Internal GPSDO (USRP-N2x0/E1X0 Models)
This application note describes the use of integrated GPS-disciplined oscillators (GPSDOs) for the USRP N-Series and E1xx. For information regarding the GPSDO that is compatible with the USRP X-Series, please see: Internal GPSDO Application Notes (USRP-X3x0 Models)
Specifications
  • 10MHz ADEV: 1e-11 over > 24h
  • 1PPS RMS jitter: < 50ns 1-sigma
  • Holdover: < 11us over 3h
  • Phase noise:
    • 1Hz: -80 dBc/Hz
    • 10Hz: -110 dBc/Hz
    • 100Hz: -135 dBc/Hz
    • 1kHz: -145 dBc/Hz
    • 10kHz: < -145 dBc/Hz
Antenna Types:
Installation Instructions
Instructions for mounting the GPSDO kit onto your USRP device can be found here: http://www.ettus.com/wp-content/uploads/2019/01/gpsdo-kit_4.pdf
Post-installation Task (N-Series only)
Note: The following instructions are only necessary for UHD 3.4.* and below.
This is necessary if you require absolute GPS time in your application or need to communicate with the GPSDO to obtain location, satellite info, etc. If you only require 10 MHz and PPS signals for reference or MIMO use (see Device Synchronization), it is not necessary to perform this step.
To configure the USRP to communicate with the GPSDO, use the usrp_burn_mb_eeprom utility:
./usrp_burn_mb_eeprom --args=<optional device args> --values="gpsdo=internal"
-- restore original setting --
By default, if a GPSDO is detected at startup, the USRP will be configured to use it as a frequency and time reference. The internal VITA timestamp will be initialized to the GPS time, and the internal oscillator will be phase-locked to the 10 MHz GPSDO reference. If the GPSDO is not locked to satellites, the VITA time will not be initialized.
