13 namespace uhd {
namespace rfnoc {
    36     static const uint32_t REG_WINDOW_BLOCK_SIZE;
    38     static const uint32_t REG_WINDOW_LEN_OFFSET;
    39     static const uint32_t REG_WINDOW_MAX_LEN_OFFSET;
    40     static const uint32_t REG_WINDOW_LOAD_COEFF_OFFSET;
    41     static const uint32_t REG_WINDOW_LOAD_COEFF_LAST_OFFSET;
    51     virtual
size_t get_max_num_coefficients(const
size_t chan) const = 0;
    62     virtual
void set_coefficients(
    63         const
std::vector<int16_t>& coeffs, const
size_t chan) = 0;
    72     virtual
std::vector<int16_t> get_coefficients(const
#define RFNOC_DECLARE_BLOCK(CLASS_NAME)
Definition: noc_block_base.hpp:22
Definition: build_info.hpp:12
Definition: noc_block_base.hpp:42
Definition: config.h:87
Definition: window_block_control.hpp:30
