uhd::rfnoc::replay_block_control Member List
This is the complete list of members for uhd::rfnoc::replay_block_control, including all inherited members.
config_play(const uint64_t offset, const uint64_t size, const size_t port=0)=0uhd::rfnoc::replay_block_controlpure virtual
get_max_items_per_packet(const size_t port=0) const =0uhd::rfnoc::replay_block_controlpure virtual
get_max_packet_size(const size_t port=0) const =0uhd::rfnoc::replay_block_controlpure virtual
get_mem_size() const =0uhd::rfnoc::replay_block_controlpure virtual
get_play_async_metadata(uhd::async_metadata_t &metadata, const double timeout=0.1)=0uhd::rfnoc::replay_block_controlpure virtual
get_play_item_size(const size_t port=0) const =0uhd::rfnoc::replay_block_controlpure virtual
get_play_offset(const size_t port=0) const =0uhd::rfnoc::replay_block_controlpure virtual
get_play_position(const size_t port=0)=0uhd::rfnoc::replay_block_controlpure virtual
get_play_size(const size_t port=0) const =0uhd::rfnoc::replay_block_controlpure virtual
get_play_type(const size_t port=0) const =0uhd::rfnoc::replay_block_controlpure virtual
get_record_async_metadata(uhd::rx_metadata_t &metadata, const double timeout=0.1)=0uhd::rfnoc::replay_block_controlpure virtual
get_record_fullness(const size_t port=0)=0uhd::rfnoc::replay_block_controlpure virtual
get_record_item_size(const size_t port=0) const =0uhd::rfnoc::replay_block_controlpure virtual
get_record_offset(const size_t port=0) const =0uhd::rfnoc::replay_block_controlpure virtual
get_record_position(const size_t port=0)=0uhd::rfnoc::replay_block_controlpure virtual
get_record_size(const size_t port=0) const =0uhd::rfnoc::replay_block_controlpure virtual
get_record_type(const size_t port=0) const =0uhd::rfnoc::replay_block_controlpure virtual
get_word_size() const =0uhd::rfnoc::replay_block_controlpure virtual
issue_stream_cmd(const uhd::stream_cmd_t &stream_cmd, const size_t port=0)=0uhd::rfnoc::replay_block_controlpure virtual
MAJOR_COMPATuhd::rfnoc::replay_block_controlstatic
MINOR_COMPATuhd::rfnoc::replay_block_controlstatic
node_t()uhd::rfnoc::node_t
play(const uint64_t offset, const uint64_t size, const size_t port=0, const uhd::time_spec_t time_spec=uhd::time_spec_t(0.0), const bool repeat=false)=0uhd::rfnoc::replay_block_controlpure virtual
PLAY_CMD_CONTINUOUSuhd::rfnoc::replay_block_controlstatic
PLAY_CMD_FINITEuhd::rfnoc::replay_block_controlstatic
PLAY_CMD_STOPuhd::rfnoc::replay_block_controlstatic
post_input_action(const std::shared_ptr< uhd::rfnoc::action_info > &action, const size_t port)=0uhd::rfnoc::replay_block_controlpure virtual
post_output_action(const std::shared_ptr< uhd::rfnoc::action_info > &action, const size_t port)=0uhd::rfnoc::replay_block_controlpure virtual
record(const uint64_t offset, const uint64_t size, const size_t port=0)=0uhd::rfnoc::replay_block_controlpure virtual
record_restart(const size_t port=0)=0uhd::rfnoc::replay_block_controlpure virtual
REG_COMPAT_ADDRuhd::rfnoc::replay_block_controlstatic
REG_MEM_SIZE_ADDRuhd::rfnoc::replay_block_controlstatic
REG_PLAY_BASE_ADDR_HI_ADDRuhd::rfnoc::replay_block_controlstatic
REG_PLAY_BASE_ADDR_LO_ADDRuhd::rfnoc::replay_block_controlstatic
REG_PLAY_BUFFER_SIZE_HI_ADDRuhd::rfnoc::replay_block_controlstatic
REG_PLAY_BUFFER_SIZE_LO_ADDRuhd::rfnoc::replay_block_controlstatic
REG_PLAY_CMD_ADDRuhd::rfnoc::replay_block_controlstatic
REG_PLAY_CMD_FIFO_SPACE_ADDRuhd::rfnoc::replay_block_controlstatic
REG_PLAY_CMD_NUM_WORDS_HI_ADDRuhd::rfnoc::replay_block_controlstatic
REG_PLAY_CMD_NUM_WORDS_LO_ADDRuhd::rfnoc::replay_block_controlstatic
REG_PLAY_CMD_TIME_HI_ADDRuhd::rfnoc::replay_block_controlstatic
REG_PLAY_CMD_TIME_LO_ADDRuhd::rfnoc::replay_block_controlstatic
REG_PLAY_ITEM_SIZE_ADDRuhd::rfnoc::replay_block_controlstatic
REG_PLAY_POS_HI_ADDRuhd::rfnoc::replay_block_controlstatic
REG_PLAY_POS_LO_ADDRuhd::rfnoc::replay_block_controlstatic
REG_PLAY_WORDS_PER_PKT_ADDRuhd::rfnoc::replay_block_controlstatic
REG_REC_BASE_ADDR_HI_ADDRuhd::rfnoc::replay_block_controlstatic
REG_REC_BASE_ADDR_LO_ADDRuhd::rfnoc::replay_block_controlstatic
REG_REC_BUFFER_SIZE_HI_ADDRuhd::rfnoc::replay_block_controlstatic
REG_REC_BUFFER_SIZE_LO_ADDRuhd::rfnoc::replay_block_controlstatic
REG_REC_FULLNESS_HI_ADDRuhd::rfnoc::replay_block_controlstatic
REG_REC_FULLNESS_LO_ADDRuhd::rfnoc::replay_block_controlstatic
REG_REC_POS_HI_ADDRuhd::rfnoc::replay_block_controlstatic
REG_REC_POS_LO_ADDRuhd::rfnoc::replay_block_controlstatic
REG_REC_RESTART_ADDRuhd::rfnoc::replay_block_controlstatic
REPLAY_ADDR_Wuhd::rfnoc::replay_block_controlstatic
REPLAY_BLOCK_OFFSETuhd::rfnoc::replay_block_controlstatic
set_max_items_per_packet(const uint32_t ipp, const size_t port=0)=0uhd::rfnoc::replay_block_controlpure virtual
set_max_packet_size(const uint32_t size, const size_t port=0)=0uhd::rfnoc::replay_block_controlpure virtual
set_play_type(const io_type_t type, const size_t port=0)=0uhd::rfnoc::replay_block_controlpure virtual
set_record_type(const io_type_t type, const size_t port=0)=0uhd::rfnoc::replay_block_controlpure virtual
stop(const size_t port=0)=0uhd::rfnoc::replay_block_controlpure virtual
