    Version: 4.8.0.0
   17 #include <boost/optional.hpp>
   24 namespace uhd {
namespace rfnoc {
   38     using sptr = std::shared_ptr<action_info>;
   50     static sptr make(
const std::string& key =
   61     using sptr = std::shared_ptr<stream_cmd_action_info>;
   75     using sptr = std::shared_ptr<rx_event_action_info>;
   90     using sptr = std::shared_ptr<tx_event_action_info>;
  103         const boost::optional<uint64_t>& tsf);
  107         const boost::optional<uint64_t>& tsf);
  114     using sptr = std::shared_ptr<tune_request_action_info>;
uhd::tune_result_t tune_result
Definition: actions.hpp:118
Definition: actions.hpp:87
uhd::tune_request_t tune_request
Definition: actions.hpp:116
Action object for graph-based tuning.
Definition: actions.hpp:111
std::vector< uint8_t > payload
An arbitrary payload. It is up to consumers and producers to.
Definition: actions.hpp:45
Definition: actions.hpp:72
virtual ~action_info()
Definition: actions.hpp:36
const size_t id
A unique counter for this action.
Definition: actions.hpp:40
uhd::rx_metadata_t::error_code_t error_code
The error code that describes the event.
Definition: actions.hpp:78
Definition: config.h:87
uhd::time_spec_t time_spec
Definition: actions.hpp:117
uhd::device_addr_t args
A dictionary of key-value pairs. May be used as desired.
Definition: actions.hpp:47
bool has_tsf
Has time specification?
Definition: actions.hpp:96
std::shared_ptr< action_info > sptr
Definition: actions.hpp:38
uhd::freq_range_t overall_freq_range
Definition: actions.hpp:121
Definition: build_info.hpp:12
uhd::freq_range_t rf_range
Definition: actions.hpp:120
Definition: time_spec.hpp:28
Definition: stream_cmd.hpp:39
Definition: tune_request.hpp:24
Definition: actions.hpp:33
stream_mode_t
Definition: stream_cmd.hpp:41
Definition: actions.hpp:58
std::string key
A string identifier for this action.
Definition: actions.hpp:42
uhd::async_metadata_t::event_code_t event_code
The event code that describes the event.
Definition: actions.hpp:93
uint64_t tsf
When the async event occurred.
Definition: actions.hpp:99
uhd::freq_range_t dsp_range
Definition: actions.hpp:119
uhd::stream_cmd_t stream_cmd
Definition: actions.hpp:63
Definition: tune_result.hpp:18
