multi_usrp.hpp
2 // Copyright 2010-2012,2014-2015 Ettus Research LLC
4 //
6 //
7
8 #pragma once
9
10 // define API capabilities for compile time detection of new features
11 #define UHD_USRP_MULTI_USRP_REF_SOURCES_API
12 #define UHD_USRP_MULTI_USRP_GET_RATES_API
13 #define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API
14 #define UHD_USRP_MULTI_USRP_FRONTEND_IQ_AUTO_API
15 #define UHD_USRP_MULTI_USRP_COMMAND_TIME_API
16 #define UHD_USRP_MULTI_USRP_BW_RANGE_API
17 #define UHD_USRP_MULTI_USRP_USER_REGS_API
18 #define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API
19 #define UHD_USRP_MULTI_USRP_NORMALIZED_GAIN
20 #define UHD_USRP_MULTI_USRP_GPIO_API
21 #define UHD_USRP_MULTI_USRP_REGISTER_API
22 #define UHD_USRP_MULTI_USRP_FILTER_API
23 #define UHD_USRP_MULTI_USRP_LO_CONFIG_API
24 #define UHD_USRP_MULTI_USRP_TX_LO_CONFIG_API
25 #define UHD_USRP_MULTI_USRP_POWER_LEVEL
26
27 #include <uhd/config.hpp>
28 #include <uhd/device.hpp>
32 #include <uhd/types/filters.hpp>
33 #include <uhd/types/ranges.hpp>
34 #include <uhd/types/sensors.hpp>
35 #include <uhd/types/stream_cmd.hpp>
38 #include <uhd/types/wb_iface.hpp>
40 #include <uhd/usrp/subdev_spec.hpp>
42 #include <complex>
43 #include <memory>
44 #include <string>
45 #include <vector>
46
47 namespace uhd { namespace usrp {
48
96 {
97 public:
98  typedef std::shared_ptr<multi_usrp> sptr;
99
100  virtual ~multi_usrp(void) = 0;
101
103  static const size_t ALL_MBOARDS;
104
106  static const size_t ALL_CHANS;
107
109  static const std::string ALL_GAINS;
110
112  static const std::string ALL_LOS;
113
121  static sptr make(const device_addr_t& dev_addr);
122
137  virtual device::sptr get_device(void) = 0;
138
141  virtual uhd::property_tree::sptr get_tree(void) const = 0;
142
144  virtual rx_streamer::sptr get_rx_stream(const stream_args_t& args) = 0;
145
147  virtual tx_streamer::sptr get_tx_stream(const stream_args_t& args) = 0;
148
156  virtual dict<std::string, std::string> get_usrp_rx_info(size_t chan = 0) = 0;
157
165  virtual dict<std::string, std::string> get_usrp_tx_info(size_t chan = 0) = 0;
166
167  /*******************************************************************
168  * Mboard methods
169  ******************************************************************/
170
193  virtual void set_master_clock_rate(double rate, size_t mboard = ALL_MBOARDS) = 0;
194
200  virtual double get_master_clock_rate(size_t mboard = 0) = 0;
201
220  virtual meta_range_t get_master_clock_rate_range(const size_t mboard = 0) = 0;
221
226  virtual std::string get_pp_string(void) = 0;
227
233  virtual std::string get_mboard_name(size_t mboard = 0) = 0;
234
245  virtual time_spec_t get_time_now(size_t mboard = 0) = 0;
246
257  virtual time_spec_t get_time_last_pps(size_t mboard = 0) = 0;
258
268  virtual void set_time_now(
269  const time_spec_t& time_spec, size_t mboard = ALL_MBOARDS) = 0;
270
299  virtual void set_time_next_pps(
300  const time_spec_t& time_spec, size_t mboard = ALL_MBOARDS) = 0;
301
322  virtual void set_time_unknown_pps(const time_spec_t& time_spec) = 0;
323
330  virtual bool get_time_synchronized(void) = 0;
331
342  virtual void set_command_time(
343  const uhd::time_spec_t& time_spec, size_t mboard = ALL_MBOARDS) = 0;
344
350  virtual void clear_command_time(size_t mboard = ALL_MBOARDS) = 0;
351
364  virtual void issue_stream_cmd(
