16 #include <unordered_map>
   17 #include <unordered_set>
   18 #include <boost/graph/adjacency_list.hpp>
   26 namespace uhd {
namespace rfnoc {
   43         std::unordered_map<res_source_info, std::vector<res_source_info>>;
   64     static const size_t ANY_PORT = size_t(~0);
   80     virtual std::string get_unique_id()
const;
   88     virtual size_t get_num_input_ports()
const = 0;
   96     virtual size_t get_num_output_ports()
const = 0;
  110     std::vector<std::string> get_property_ids()
const;
  127     template <
typename prop_data_t>
  129         const std::string&
id,
const prop_data_t& val,
const size_t instance = 0);
  182     template <
  183     const prop_data_t& get_property(
  184         const std::string&
id,
const size_t instance = 0) ;
  201     virtual void set_command_time(
uhd::time_spec_t time,
const size_t instance);
  214     virtual void clear_command_time(
  242     void register_property(
  279     void add_property_resolver(
  305     void set_prop_forwarding_policy(
  342     template <
  344         const std::string&
id,
const res_source_info& src_info);
  357     template <
  358     const prop_data_t& get_property(
  377     void register_action_handler(
const std::string&
id,
action_handler_t&& handler);
  397     void set_action_forwarding_policy(
  460     virtual bool check_topology(
const std::vector<size_t>& connected_inputs,
  461         const std::vector<size_t>& connected_outputs);
  468     virtual void shutdown();
  477     friend class node_accessor_t;
  498     template <
typename PredicateType>
  499     prop_ptrs_t filter_props(PredicateType&& predicate)
  502         for (
const auto& type_prop_pair : _props) {
  503             for (
const auto& prop : type_prop_pair.second) {
  504                 if (predicate(prop)) {
  505                     filtered_props.push_back(prop);
  510         return filtered_props;
  520     property_base_t* inject_edge_property(
  521         property_base_t* blueprint, res_source_info new_src_info);
  561     void resolve_props();
  577     void set_resolve_all_callback(resolve_callback_t&& resolver)
  579         _resolve_all_cb = resolver;
  584     void clear_resolve_all_callback()
  586         _resolve_all_cb = _default_resolve_all_cb;
  592     void set_graph_mutex_callback(graph_mutex_callback_t&& mutex)
  594         _graph_mutex_cb = mutex;
  600     void clear_graph_mutex_callback()
  602         _graph_mutex_cb = NULL;
  639     void forward_edge_property(
  640         property_base_t* incoming_prop,
const size_t incoming_port);
  648     void set_post_action_callback(action_handler_t&& post_handler)
  650         _post_action_cb = std::move(post_handler);
  667     bool _has_port(
const res_source_info& port_info)
const;
  670     template <
  672         const std::string&
id,
  678     mutable std::mutex _prop_mutex;
  682         std::vector<property_base_t*>,
  687     std::unordered_map<property_base_t*, resolve_callback_t> _clean_cb_registry;
  689     using property_resolver_t = std::tuple<prop_ptrs_t, prop_ptrs_t, resolver_fn_t>;
  691     std::vector<property_resolver_t> _prop_resolvers;
  696     graph_mutex_callback_t _graph_mutex_cb;
  700     resolve_callback_t _resolve_all_cb;
  704     const resolve_callback_t _default_resolve_all_cb = [
this]() {
  716     std::unordered_set<std::unique_ptr<property_base_t>> _dynamic_props;
  721     std::unordered_map<std::string, forwarding_policy_t> _prop_fwd_policies{
  722         {
"", forwarding_policy_t::ONE_TO_ONE}};
  725     forwarding_map_t _prop_fwd_map;
  730     mutable std::mutex _action_mutex;
  733     std::unordered_map<std::string, action_handler_t> _action_handlers;
  736     std::unordered_map<std::string, forwarding_policy_t> _action_fwd_policies{
  737         {
  742     action_handler_t _post_action_cb = [](
const res_source_info&,
  746     forwarding_map_t _action_fwd_map;
  751     std::vector<uhd::time_spec_t> _cmd_timespecs;
