14 namespace uhd {
namespace transport {
namespace vrt {
    17 static const size_t num_vrl_words32 = 3;
    20 static const size_t max_if_hdr_words32 = 7;
    41         PACKET_TYPE_DATA    = 0x0,
    42         PACKET_TYPE_IF_EXT  = 0x1,
    43         PACKET_TYPE_CONTEXT = 0x2,
    48         PACKET_TYPE_ACK  = 0x1,
    49         PACKET_TYPE_CMD  = 0x2,
    50         PACKET_TYPE_RESP = 0x3,
   173     : link_type(LINK_TYPE_NONE)
   174     , packet_type(PACKET_TYPE_DATA)
   175     , num_payload_words32(0)
   176     , num_payload_bytes(0)
   177     , num_header_words32(0)
   178     , num_packet_words32(0)
 uint64_t cid
Definition: vrt_if_packet.hpp:76
Definition: vrt_if_packet.hpp:27
size_t num_packet_words32
Definition: vrt_if_packet.hpp:59
UHD_API void if_hdr_unpack_le(const uint32_t *packet_buff, if_packet_info_t &if_packet_info)
if_packet_info_t(void)
Definition: vrt_if_packet.hpp:172
packet_type_t
Definition: vrt_if_packet.hpp:39
uint64_t tsf
Definition: vrt_if_packet.hpp:82
UHD_API void if_hdr_unpack_be(const uint32_t *packet_buff, if_packet_info_t &if_packet_info)
bool has_cid
Class ID.
Definition: vrt_if_packet.hpp:75
link_type_t
Definition: vrt_if_packet.hpp:32
uint32_t tlr
Definition: vrt_if_packet.hpp:85
Definition: build_info.hpp:12
uint32_t sid
Definition: vrt_if_packet.hpp:73
UHD_API void if_hdr_pack_be(uint32_t *packet_buff, if_packet_info_t &if_packet_info)
bool error
This is asserted for command responses that are errors (CHDR only)
Definition: vrt_if_packet.hpp:66
size_t num_payload_bytes
Definition: vrt_if_packet.hpp:57
bool has_tsi
Integer timestamp.
Definition: vrt_if_packet.hpp:78
#define UHD_INLINE
Definition: config.h:65
bool has_tsf
Fractional timestamp.
Definition: vrt_if_packet.hpp:81
size_t packet_count
Definition: vrt_if_packet.hpp:62
Definition: config.h:87
bool has_sid
Stream ID (SID).
Definition: vrt_if_packet.hpp:72
size_t num_payload_words32
Definition: vrt_if_packet.hpp:56
bool fc_ack
This is asserted for flow control packets are ACKS (CHDR only)
Definition: vrt_if_packet.hpp:68
UHD_API void if_hdr_pack_le(uint32_t *packet_buff, if_packet_info_t &if_packet_info)
bool has_tlr
Trailer.
Definition: vrt_if_packet.hpp:84
size_t num_header_words32
Definition: vrt_if_packet.hpp:58
bool sob
Asserted for start- or end-of-burst.
Definition: vrt_if_packet.hpp:64
uint32_t tsi
Definition: vrt_if_packet.hpp:79