365  const stream_cmd_t& stream_cmd, size_t chan = ALL_CHANS) = 0;
366
409  virtual void set_time_source(
410  const std::string& source, const size_t mboard = ALL_MBOARDS) = 0;
411
417  virtual std::string get_time_source(const size_t mboard) = 0;
418
424  virtual std::vector<std::string> get_time_sources(const size_t mboard) = 0;
425
476  virtual void set_clock_source(
477  const std::string& source, const size_t mboard = ALL_MBOARDS) = 0;
478
484  virtual std::string get_clock_source(const size_t mboard) = 0;
485
491  virtual std::vector<std::string> get_clock_sources(const size_t mboard) = 0;
492
503  virtual void set_sync_source(const std::string& clock_source,
504  const std::string& time_source,
505  const size_t mboard = ALL_MBOARDS) = 0;
506
537  virtual void set_sync_source(
538  const device_addr_t& sync_source, const size_t mboard = ALL_MBOARDS) = 0;
539
545  virtual device_addr_t get_sync_source(const size_t mboard) = 0;
546
552  virtual std::vector<device_addr_t> get_sync_sources(const size_t mboard) = 0;
553
568  virtual void set_clock_source_out(
569  const bool enb, const size_t mboard = ALL_MBOARDS) = 0;
570
585  virtual void set_time_source_out(
586  const bool enb, const size_t mboard = ALL_MBOARDS) = 0;
587
591  virtual size_t get_num_mboards(void) = 0;
592
599  virtual sensor_value_t get_mboard_sensor(
600  const std::string& name, size_t mboard = 0) = 0;
601
607  virtual std::vector<std::string> get_mboard_sensor_names(size_t mboard = 0) = 0;
608
618  virtual void set_user_register(
619  const uint8_t addr, const uint32_t data, size_t mboard = ALL_MBOARDS) = 0;
620
645  virtual uhd::wb_iface::sptr get_user_settings_iface(const size_t chan = 0) = 0;
646
664  virtual uhd::rfnoc::radio_control& get_radio_control(const size_t chan = 0) = 0;
665
673  virtual uhd::extension::extension::sptr get_extension(
674  const direction_t trx, const size_t chan) = 0;
675
685  template <typename T>
686  typename T::sptr get_extension(const direction_t trx, const size_t chan)
687  {
688  return std::dynamic_pointer_cast<T>(get_extension(trx, chan));
689  }
690
691  /*******************************************************************
692  * RX methods
693  ******************************************************************/
704  virtual void set_rx_subdev_spec(
705  const uhd::usrp::subdev_spec_t& spec, size_t mboard = ALL_MBOARDS) = 0;
706
712  virtual uhd::usrp::subdev_spec_t get_rx_subdev_spec(size_t mboard = 0) = 0;
713
719  virtual size_t get_rx_num_channels(void) = 0;
720
726  virtual std::string get_rx_subdev_name(size_t chan = 0) = 0;
727
737  virtual void set_rx_rate(double rate, size_t chan = ALL_CHANS) = 0;
738
748  virtual void set_rx_spp(const size_t spp, const size_t chan = ALL_CHANS) = 0;
749
755  virtual double get_rx_rate(size_t chan = 0) = 0;
756
762  virtual meta_range_t get_rx_rates(size_t chan = 0) = 0;
763
774  virtual tune_result_t set_rx_freq(
775  const tune_request_t& tune_request, size_t chan = 0) = 0;
776
782  virtual double get_rx_freq(size_t chan = 0) = 0;
783
793  virtual freq_range_t get_rx_freq_range(size_t chan = 0) = 0;
794
800  virtual freq_range_t get_fe_rx_freq_range(size_t chan = 0) = 0;
801
802  /**************************************************************************
803  * LO controls
804  *************************************************************************/
