The top-level simulation module will instantiate the DUT and implement self-checking behavior. Testbenches can be written in any language (SystemVerilog, Verilog, VHDL) but to take advantage of our repository of simulation libraries, it is recommended that SystemVerilog be used.
An example testbench is shown below. This example is for an RFNoC block. If creating a testbench for RFNoC, it is recommended to use the RFNoC ModTool to generate a testbench template for your RFNoC block.
See Simulation Libraries for documentation on the simulation libraries used in this example.
// // Copyright 2020 Ettus Research, A National Instruments Company // // SPDX-License-Identifier: LGPL-3.0-or-later // // Module: rfnoc_block_example_tb // // Description: An example top-level testbench // `default_nettype none module rfnoc_block_example_tb; `include "test_exec.svh" import PkgTestExec::*; import PkgChdrUtils::*; import PkgRfnocBlockCtrlBfm::*; //--------------------------------------------------------------------------- // Testbench Configuration //--------------------------------------------------------------------------- localparam [ 9:0] THIS_PORTID = 10'h123; localparam int CHDR_W = 64; localparam int ITEM_W = 32; localparam int NUM_PORTS_I = 1; localparam int NUM_PORTS_O = 1; localparam int MTU = 13; localparam int SPP = 64; localparam int PKT_SIZE_BYTES = SPP * (ITEM_W/8); localparam int STALL_PROB = 25; // Default BFM stall probability localparam real CHDR_CLK_PER = 5.0; // 200 MHz localparam real CTRL_CLK_PER = 25.0; // 40 MHz //--------------------------------------------------------------------------- // Clocks and Resets //--------------------------------------------------------------------------- bit rfnoc_chdr_clk; bit rfnoc_ctrl_clk; sim_clock_gen #(CHDR_CLK_PER) rfnoc_chdr_clk_gen (.clk(rfnoc_chdr_clk), .rst()); sim_clock_gen #(CTRL_CLK_PER) rfnoc_ctrl_clk_gen (.clk(rfnoc_ctrl_clk), .rst()); //--------------------------------------------------------------------------- // Bus Functional Models //--------------------------------------------------------------------------- // Backend Interface RfnocBackendIf backend (rfnoc_chdr_clk, rfnoc_ctrl_clk); // AXIS-Ctrl Interface AxiStreamIf #(32) m_ctrl (rfnoc_ctrl_clk, 1'b0); AxiStreamIf #(32) s_ctrl (rfnoc_ctrl_clk, 1'b0); // AXIS-CHDR Interfaces AxiStreamIf #(CHDR_W) m_chdr [NUM_PORTS_I] (rfnoc_chdr_clk, 1'b0); AxiStreamIf #(CHDR_W) s_chdr [NUM_PORTS_O] (rfnoc_chdr_clk, 1'b0); // Block Controller BFM RfnocBlockCtrlBfm #(CHDR_W, ITEM_W) blk_ctrl = new(backend, m_ctrl, s_ctrl); // CHDR word and item/sample data types typedef ChdrData #(CHDR_W, ITEM_W)::chdr_word_t chdr_word_t; typedef ChdrData #(CHDR_W, ITEM_W)::item_t item_t; // Connect block controller to BFMs for (genvar i = 0; i < NUM_PORTS_I; i++) begin : gen_bfm_input_connections initial begin blk_ctrl.connect_master_data_port(i, m_chdr[i], PKT_SIZE_BYTES); blk_ctrl.set_master_stall_prob(i, STALL_PROB); end end for (genvar i = 0; i < NUM_PORTS_O; i++) begin : gen_bfm_output_connections initial begin blk_ctrl.connect_slave_data_port(i, s_chdr[i]); blk_ctrl.set_slave_stall_prob(i, STALL_PROB); end