Version: 4.7.0.0-22-g6758966a
log.h
1
2
* Copyright 2017 Ettus Research (National Instruments Corp.)
3
4
* SPDX-License-Identifier: GPL-3.0-or-later
5
6
7
#pragma once
8
9
#include <
uhd/config.h
10
11
typedef
enum
12
UHD_LOG_LEVEL_TRACE
13
UHD_LOG_LEVEL_DEBUG
14
UHD_LOG_LEVEL_INFO
15
UHD_LOG_LEVEL_WARNING
16
UHD_LOG_LEVEL_ERROR
UHD_LOG_LEVEL_FATAL
18
uhd_log_severity_level_t
19
#ifdef __cplusplus
21
extern
"C"
22
#endif
23
void
UHD_API
_uhd_log
const
log_level,
25
const
char
* filename,
26
const
int
lineno,
27
const
char
* comp,
28
const
char
* format,
29
30
31
#ifdef __cplusplus
32
33
#endif
34
35
36
#ifndef __cplusplus
37
// macro-style logging (compile-time determined)
38
# if UHD_LOG_MIN_LEVEL < 1
39
# define UHD_LOG_TRACE(component, ...) \
40
_uhd_log(UHD_LOG_LEVEL_TRACE, __FILE__, __LINE__, component, __VA_ARGS__);
41
# else
42
43
# endif
44
45
# if UHD_LOG_MIN_LEVEL < 2
46
# define UHD_LOG_DEBUG(component, ...) \
47
_uhd_log(UHD_LOG_LEVEL_DEBUG, __FILE__, __LINE__, component, __VA_ARGS__);
48
# else
49
50
# endif
51
52
# if UHD_LOG_MIN_LEVEL < 3
53
# define UHD_LOG_INFO(component, ...) \
54
_uhd_log(UHD_LOG_LEVEL_INFO, __FILE__, __LINE__, component, __VA_ARGS__);
55
# else
56
57
# endif
58
59
# if UHD_LOG_MIN_LEVEL < 4
60
# define UHD_LOG_WARNING(component, ...) \
61
_uhd_log(UHD_LOG_LEVEL_WARNING, __FILE__, __LINE__, component, __VA_ARGS__);
62
# else
63
64
# endif
65
66
# if UHD_LOG_MIN_LEVEL < 5
67
# define UHD_LOG_ERROR(component, ...) \
68
_uhd_log(UHD_LOG_LEVEL_ERROR, __FILE__, __LINE__, component, __VA_ARGS__);
69
# else
70
71
# endif
72
73
# if UHD_LOG_MIN_LEVEL < 6
74
# define UHD_LOG_FATAL(component, ...) \
75
_uhd_log(UHD_LOG_LEVEL_FATAL, __FILE__, __LINE__, component, __VA_ARGS__);
76
# else
77
78
# endif
79
80
#endif
/* #ifndef __cplusplus */
config.h
UHD_API
Definition:
config.h:87
Definition:
log.h:11
UHD_LOG_LEVEL_TRACE
@ UHD_LOG_LEVEL_TRACE
Definition:
log.h:12
UHD_LOG_LEVEL_ERROR
@ UHD_LOG_LEVEL_ERROR
Definition:
log.h:16
UHD_LOG_LEVEL_INFO
@ UHD_LOG_LEVEL_INFO
Definition:
log.h:14
UHD_LOG_LEVEL_DEBUG
@ UHD_LOG_LEVEL_DEBUG
Definition:
log.h:13
UHD_LOG_LEVEL_FATAL
@ UHD_LOG_LEVEL_FATAL
Definition:
log.h:17
@ UHD_LOG_LEVEL_WARNING
Definition:
log.h:15
_uhd_log
void UHD_API _uhd_log(const uhd_log_severity_level_t log_level, const char *filename, const int lineno, const char *comp, const char *format,...)
include
uhd
utils
log.h
Generated by
1.9.1