818  virtual std::vector<std::string> get_rx_lo_names(size_t chan = 0) = 0;
819
838  virtual void set_rx_lo_source(
839  const std::string& src, const std::string& name = ALL_LOS, size_t chan = 0) = 0;
840
849  virtual const std::string get_rx_lo_source(
850  const std::string& name = ALL_LOS, size_t chan = 0) = 0;
851
864  virtual std::vector<std::string> get_rx_lo_sources(
865  const std::string& name = ALL_LOS, size_t chan = 0) = 0;
866
877  virtual void set_rx_lo_export_enabled(
878  bool enabled, const std::string& name = ALL_LOS, size_t chan = 0) = 0;
879
885  virtual bool get_rx_lo_export_enabled(
886  const std::string& name = ALL_LOS, size_t chan = 0) = 0;
887
912  virtual double set_rx_lo_freq(
913  double freq, const std::string& name, size_t chan = 0) = 0;
914
925  virtual double get_rx_lo_freq(const std::string& name, size_t chan = 0) = 0;
926
936  virtual freq_range_t get_rx_lo_freq_range(
937  const std::string& name, size_t chan = 0) = 0;
938
951  virtual std::vector<std::string> get_tx_lo_names(size_t chan = 0) = 0;
952
968  virtual void set_tx_lo_source(const std::string& src,
969  const std::string& name = ALL_LOS,
970  const size_t chan = 0) = 0;
971
980  virtual const std::string get_tx_lo_source(
981  const std::string& name = ALL_LOS, const size_t chan = 0) = 0;
982
993  virtual std::vector<std::string> get_tx_lo_sources(
994  const std::string& name = ALL_LOS, const size_t chan = 0) = 0;
995
1006  virtual void set_tx_lo_export_enabled(
1007  const bool enabled, const std::string& name = ALL_LOS, const size_t chan = 0) = 0;
1008
1014  virtual bool get_tx_lo_export_enabled(
1015  const std::string& name = ALL_LOS, const size_t chan = 0) = 0;
1016
1041  virtual double set_tx_lo_freq(
1042  const double freq, const std::string& name, const size_t chan = 0) = 0;
1043
1054  virtual double get_tx_lo_freq(const std::string& name, const size_t chan = 0) = 0;
1055
1065  virtual freq_range_t get_tx_lo_freq_range(
1066  const std::string& name, const size_t chan = 0) = 0;
1067
1068  /**************************************************************************
1069  * Gain controls
1070  *************************************************************************/
1084  virtual void set_rx_gain(double gain, const std::string& name, size_t chan = 0) = 0;
1085
1098  virtual std::vector<std::string> get_rx_gain_profile_names(const size_t chan = 0) = 0;
1099
1108  virtual void set_rx_gain_profile(
1109  const std::string& profile, const size_t chan = 0) = 0;
1110
1116  virtual std::string get_rx_gain_profile(const size_t chan = 0) = 0;
1117
1119  void set_rx_gain(double gain, size_t chan = 0)
1120  {
1121  return this->set_rx_gain(gain, ALL_GAINS, chan);
1122  }
1123
1141  virtual void set_normalized_rx_gain(double gain, size_t chan = 0) = 0;
1142
1160  virtual void set_rx_agc(bool enable, size_t chan = 0) = 0;
1161
1169  virtual double get_rx_gain(const std::string& name, size_t chan = 0) = 0;
1170
1172  double get_rx_gain(size_t chan = 0)
1173  {
1174  return this->get_rx_gain(ALL_GAINS, chan);
1175  }
1176
1187  virtual double get_normalized_rx_gain(size_t chan = 0) = 0;
1188
1196  virtual gain_range_t get_rx_gain_range(const std::string& name, size_t chan = 0) = 0;
1197
1200  {
1201  return this->get_rx_gain_range(ALL_GAINS, chan);
1202  }
1203
1210  virtual std::vector<std::string> get_rx_gain_names(size_t chan = 0) = 0;
