iq_cal.hpp
2 // Copyright 2020 Ettus Research, a National Instruments Brand
5 //
6
7 #pragma once
8
9 #include <uhd/cal/container.hpp>
10 #include <uhd/config.hpp>
12 #include <complex>
13 #include <cstdint>
14 #include <memory>
15 #include <string>
16
17 namespace uhd { namespace usrp { namespace cal {
18
25 class UHD_API iq_cal : public container
26 {
27 public:
28  using sptr = std::shared_ptr<iq_cal>;
29
31  //
32  // This class supports two kinds of interpolation: Nearest-neighbour, and
33  // linear.
34  //
35  // \param interp The new interpolation mode
36  // \throws uhd::value_error if the given interpolation mode is not
37  // supported.
38  virtual void set_interp_mode(const uhd::math::interp_mode interp) = 0;
39
41  //
42  // This function will interpolate to return a valid coefficient for any
43  // given frequency.
44  virtual std::complex<double> get_cal_coeff(const double freq) const = 0;
45
47  //
48  // This usually only needs to called by calibration utilities.
49  //
50  // \param freq The frequency at which this coefficient is measured
51  // \param coeff The value that is stored
52  // \param suppression_abs The amount of impairment suppression this
53  // coefficient provides, in dB.
54  // \param suppression_delta The difference of impairment power between
55  // applying this coefficient and applying none, in
56  // dB.
57  virtual void set_cal_coeff(const double freq,
58  const std::complex<double> coeff,
59  const double suppression_abs = 0,
60  const double suppression_delta = 0) = 0;
61
63  //
64  // This can be useful in order to drop existing cal data, and load an
65  // entirely new set with deserialize().
66  virtual void clear() = 0;
67
69  static sptr make(
70  const std::string& name, const std::string& serial, const uint64_t timestamp);
71
73  static sptr make();
74 };
75
76 }}} // namespace uhd::usrp::cal
uhd::usrp::cal::iq_cal::sptr
std::shared_ptr< iq_cal > sptr
Definition: iq_cal.hpp:28
config.hpp
UHD_API
Definition: config.h:87
uhd
Definition: build_info.hpp:12
Definition: iq_cal.hpp:25
container.hpp
interp_mode
Definition: interpolation.hpp:11
interpolation.hpp
uhd::usrp::cal::container
Definition: container.hpp:22
