14 namespace uhd {
namespace rfnoc {
    50     virtual void set_enable(
const bool enable,
const size_t port) = 0;
    60     virtual bool get_enable(
const size_t port)
const = 0;
    70     virtual void set_waveform(
const siggen_waveform type,
    99     virtual void set_amplitude(
const double amplitude,
   111     virtual double get_amplitude(
const size_t port)
const = 0;
   126     virtual void set_constant(
const std::complex<double> constant,
   137     virtual std::complex<double> get_constant(
const size_t port)
const = 0;
   148     virtual void set_sine_phase_increment(
const double phase_inc,
   159     virtual double get_sine_phase_increment(
const size_t port)
const = 0;
   170     virtual void set_samples_per_packet(
const size_t spp,
   180     virtual size_t get_samples_per_packet(
const size_t port)
const = 0;
   193         const double frequency,
const double sample_rate,
const size_t port)
   195         if (sample_rate <= 0.0) {
   198         const double phase_inc = (frequency / sample_rate) * 2.0 * uhd::math::PI;
   199         if (phase_inc < -uhd::math::PI || phase_inc > uhd::math::PI) {
   202         set_sine_phase_increment(phase_inc, port);
 siggen_waveform
Definition: siggen_block_control.hpp:16
static const uint32_t REG_PHASE_INC_OFFSET
Definition: siggen_block_control.hpp:39
static const uint32_t REG_SPP_OFFSET
Definition: siggen_block_control.hpp:35
Definition: exception.hpp:107
#define RFNOC_DECLARE_BLOCK(CLASS_NAME)
Definition: noc_block_base.hpp:22
static const uint32_t REG_ENABLE_OFFSET
Definition: siggen_block_control.hpp:34
Definition: build_info.hpp:12
void set_sine_frequency(const double frequency, const double sample_rate, const size_t port)
Definition: siggen_block_control.hpp:192
Definition: noc_block_base.hpp:42
static const uint32_t REG_GAIN_OFFSET
Definition: siggen_block_control.hpp:37
Definition: config.h:87
static const uint32_t REG_CONSTANT_OFFSET
Definition: siggen_block_control.hpp:38
static const uint32_t REG_CARTESIAN_OFFSET
Definition: siggen_block_control.hpp:40
Definition: siggen_block_control.hpp:28
static const uint32_t REG_BLOCK_SIZE
Definition: siggen_block_control.hpp:33
static const uint32_t REG_WAVEFORM_OFFSET
Definition: siggen_block_control.hpp:36