1211
1220  virtual void set_rx_antenna(const std::string& ant, size_t chan = 0) = 0;
1221
1227  virtual std::string get_rx_antenna(size_t chan = 0) = 0;
1228
1234  virtual std::vector<std::string> get_rx_antennas(size_t chan = 0) = 0;
1235
1245  virtual void set_rx_bandwidth(double bandwidth, size_t chan = 0) = 0;
1246
1252  virtual double get_rx_bandwidth(size_t chan = 0) = 0;
1253
1259  virtual meta_range_t get_rx_bandwidth_range(size_t chan = 0) = 0;
1260
1268  virtual dboard_iface::sptr get_rx_dboard_iface(size_t chan = 0) = 0;
1269
1276  virtual sensor_value_t get_rx_sensor(const std::string& name, size_t chan = 0) = 0;
1277
1283  virtual std::vector<std::string> get_rx_sensor_names(size_t chan = 0) = 0;
1284
1297  virtual void set_rx_dc_offset(const bool enb, size_t chan = ALL_CHANS) = 0;
1298
1306  virtual void set_rx_dc_offset(
1307  const std::complex<double>& offset, size_t chan = ALL_CHANS) = 0;
1308
1313  virtual meta_range_t get_rx_dc_offset_range(size_t chan = 0) = 0;
1314
1321  virtual void set_rx_iq_balance(const bool enb, size_t chan) = 0;
1322
1330  virtual void set_rx_iq_balance(
1331  const std::complex<double>& correction, size_t chan = ALL_CHANS) = 0;
1332
1333
1334  /**************************************************************************
1335  * Power level controls
1336  *************************************************************************/
1353  virtual bool has_rx_power_reference(const size_t chan = 0) = 0;
1354
1369  virtual void set_rx_power_reference(
1370  const double power_dbm, const size_t chan = 0) = 0;
1371
1384  virtual double get_rx_power_reference(const size_t chan = 0) = 0;
1385
1395  virtual meta_range_t get_rx_power_range(const size_t chan) = 0;
1396
1397  /*******************************************************************
1398  * TX methods
1399  ******************************************************************/
1409  virtual void set_tx_subdev_spec(
1410  const uhd::usrp::subdev_spec_t& spec, size_t mboard = ALL_MBOARDS) = 0;
1411
1417  virtual uhd::usrp::subdev_spec_t get_tx_subdev_spec(size_t mboard = 0) = 0;
1418
1424  virtual size_t get_tx_num_channels(void) = 0;
1425
1431  virtual std::string get_tx_subdev_name(size_t chan = 0) = 0;
1432
1442  virtual void set_tx_rate(double rate, size_t chan = ALL_CHANS) = 0;
1443
1449  virtual double get_tx_rate(size_t chan = 0) = 0;
1450
1456  virtual meta_range_t get_tx_rates(size_t chan = 0) = 0;
1457
1468  virtual tune_result_t set_tx_freq(
1469  const tune_request_t& tune_request, size_t chan = 0) = 0;
1470
1476  virtual double get_tx_freq(size_t chan = 0) = 0;
1477
1487  virtual freq_range_t get_tx_freq_range(size_t chan = 0) = 0;
1488
1494  virtual freq_range_t get_fe_tx_freq_range(size_t chan = 0) = 0;
1495
1509  virtual void set_tx_gain(double gain, const std::string& name, size_t chan = 0) = 0;
1510
1523  virtual std::vector<std::string> get_tx_gain_profile_names(const size_t chan = 0) = 0;
1524
1533  virtual void set_tx_gain_profile(
1534  const std::string& profile, const size_t chan = 0) = 0;
1535
1541  virtual std::string get_tx_gain_profile(const size_t chan = 0) = 0;
1542
1544  void set_tx_gain(double gain, size_t chan = 0)
1545  {
1546  return this->set_tx_gain(gain, ALL_GAINS, chan);
1547  }
1548
1561  virtual void set_normalized_tx_gain(double gain, size_t chan = 0) = 0;
1562
