16 namespace uhd {
namespace usrp {
namespace cal {
    87     static std::vector<uint8_t> read_cal_data(
const std::string& key,
    88         const std::string& serial,
   108     static bool has_cal_data(
   109         const std::string& serial,
   130     static void write_cal_data(
   131         const std::string& serial,
   132         const std::vector<uint8_t>& cal_data,
   133         const std::string& backup_ext =
   144         std::function<std::vector<uint8_t>(
const std::string&,
const std::string&)>;
 No calibration data available.
Stored on device flash memory, e.g. EEPROM.
Definition: database.hpp:67
std::function< std::vector< uint8_t >(const std::string &, const std::string &)> get_data_fn_type
Function type to return serialized cal data key and serial.
Definition: database.hpp:144
Definition: build_info.hpp:12
Internal Resource Compiler (i.e., hard-coded within UHD)
Stored on the local filesystem.
source
Identify the source of calibration data, i.e., where was it stored.
Definition: database.hpp:23
std::function< bool(const std::string &, const std::string &)> has_data_fn_type
Function type to look up if there is cal data given a key and serial.
Definition: database.hpp:136
Definition: config.h:87
