block_controller_factory_python.hpp
2 // Copyright 2020 Ettus Research, a National Instruments Brand
5 //
6
7 #pragma once
8
10
11 namespace uhd { namespace rfnoc {
12
13 // Static factory for constructing a block controller T given an instance of
14 // the superclass noc_block_base for the block controller, as might be
15 // returned from uhd::rfnoc::graph::get_block(). The instance is downcast to
16 // the derived class and returned to the client as a T::sptr. If block_base
17 // does not represent an instance of T, nullptr is returned.
18 template <typename T>
20 {
21 public:
22  static typename T::sptr make_from(uhd::rfnoc::noc_block_base::sptr block_base)
23  {
24  return std::dynamic_pointer_cast<T>(block_base);
25  }
26 };
27
28 }} // namespace uhd::rfnoc
uhd::rfnoc::block_controller_factory
Definition: block_controller_factory_python.hpp:19
uhd::rfnoc::block_controller_factory::make_from
static T::sptr make_from(uhd::rfnoc::noc_block_base::sptr block_base)
Definition: block_controller_factory_python.hpp:22
uhd
Definition: build_info.hpp:12
noc_block_base.hpp
Definition: noc_block_base.hpp:48