1570  virtual double get_tx_gain(const std::string& name, size_t chan = 0) = 0;
1571
1573  double get_tx_gain(size_t chan = 0)
1574  {
1575  return this->get_tx_gain(ALL_GAINS, chan);
1576  }
1577
1588  virtual double get_normalized_tx_gain(size_t chan = 0) = 0;
1589
1597  virtual gain_range_t get_tx_gain_range(const std::string& name, size_t chan = 0) = 0;
1598
1601  {
1602  return this->get_tx_gain_range(ALL_GAINS, chan);
1603  }
1604
1611  virtual std::vector<std::string> get_tx_gain_names(size_t chan = 0) = 0;
1612
1613  /**************************************************************************
1614  * Power level controls
1615  *************************************************************************/
1632  virtual bool has_tx_power_reference(const size_t chan = 0) = 0;
1633
1648  virtual void set_tx_power_reference(
1649  const double power_dbm, const size_t chan = 0) = 0;
1650
1663  virtual double get_tx_power_reference(const size_t chan = 0) = 0;
1664
1674  virtual meta_range_t get_tx_power_range(const size_t chan) = 0;
1675
1684  virtual void set_tx_antenna(const std::string& ant, size_t chan = 0) = 0;
1685
1691  virtual std::string get_tx_antenna(size_t chan = 0) = 0;
1692
1698  virtual std::vector<std::string> get_tx_antennas(size_t chan = 0) = 0;
1699
1709  virtual void set_tx_bandwidth(double bandwidth, size_t chan = 0) = 0;
1710
1716  virtual double get_tx_bandwidth(size_t chan = 0) = 0;
1717
1723  virtual meta_range_t get_tx_bandwidth_range(size_t chan = 0) = 0;
1724
1732  virtual dboard_iface::sptr get_tx_dboard_iface(size_t chan = 0) = 0;
1733
1740  virtual sensor_value_t get_tx_sensor(const std::string& name, size_t chan = 0) = 0;
1741
1747  virtual std::vector<std::string> get_tx_sensor_names(size_t chan = 0) = 0;
1748
1755  virtual void set_tx_dc_offset(
1756  const std::complex<double>& offset, size_t chan = ALL_CHANS) = 0;
1757
1762  virtual meta_range_t get_tx_dc_offset_range(size_t chan = 0) = 0;
1763
1771  virtual void set_tx_iq_balance(
1772  const std::complex<double>& correction, size_t chan = ALL_CHANS) = 0;
1773
1774  /*******************************************************************
1775  * GPIO methods
1776  ******************************************************************/
1777
1783  virtual std::vector<std::string> get_gpio_banks(const size_t mboard) = 0;
1784
1837  virtual void set_gpio_attr(const std::string& bank,
1838  const std::string& attr,
1839  const uint32_t value,
1840  const uint32_t mask = 0xffffffff,
1841  const size_t mboard = 0) = 0;
1842
1862  virtual uint32_t get_gpio_attr(
1863  const std::string& bank, const std::string& attr, const size_t mboard = 0) = 0;
1864
1881  virtual std::vector<std::string> get_gpio_src_banks(const size_t mboard = 0) = 0;
1882
1893  virtual std::vector<std::string> get_gpio_srcs(
1894  const std::string& bank, const size_t mboard = 0) = 0;
1895
1905  virtual std::vector<std::string> get_gpio_src(
1906  const std::string& bank, const size_t mboard = 0) = 0;
1907
1922  virtual void set_gpio_src(const std::string& bank,
1923  const std::vector<std::string>& src,
1924  const size_t mboard = 0) = 0;
1925
1926  /*******************************************************************
1927  * Filter API methods
1928  ******************************************************************/
1929  // TODO: This should be a const function, but I don't want to wrestle with the
