTH(IDWIDTH))                  resp (.clk(clk));
  modport master(output addr, output data, input resp);
  modport slave(input addr, input data, output resp);
endinterface
Meta: AXI4 Reader
interface axi4_rd_t #(parameter DWIDTH=64, parameter AWIDTH=32, parameter IDWIDTH=4)
                     (input clk);
  axi4_rdata_t #(.DWIDTH(DWIDTH), .IDWIDTH(IDWIDTH)) data (.clk(clk));
  modport master(output addr, output data);
  modport slave(input addr, input data);
endinterface