end //--------------------------------------------------------------------------- // Device Under Test (DUT) //--------------------------------------------------------------------------- // DUT Slave (Input) Port Signals logic [CHDR_W*NUM_PORTS_I-1:0] s_rfnoc_chdr_tdata; logic [ NUM_PORTS_I-1:0] s_rfnoc_chdr_tlast; logic [ NUM_PORTS_I-1:0] s_rfnoc_chdr_tvalid; logic [ NUM_PORTS_I-1:0] s_rfnoc_chdr_tready; // DUT Master (Output) Port Signals logic [CHDR_W*NUM_PORTS_O-1:0] m_rfnoc_chdr_tdata; logic [ NUM_PORTS_O-1:0] m_rfnoc_chdr_tlast; logic [ NUM_PORTS_O-1:0] m_rfnoc_chdr_tvalid; logic [ NUM_PORTS_O-1:0] m_rfnoc_chdr_tready; // Map the array of BFMs to a flat vector for the DUT connections for (genvar i = 0; i < NUM_PORTS_I; i++) begin : gen_dut_input_connections // Connect BFM master to DUT slave port assign s_rfnoc_chdr_tdata[CHDR_W*i+:CHDR_W] = m_chdr[i].tdata; assign s_rfnoc_chdr_tlast[i] = m_chdr[i].tlast; assign s_rfnoc_chdr_tvalid[i] = m_chdr[i].tvalid; assign m_chdr[i].tready = s_rfnoc_chdr_tready[i]; end for (genvar i = 0; i < NUM_PORTS_O; i++) begin : gen_dut_output_connections // Connect BFM slave to DUT master port assign s_chdr[i].tdata = m_rfnoc_chdr_tdata[CHDR_W*i+:CHDR_W]; assign s_chdr[i].tlast = m_rfnoc_chdr_tlast[i]; assign s_chdr[i].tvalid = m_rfnoc_chdr_tvalid[i]; assign m_rfnoc_chdr_tready[i] = s_chdr[i].tready; end rfnoc_block_example #( .THIS_PORTID (THIS_PORTID), .CHDR_W (CHDR_W), .MTU (MTU) ) dut ( .rfnoc_chdr_clk (rfnoc_chdr_clk), .rfnoc_ctrl_clk (rfnoc_ctrl_clk), .rfnoc_core_config (backend.cfg), .rfnoc_core_status (backend.sts), .s_rfnoc_chdr_tdata (s_rfnoc_chdr_tdata), .s_rfnoc_chdr_tlast (s_rfnoc_chdr_tlast), .s_rfnoc_chdr_tvalid (s_rfnoc_chdr_tvalid), .s_rfnoc_chdr_tready (s_rfnoc_chdr_tready), .m_rfnoc_chdr_tdata (m_rfnoc_chdr_tdata), .m_rfnoc_chdr_tlast (m_rfnoc_chdr_tlast), .m_rfnoc_chdr_tvalid (m_rfnoc_chdr_tvalid), .m_rfnoc_chdr_tready (m_rfnoc_chdr_tready), .s_rfnoc_ctrl_tdata (m_ctrl.tdata), .s_rfnoc_ctrl_tlast (m_ctrl.tlast), .s_rfnoc_ctrl_tvalid (m_ctrl.tvalid), .s_rfnoc_ctrl_tready (m_ctrl.tready), .m_rfnoc_ctrl_tdata (s_ctrl.tdata), .m_rfnoc_ctrl_tlast (s_ctrl.tlast), .m_rfnoc_ctrl_tvalid (s_ctrl.tvalid), .m_rfnoc_ctrl_tready (s_ctrl.tready) ); //--------------------------------------------------------------------------- // Main Test Process //--------------------------------------------------------------------------- initial begin : tb_main // Initialize the test exec object for this testbench test.start_tb("example"); // Start the BFMs running //blk_ctrl.run(); //-------------------------------- // Reset //-------------------------------- test.start_test("Flush block then reset it", 10us); //blk_ctrl.flush_and_reset(); test.end_test(); //-------------------------------- // Test Sequences //-------------------------------- test.start_test("This is an example test", 10us); // < Add test code here > test.end_test(); //-------------------------------- // Finish Up //-------------------------------- // Display final statistics and results test.end_tb(); end : tb_main endmodule : rfnoc_block_example_tb `default_nettype wire