1930  // compiler right now
1938  virtual std::vector<std::string> get_rx_filter_names(const size_t chan) = 0;
1939
1946  virtual uhd::filter_info_base::sptr get_rx_filter(
1947  const std::string& name, const size_t chan) = 0;
1948
1956  virtual void set_rx_filter(const std::string& name,
1958  const size_t chan) = 0;
1959
1960  // TODO: This should be a const function, but I don't want to wrestle with the
1961  // compiler right now
1969  virtual std::vector<std::string> get_tx_filter_names(const size_t chan) = 0;
1970
1977  virtual uhd::filter_info_base::sptr get_tx_filter(
1978  const std::string& name, const size_t chan) = 0;
1979
1987  virtual void set_tx_filter(const std::string& name,
1989  const size_t chan) = 0;
1990
2008  virtual uhd::rfnoc::mb_controller& get_mb_controller(const size_t mboard = 0) = 0;
2009 };
2010
2011 }} // namespace uhd::usrp
uhd::soft_reg_field::mask
Definition: soft_register.hpp:86
sensors.hpp
radio_control.hpp
config.hpp
uhd::wb_iface::sptr
std::shared_ptr< wb_iface > sptr
Definition: wb_iface.hpp:20
device.hpp
tune_request.hpp
uhd::usrp::multi_usrp::set_tx_gain
Definition: multi_usrp.hpp:1544
extension.hpp
uhd::rx_streamer::sptr
Definition: stream.hpp:172
dboard_iface.hpp
uhd::usrp::multi_usrp::get_tx_gain_range
Definition: multi_usrp.hpp:1600
uhd::tx_streamer::sptr
std::shared_ptr< tx_streamer > sptr
Definition: stream.hpp:278
Definition: mb_controller.hpp:28
std::shared_ptr< extension > sptr
Definition: extension.hpp:40
uhd::usrp::multi_usrp::sptr
std::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:98
UHD_API
Definition: config.h:87
uhd::usrp::cal::source
source
Identify the source of calibration data, i.e., where was it stored.
Definition: database.hpp:22
Definition: property_tree.hpp:224
noncopyable.hpp
uhd::usrp::dboard_iface::sptr
std::shared_ptr< dboard_iface > sptr
Definition: dboard_iface.hpp:56
stream_cmd.hpp
uhd::device_addr_t
std::shared_ptr< filter_info_base > sptr
Definition: filters.hpp:24
subdev_spec.hpp
uhd
Definition: build_info.hpp:12
uhd::time_spec_t
Definition: time_spec.hpp:28
Definition: radio_control.hpp:101
ranges.hpp
uhd::stream_cmd_t
Definition: stream_cmd.hpp:39
uhd::tune_request_t
Definition: tune_request.hpp:24
uhd::usrp::multi_usrp::get_extension
Definition: multi_usrp.hpp:686
uhd::usrp::multi_usrp::ALL_GAINS
A wildcard gain element name.
Definition: multi_usrp.hpp:109
filters.hpp
uhd::stream_args_t
Definition: stream.hpp:50
Definition: multi_usrp.hpp:1573
uhd::device::sptr
std::shared_ptr< device > sptr
Definition: device.hpp:29
Definition: multi_usrp.hpp:95
wb_iface.hpp
uhd::usrp::multi_usrp::set_rx_gain
Definition: multi_usrp.hpp:1119
uhd::noncopyable
uhd::usrp::multi_usrp::ALL_LOS
A wildcard LO stage name.
Definition: multi_usrp.hpp:112
Definition: subdev_spec.hpp:59
uhd::usrp::multi_usrp::get_rx_gain
Definition: multi_usrp.hpp:1172
mb_controller.hpp
uhd::usrp::multi_usrp::ALL_CHANS
A wildcard channel index.
Definition: multi_usrp.hpp:106
uhd::usrp::multi_usrp::ALL_MBOARDS
A wildcard motherboard index.
Definition: multi_usrp.hpp:103
uhd::sensor_value_t
Definition: sensors.hpp:28
uhd::usrp::multi_usrp::get_rx_gain_range
Definition: multi_usrp.hpp:1199
uhd::meta_range_t
Definition: ranges.hpp:65
uhd::direction_t
direction_t
Definition: direction.hpp:12
tune_result.hpp
uhd::tune_result_t
Definition: tune_result.hpp:18
