uhd::rfnoc::fft_block_control Member List
This is the complete list of members for uhd::rfnoc::fft_block_control, including all inherited members.
get_bypass_mode() const =0uhd::rfnoc::fft_block_controlpure virtual
get_cp_insertion_list() const =0uhd::rfnoc::fft_block_controlpure virtual
get_cp_removal_list() const =0uhd::rfnoc::fft_block_controlpure virtual
get_direction() const =0uhd::rfnoc::fft_block_controlpure virtual
get_length() const =0uhd::rfnoc::fft_block_controlpure virtual
get_magnitude() const =0uhd::rfnoc::fft_block_controlpure virtual
get_max_cp_insertion_list_length() const =0uhd::rfnoc::fft_block_controlpure virtual
get_max_cp_length() const =0uhd::rfnoc::fft_block_controlpure virtual
get_max_cp_removal_list_length() const =0uhd::rfnoc::fft_block_controlpure virtual
get_max_length() const =0uhd::rfnoc::fft_block_controlpure virtual
get_scaling() const =0uhd::rfnoc::fft_block_controlpure virtual
get_shift_config() const =0uhd::rfnoc::fft_block_controlpure virtual
node_t()uhd::rfnoc::node_t
REG_BYPASS_ADDRuhd::rfnoc::fft_block_controlstatic
REG_CAPABILITIES2_ADDRuhd::rfnoc::fft_block_controlstatic
REG_CAPABILITIES_ADDRuhd::rfnoc::fft_block_controlstatic
REG_COMPAT_ADDRuhd::rfnoc::fft_block_controlstatic
REG_CP_INS_LEN_ADDRuhd::rfnoc::fft_block_controlstatic
REG_CP_INS_LIST_CLR_ADDRuhd::rfnoc::fft_block_controlstatic
REG_CP_INS_LIST_LOAD_ADDRuhd::rfnoc::fft_block_controlstatic
REG_CP_INS_LIST_OCC_ADDRuhd::rfnoc::fft_block_controlstatic
REG_CP_REM_LEN_ADDRuhd::rfnoc::fft_block_controlstatic
REG_CP_REM_LIST_CLR_ADDRuhd::rfnoc::fft_block_controlstatic
REG_CP_REM_LIST_LOAD_ADDRuhd::rfnoc::fft_block_controlstatic
REG_CP_REM_LIST_OCC_ADDRuhd::rfnoc::fft_block_controlstatic
REG_DIRECTION_ADDRuhd::rfnoc::fft_block_controlstatic
REG_DIRECTION_ADDR_V1uhd::rfnoc::fft_block_controlstatic
REG_LENGTH_LOG2_ADDRuhd::rfnoc::fft_block_controlstatic
REG_LENGTH_LOG2_ADDR_V1uhd::rfnoc::fft_block_controlstatic
REG_MAGNITUDE_ADDRuhd::rfnoc::fft_block_controlstatic
REG_MAGNITUDE_ADDR_V1uhd::rfnoc::fft_block_controlstatic
REG_ORDER_ADDRuhd::rfnoc::fft_block_controlstatic
REG_ORDER_ADDR_V1uhd::rfnoc::fft_block_controlstatic
REG_OVERFLOW_ADDRuhd::rfnoc::fft_block_controlstatic
REG_PORT_CONFIG_ADDRuhd::rfnoc::fft_block_controlstatic
REG_RESET_ADDRuhd::rfnoc::fft_block_controlstatic
REG_RESET_ADDR_V1uhd::rfnoc::fft_block_controlstatic
REG_SCALING_ADDRuhd::rfnoc::fft_block_controlstatic
REG_SCALING_ADDR_V1uhd::rfnoc::fft_block_controlstatic
set_bypass_mode(const bool bypass)=0uhd::rfnoc::fft_block_controlpure virtual
set_cp_insertion_list(const std::vector< uint32_t > cp_lengths)=0uhd::rfnoc::fft_block_controlpure virtual
set_cp_removal_list(const std::vector< uint32_t > cp_lengths)=0uhd::rfnoc::fft_block_controlpure virtual
set_direction(const fft_direction direction)=0uhd::rfnoc::fft_block_controlpure virtual
set_length(const uint32_t length)=0uhd::rfnoc::fft_block_controlpure virtual
set_magnitude(const fft_magnitude magnitude)=0uhd::rfnoc::fft_block_controlpure virtual
set_scaling(const uint32_t scaling)=0uhd::rfnoc::fft_block_controlpure virtual
set_scaling_factor(const double factor)=0uhd::rfnoc::fft_block_controlpure virtual
set_shift_config(const fft_shift shift)=0uhd::rfnoc::fft_block_controlpure virtual
