11 #include <boost/date_time/posix_time/posix_time_types.hpp>    12 #include <boost/optional.hpp>   110 namespace uhd {
namespace log {
   130     const std::string& log_level_str);
   142         const std::string& file_,
   143         const unsigned int& line_,
   144         const std::string& component_,
   145         const std::thread::id& thread_id_)
   147         , verbosity(verbosity_)
   150         , component(component_)
   151         , thread_id(thread_id_)
   196 #define _UHD_LOG_INTERNAL(component, level) \   197     uhd::_log::log(level, __FILE__, __LINE__, component, std::this_thread::get_id())   201 #if UHD_LOG_MIN_LEVEL < 1   202 #    define UHD_LOG_TRACE(component, message) \   203         _UHD_LOG_INTERNAL(component, uhd::log::trace) << message;   205 #    define UHD_LOG_TRACE(component, message)   208 #if UHD_LOG_MIN_LEVEL < 2   209 #    define UHD_LOG_DEBUG(component, message) \   210         _UHD_LOG_INTERNAL(component, uhd::log::debug) << message;   212 #    define UHD_LOG_DEBUG(component, message)   215 #if UHD_LOG_MIN_LEVEL < 3   216 #    define UHD_LOG_INFO(component, message) \   217         _UHD_LOG_INTERNAL(component, uhd::log::info) << message;   219 #    define UHD_LOG_INFO(component, message)   222 #if UHD_LOG_MIN_LEVEL < 4   223 #    define UHD_LOG_WARNING(component, message) \   224         _UHD_LOG_INTERNAL(component, uhd::log::warning) << message;   226 #    define UHD_LOG_WARNING(component, message)   229 #if UHD_LOG_MIN_LEVEL < 5   230 #    define UHD_LOG_ERROR(component, message) \   231         _UHD_LOG_INTERNAL(component, uhd::log::error) << message;   233 #    define UHD_LOG_ERROR(component, message)   236 #define UHD_LOG_THROW(exception_type, component, message) \   238         std::ostringstream __ss;                          \   240         UHD_LOG_ERROR(component, __ss.str());             \   241         throw exception_type(__ss.str());                 \   244 #if UHD_LOG_MIN_LEVEL < 6   245 #    define UHD_LOG_FATAL(component, message) \   246         _UHD_LOG_INTERNAL(component, uhd::log::fatal) << message;   248 #    define UHD_LOG_FATAL(component, message)   251 #define RFNOC_LOG_TRACE(message)   UHD_LOG_TRACE(this->get_unique_id(), message)   252 #define RFNOC_LOG_DEBUG(message)   UHD_LOG_DEBUG(this->get_unique_id(), message)   253 #define RFNOC_LOG_INFO(message)    UHD_LOG_INFO(this->get_unique_id(), message)   254 #define RFNOC_LOG_WARNING(message) UHD_LOG_WARNING(this->get_unique_id(), message)   255 #define RFNOC_LOG_ERROR(message)   UHD_LOG_ERROR(this->get_unique_id(), message)   256 #define RFNOC_LOG_FATAL(message)   UHD_LOG_FATAL(this->get_unique_id(), message)   258 #ifndef UHD_LOG_FASTPATH_DISABLE   263 #    define UHD_LOG_FASTPATH(message) uhd::_log::log_fastpath(message);   265 #    define UHD_LOG_FASTPATH(message)   269 #define UHD_LOGGER_TRACE(component)   _UHD_LOG_INTERNAL(component, uhd::log::trace)   270 #define UHD_LOGGER_DEBUG(component)   _UHD_LOG_INTERNAL(component, uhd::log::debug)   271 #define UHD_LOGGER_INFO(component)    _UHD_LOG_INTERNAL(component, uhd::log::info)   272 #define UHD_LOGGER_WARNING(component) _UHD_LOG_INTERNAL(component, uhd::log::warning)   273 #define UHD_LOGGER_ERROR(component)   _UHD_LOG_INTERNAL(component, uhd::log::error)   274 #define UHD_LOGGER_FATAL(component)   _UHD_LOG_INTERNAL(component, uhd::log::fatal)   277 #if defined(__GNUG__)   278 #    define UHD_HERE()            \   280         UHD_LOGGER_DEBUG("DEBUG") \   281             << __FILE__ << ":" << __LINE__ << " (" << UHD_PRETTY_FUNCTION << ")";   283 #    define UHD_HERE() UHD_LOGGER_DEBUG("DEBUG") << __FILE__ << ":" << __LINE__;   288 #define UHD_VAR(var) UHD_LOGGER_DEBUG("DEBUG") << #var << " = " << var;   291 #define UHD_HEX(var)                                                              \   292     UHD_LOGGER_DEBUG("DEBUG") << #var << " = 0x" << std::hex << std::setfill('0') \   293                               << std::setw(8) << var << std::dec;   300 void UHD_API log_fastpath(
const std::string&);
   307         const std::string& file,
   308         const unsigned int line,
   309         const std::string& component,
   310         const std::thread::id thread_id);
   316 #define INSERTION_OVERLOAD(x) \   326     template <
typename T>
   327     INSERTION_OVERLOAD(T val)
   330     INSERTION_OVERLOAD(std::ostream& (*val)(std::ostream&))
   331         INSERTION_OVERLOAD(std::ios& (*val)(std::ios&))
   332             INSERTION_OVERLOAD(std::ios_base& (*val)(std::ios_base&))
   335     std::ostringstream _ss;
 boost::posix_time::ptime time
Definition: log.hpp:155
std::string file
Definition: log.hpp:157
unsigned int line
Definition: log.hpp:158
logging_info()
Definition: log.hpp:139
severity_level
Definition: log.hpp:116
Definition: build_info.hpp:12
Definition: log.hpp:160
UHD_API void set_file_level(uhd::log::severity_level level)
uhd::log::severity_level verbosity
Definition: log.hpp:156
UHD_API void set_log_level(uhd::log::severity_level level)
UHD_API void set_logger_level(const std::string &logger, uhd::log::severity_level level)
Definition: config.h:87
logging_info(const boost::posix_time::ptime &time_, const uhd::log::severity_level &verbosity_, const std::string &file_, const unsigned int &line_, const std::string &component_, const std::thread::id &thread_id_)
Definition: log.hpp:140
std::string message
Definition: log.hpp:161
UHD_API void set_console_level(uhd::log::severity_level level)
std::string component
Definition: log.hpp:159
boost::optional< uhd::log::severity_level > UHD_API parse_log_level_from_string(const std::string &log_level_str)
